5572 connectés
Problème avec Postfix
n°246085
beber.done​ux01
oui
Posté le 06-04-2003 à 17:43:06  profilanswer
a mon avi tu dois simplement rajouter localhost à mydestination
n°246132
linuxois1
acharnement = réussite
Posté le 06-04-2003 à 19:07:12  profilanswer
Voici mon fichier main.cf qui fonctionne :
# SOFT BOUNCE
soft_bounce = yes
# LOCAL PATHNAME INFORMATION
queue_directory = /var/spool/postfix
command_directory = /usr/sbin
daemon_directory = /usr/lib/postfix
# QUEUE AND PROCESS OWNERSHIP
mail_owner = postfix
default_privs = nobody
# INTERNET HOST AND DOMAIN NAMES
myhostname = NomTaMachine.TonNomDomaine
mydomain = TonNomDomaine
# SENDING MAIL
myorigin = $myhostname
myorigin = $mydomain
# RECEIVING MAIL
inet_interfaces = $myhostname, localhost
mydestination = $myhostname, localhost.$mydomain, $mydomain
# TRUST AND RELAY CONTROL
mynetworks = 192.168.4.0/24, 127.0.0.0/8
relay_domains = $mydestination
# INTERNET OR INTRANET
relayhost = NomTaMachine.TonNomDomaine:25
relayhost = $mydomain
# REJECTING UNKNOWN LOCAL USERS
#local_recipient_maps = $alias_maps unix:passwd.byname
# ADDRESS REWRITING
sender_canonical_maps = hash:/etc/postfix/canonical
# ADDRESS REDIRECTION (VIRTUAL DOMAIN)
virtual_maps = hash:/etc/postfix/virtual
# "USER HAS MOVED" BOUNCE MESSAGES
# TRANSPORT MAP
default_transport = smtp
transport_maps = hash:/etc/postfix/transport
# ALIAS DATABASE
alias_maps = hash:/etc/postfix/aliases
alias_database = hash:/etc/postfix/aliases
# ADDRESS EXTENSIONS (e.g., user+foo)
# DELIVERY TO MAILBOX
mail_spool_directory = /var/spool/mail
# EXTENSION (address extension), DOMAIN (domain part of address),
# IF YOU USE THIS TO DELIVER MAIL SYSTEM-WIDE, YOU MUST SET UP AN
# ALIAS THAT FORWARDS MAIL FOR ROOT TO A REAL USER.
mailbox_command = /usr/bin/procmail -a $DOMAIN -d $LOGNAME
# JUNK MAIL CONTROLS
#header_checks = regexp:/etc/postfix/header_checks
# FAST ETRN SERVICE
#fast_flush_domains = $relay_domains
# SHOW SOFTWARE VERSION OR NOT
#smtpd_banner = $myhostname ESMTP $mail_name
#smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
smtpd_banner = $myhostname ESMTP $mail_name ($mail_version) (Mandrake Linux)
# PARALLEL DELIVERY TO THE SAME DESTINATION
local_destination_concurrency_limit = 2
default_destination_concurrency_limit = 10
# DEBUGGING CONTROL
debug_peer_level = 2
#debug_peer_list = 127.0.0.1
#debug_peer_list = some.domain
debugger_command =
  PATH=/usr/bin:/usr/X11R6/bin
  xxgdb $daemon_directory/$process_name $process_id & sleep 5
# OTHER OPTIONS (Mandrake)
delay_warning_time = 4
# INSTALL-TIME CONFIGURATION INFORMATION
sendmail_path = /usr/sbin/sendmail.postfix
newaliases_path = /usr/bin/newaliases.postfix
mailq_path = /usr/bin/mailq.postfix
setgid_group = postdrop
manpage_directory = /usr/share/man
sample_directory = /usr/share/doc/postfix-1.1.11/samples
readme_directory = /usr/share/doc/postfix-1.1.11/README_FILES
# LIMITATIONS
defaultdestination_recipient_limite = 20
maximal_queue_lifetime = 5
header_sizelimit = 102400
message_size_limit = 10240000
queue_min_free = 10000000
smtpd_error_sleep_time = 5
smtpd_soft_error_limit = 10
smtpd_hard_error_limit = 10
# SECURITY
disable_vrfy_command = yes
smtpd_helo_required = yes
smtpd_recipient_restrictions = check_client_access hash:/etc/postfix/clients, permit_mynetworks, check_relay_domains,reject_invalid_hostname, reject_non_fqdn_hostname, reject_non_fqdn_sender, reject_non_fqdn_recipient,reject_unknown_sender_domain, reject_unknown_recipient_domain, reject_unauth_pipelining, reject_unauth_destination, check_recipient_access pcre:/etc/postfix/recipient_checks.pcre, check_sender_access hash:/etc/postfix/sender_checks,check_sender_access hash:/etc/postfix/freemail_access, check_client_access hash:/etc/postfix/client_checks, check_client_access pcre:/etc/postfix/client_checks.pcre, reject_rbl_client relays.ordb.org, reject_rbl_client inputs.relays.osirusoft.com, reject_rbl_client dialups.relays.osirusoft.com, reject_rbl_client spamhaus.relays.osirusoft.com, reject_rbl_client proxies.relays.monkeys.com, reject_rbl_client opm.blitzed.org, permit_mynetworks, check_relay_domains, maps_rbl_domains = rbl.maps.vix.com, dul.maps.vix.com, relays.ordb.org, bl.spamcop.net
smtpd_sender_restrictions = reject_unknown_sender_domain, check_client_access hash:/etc/postfix/clients, permit_mynetworks, check_relay_domains
smtpd_client_restrictions = check_client_access hash:/etc/postfix/access, check_relay_domains, reject_maps_rbl, permit_mynetworks, check_relay_domains, permit_auth_destination, reject_unauth_destination, reject_unknown_recipient_domain, permit_mx_backup, reject_unknown_client, reject_unknown_sender_domain, check_sender_access hash:/etc/postfix/access, reject_non_fqdn_sender, local_recipient_maps = $alias_maps unix:passwd.byname
header_checks = regexp:/etc/postfix/headers_checks
smtpd_restriction_classes = from_freemail_host
from_freemail_host = check_client_access hash:/etc/postfix/freemail_hosts, reject
Bon courage.
Linuxois1 ex- Linuxois pour perte de mot de passe et @ adresse mail n'existant plus.
n°246137
Mjules
Parle dans le vide
Posté le 06-04-2003 à 19:13:32  profilanswer
ton fichier hosts est bien renseigné ? ou alors, tu as un DNS qui résoud ton nom local ?
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°246148
mikala
Souviens toi du 5 Novembre...
Posté le 06-04-2003 à 19:29:41  profilanswer
tu as bien fait les postmap virtual & co ?
ensuite pour les hots  postfix a son propre truc
fais un postfix check tiens .
n°246155
mikala
Posté le 06-04-2003 à 19:42:30  profilanswer
vegeta020786 a écrit :
J'ai copié ton main.cf (en remplaçant quelques trucs bien sur :))
mais:
Apr  6 19:17:20 OpenBSD sendmail[19177]: h36HHK92019177: from=arsenic, size=28, class=0, nrcpts=1, msgid=<200304061717.h36HHK92019177@OpenBSD.slackware-fr>, relay=root@localhost
Apr  6 19:17:21 OpenBSD postfix/smtpd[11424]: fatal: open dictionary: need "type:name" form: hashetc/postfix/virtual
Apr  6 19:17:22 OpenBSD postfix/master[17110]: warning: process /usr/local/libexec/postfix/smtpd pid 11424 exit status 1
Apr  6 19:17:22 OpenBSD postfix/master[17110]: warning: /usr/local/libexec/postfix/smtpd: bad command startup -- throttling
hum
tu as bien mis
Code :
  1. hash:/etc/postfix
car ton erreur la vient probablement de la :/
n°246162
mikala
Posté le 06-04-2003 à 19:54:40  profilanswer
J'ai vérifié comme j'ai copié/collé les smileys avaient merdés :D mais:
Apr  6 19:48:04 OpenBSD postfix/master[17110]: reload configuration
Apr  6 19:48:14 OpenBSD sendmail[21655]: h36HmEj0021655: from=arsenic, size=28, class=0, nrcpts=1, msgid=<200304061748.h36HmEj0021655@OpenBSD.slackware-fr>, relay=root@localhost
Apr  6 19:48:38 OpenBSD postfix/qmgr[15066]: fatal: open database /etc/postfix/virtual.db: No such file or directory
Apr  6 19:48:39 OpenBSD postfix/master[17110]: warning: process /usr/local/libexec/postfix/qmgr pid 15066 exit status 1
Apr  6 19:48:39 OpenBSD postfix/master[17110]: warning: /usr/local/libexec/postfix/qmgr: bad command startup -- throttling
fais un petit ~$ postmap virtual
dans ton /etc/postfix
n°246177
mikala
Posté le 06-04-2003 à 20:07:54  profilanswer
Heu je le fais comment? :D
OpenBSD# postmap virtual
postmap: Command not found.
emmanuelle:~# whereis postmap
postmap: /usr/sbin/postmap /usr/share/man/man1/postmap.1.gz
va falloir compiler correctement le postfix hein :)
(ou mettre les bons chemins  [:ddr555] )
n°246185
mikala
Posté le 06-04-2003 à 20:14:06  profilanswer
Bon c'était dans /usr/local/sbin/ :)
donc:
./postmap virtual
postmap: fatal: open virtual: No such file or directory
j'ai fait ça dans /usr/local/sbin
dans ce cas cd /etc/postfix
/usr/local/sbin/postmap virtual
(en gros faut creer la base de donnée pour postfix )
exemple chez moi
Code :
  1. emmanuelle:/etc/postfix# ls
  2. access     canonical       helo_access     main.cf    pcre_table    postfix-files   regexp_table  sender_access     transport     virtual
  3. access.db  dynamicmaps.cf  helo_access.db  master.cf  post-install  postfix-script  relocated     sender_access.db  transport.db
P.S: Open c'est nul pour faire de l'ipv6 natif  [:ddr555]
Edit: smiley de mes deux :o
Edit2: (oui je me sers pas de virtual , donc je ne lui est pas postmaté la tete :p )
Message édité par mikala le 06-04-2003 à 20:15:33
n°246192
mikala
Posté le 06-04-2003 à 20:23:08  profilanswer
Ca a bien créé le virtual.db dans /etc/postfix mais:Apr  6 20:16:48 OpenBSD postfix/master[17110]: reload configuration
Apr  6 20:16:53 OpenBSD postfix/cleanup[19218]: fatal: open database /etc/postfix/canonical.db: No such file or directory
Apr  6 20:16:54 OpenBSD postfix/master[17110]: warning: process /usr/local/libexec/postfix/cleanup pid 19218 exit status 1
Apr  6 20:16:54 OpenBSD postfix/master[17110]: warning: /usr/local/libexec/postfix/cleanup: bad command startup -- throttling
hum ;)
en gros a chaque fois qu'il te dis qu'il ne trouve pas le toto.db
tu dois partir pour un postmap toto :o)
donc postmap va , postmap :D
n°246215
mikala
Posté le 06-04-2003 à 20:51:32  profilanswer
aux grands maux les grands remedes :o
http://mikala.littleboboy.net/~mikala/postfix/
voila ma conf :o
(j'ai quelques domaines mx en backup mais pas la peine d'en tenir compte . )
Edit: l'ortografe dedieu  :whistle:
Message édité par mikala le 06-04-2003 à 20:52:07
n°246219
mikala
Posté le 06-04-2003 à 20:56:15  profilanswer
Tu connais Sha_? comme je vois que y'a copine de gruik, krukh dans ton main.cf :D
vivi :D
le chan officiel #copinedegruik est sur irc.tafiole.net :D
(je comprends mieux pk tu es sous *BSD [:spamafote]
viens donc ;o)
PROBLEME AVEC STUDIO 7 ET WIN XPcarte TV pinnacle et problème d'overlay
[SSH] Probleme de clée ou bien ?Un problème de mails
Problème fetchmail, procmail, spamassassin, evolution et postfix (ouf)petit probleme avec postfix !
Probleme de config postfix +amavis + viruscan [URGENT] [RESOLU]Problème Caramail + gnus et postfix
probleme loops back to myself : postfixProblème avec Postfix....
Plus de sujets relatifs à : Problème avec Postfix
