5530 connectés
  Linux et OS Alternatifs
  Multimédia
  Problem lecture fichier .avi avec mplayer
n°512899
brethold
Posté le 30-06-2004 à 15:09:12  profilanswer
lu all , c encore mplayer qui fé des ptites betises ou pe etre c moi :)
Mon problem c l'ouverture des fichiers .avi qui prend un temp fou , cad qd je lance la lecture , il faut attendre entre 3 a 4 minutes pour que la video se lance normalement .
Voila ce que m'affiche mplayer comme message :
AVI file format detected.
VIDEO:  [XVID]  640x368  16bpp  25,000 fps  971,2 kbps (118,5 kbyte/s)
Clip info:
 Software: Nandub v1.0rc2
Trying to force audio codec driver family libmad...
Opening audio decoder: [libmad] libmad mpeg audio decoder
AUDIO: 48000 Hz, 2 ch, 16 bit (0x10), ratio: 16000->192000 (128,0 kbit)
Selected audio codec: [mad] afm:libmad (libMAD MPEG layer 1-2-3)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Checking audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
AF_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
AF_pre: 48000Hz 2ch Signed 16-bit (Little-Endian)
AO: [oss] 48000Hz 2ch Signed 16-bit (Little-Endian) (2 bps)
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Starting playback...
VDec: vo config request - 640 x 368 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1,74:1 - prescaling to correct movie aspect.
VO: [xv] 640x368 => 640x368 Planar YV12
[ws] Error in display.
[ws]  Error code: 14 ( BadIDChoice (invalid resource ID chosen for this connection) )
[ws]  Request code: 1
[ws]  Minor code: 0
[ws]  Modules: sleep_usleep
[ws]  Error code: 13 ( BadGC (invalid GC parameter) )
[ws]  Request code: 70
[ws]  Minor code: 0
[ws]  Request code: 149
[ws]  Minor code: 1
[ws]  Modules: enable_cache
[ws]  Request code: 53
[ws]  Minor code: 0
a la fin je voi bien qu'il ya un problem mais je sais pas comment m'y prendre pour le regler.
Pour le vo j'ai tester X11 et xv mais ca change rien.
Je suis ouvert a tte proposition de votre part ;)
Message édité par brethold le 30-06-2004 à 15:14:02
n°512911
jc the gre​at
Posté le 30-06-2004 à 15:24:59  profilanswer
es tu sur que ton fichier AVI est lisible normalement par un autre player ?
"L'autodidacte, qui dans la vie, est parti de zéro pour n'arriver à rien dans l'existence, n'a de merci à dire à personne." (Pierre Dac)
n°512912
philou_a7
\_o< coin ! >o_/
Posté le 30-06-2004 à 15:27:10  profilanswer
tu as pu essayer d'autres valeurs de -vo ?
n°512923
brethold
Posté le 30-06-2004 à 15:39:45  profilanswer
oui il est lisible meme par mplayer mais il faut attendre qque minutes  qu'il charge qque chose , je vien d'essayer avec xine et la video marche nikel sauf que le son marche pas au debut et au bout de qque minutes le son vien tt seul .
Je crois donc que c'est un problem lieé au son avec les videos XVID.
Sinon j'ai essayer X11 et vo mais pas les autres car je sais pas vraiment a quoi ils cresepondent.
Message édité par brethold le 30-06-2004 à 15:40:29
n°512935
philou_a7
\_o< coin ! >o_/
Posté le 30-06-2004 à 15:48:04  profilanswer
essaie -vo null pour voir si tu as les memes messages d'erreur
tu n'auras pas d'affichage mais au moins tu verras si il trouve des erreurs dans le fichier ;)
n°512946
brethold
Posté le 30-06-2004 à 16:06:54  profilanswer
voila ce que j'ai avec -vo null:
VIDEO:  [XVID]  640x368  16bpp  25,00 fps  971,2 kbps (118,5 kbyte/s)
Clip info:
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
MP3lib: init layer2&3 finished, tables done
Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3)
This file was encoded with XviD build 9
VO: [null] 640x368 => 640x368 Planar YV12  [fs]
Je pense que mon problem est juste avec les xvid , est ce qu'il ya moyen de verifier si les codecs sont bien installes et faut il reinstaller mplayer en entier
Mici pour vos pistes les gars :)
Message édité par brethold le 30-06-2004 à 16:09:46
n°512953
codi
Posté le 30-06-2004 à 16:21:42  profilanswer
visiblement ce n'est pas un probleme de xvid puisque tu n'a plus d'erreurs
-vo null lit le fichier mais ne l'affiche pas
donc le probleme vient de l'affichage.
driver installe?
essaye :
-vo gl
-vo fbdev
tant qu'a faire enleve ce -ao oss
n°512956
philou_a7
\_o< coin ! >o_/
Posté le 30-06-2004 à 16:26:44  profilanswer
exactement, mplayer a des soucis pour l'affichage uniquement, pas pour la lecture, et il est plus que probable que reinstaller ne changera rien.
tu utilise quoi comme affichage ?
n°513059
brethold
Posté le 30-06-2004 à 18:15:31  profilanswer
oui mon driver nvidia est installé , d'ailleur avec les autres lecteurs integré de kde les .avi passent nikel c juste avec mplayer que ca decone.
Bon j'ai teste -vo gl ca donne la meme chose et avec -vi fbdev j'ai cette erreur:
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
FATAL: Could not initialize video filters (-vf) or video output (-vo).
Can't restore text mode: Argument invalide
Message édité par brethold le 30-06-2004 à 18:16:28
  Multimédia
Ouverture de fichierpartage de fichier sous linux?
[DEBIAN] comment lire un fichier sur un cdrom ?Imprimer une page internet dans un fichier PDF
transfert de fichier[resolu]echec de l'installation de mplayer via urpmi
[Resolu] Rediriger la console dans un fichier[DEBIAN] Copie de fichier
[résolu] prob de plantage avec mplayer[BASH][SCRIPT]lecture de plusieurs fichier en meme temps?
Plus de sujets relatifs à : Problem lecture fichier .avi avec mplayer
