5957 connectés
  Linux et OS Alternatifs
  Installation
  [Roundcube] les mails reçus ne s'affichent pas !
n°1389137
spider117
Posté le 09-04-2016 à 17:53:32  profilanswer
Salut ,
J'ai installé une webmail sur mon serveur dédié on lisant un tuto sur le net bref j'arrive a envoyé des mail a mon adresse de hotmail mais quand j'essaye de faire l'inverse et bien roundcube ne m'affiche pas le mail reçu !
Pouvez vous m'aider svp ?
Voila un aperçu de mon fichier mail.log :
Code :
  1. ession=<qtq4Hw8wPQAAAAAAAAAAAAAAAAAAAAAB>
  2. Apr  9 11:39:58 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=50 out=416
  3. Apr  9 11:40:01 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7449, secured, session=<rwfhHw8wDwAAAAAAAAAAAAAAAAAAAAAB>
  4. Apr  9 11:40:01 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=50 out=416
  5. Apr  9 11:40:02 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7451, secured, session=<Pfz2Hw8wXgAAAAAAAAAAAAAAAAAAAAAB>
  6. Apr  9 11:40:03 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=288 out=1275
  7. Apr  9 11:40:27 edenamourbis postfix/virtual[7452]: fatal: bad string length 0 < 1: virtual_mailbox_base =
  8. Apr  9 11:40:28 edenamourbis postfix/master[7368]: warning: process /usr/lib/postfix/virtual pid 7452 exit status 1
  9. Apr  9 11:40:28 edenamourbis postfix/master[7368]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
  10. Apr  9 11:40:52 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7454, secured, session=<DMX4Ig8wHQAAAAAAAAAAAAAAAAAAAAAB>
  11. Apr  9 11:40:53 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=153 out=921
  12. Apr  9 11:41:28 edenamourbis postfix/virtual[7460]: fatal: bad string length 0 < 1: virtual_mailbox_base =
  13. Apr  9 11:41:29 edenamourbis postfix/master[7368]: warning: process /usr/lib/postfix/virtual pid 7460 exit status 1
  14. Apr  9 11:41:29 edenamourbis postfix/master[7368]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
  15. Apr  9 11:41:52 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7462, secured, session=<GPyJJg8wPQAAAAAAAAAAAAAAAAAAAAAB>
  16. Apr  9 11:41:52 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=153 out=921
  17. Apr  9 11:42:29 edenamourbis postfix/virtual[7463]: fatal: bad string length 0 < 1: virtual_mailbox_base =
  18. Apr  9 11:42:30 edenamourbis postfix/master[7368]: warning: process /usr/lib/postfix/virtual pid 7463 exit status 1
  19. Apr  9 11:42:30 edenamourbis postfix/master[7368]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
  20. Apr  9 11:42:53 edenamourbis dovecot: auth-worker(7465): mysql(127.0.0.1): Connected to database postfixadmin
  21. Apr  9 11:42:53 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7467, secured, session=<uSwhKg8wgQAAAAAAAAAAAAAAAAAAAAAB>
  22. Apr  9 11:42:53 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=153 out=921
  23. Apr  9 11:43:30 edenamourbis postfix/virtual[7470]: fatal: bad string length 0 < 1: virtual_mailbox_base =
  24. Apr  9 11:43:31 edenamourbis postfix/master[7368]: warning: process /usr/lib/postfix/virtual pid 7470 exit status 1
  25. Apr  9 11:43:31 edenamourbis postfix/master[7368]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
  26. Apr  9 11:43:52 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=::1, lip=::1, mpid=7475, secured, session=<1gCzLQ8w+wAAAAAAAAAAAAAAAAAAAAAB>
  27. Apr  9 11:43:53 edenamourbis dovecot: imap(hostmaster@edenamour.com): Disconnected: Logged out in=153 out=921
  28. Apr  9 11:44:18 edenamourbis dovecot: imap-login: Login: user=<hostmaster@edenamour.com>, method=PLAIN, rip=154.121.4.222, lip=46.105.94.80, mpid=7478, TLS, session=<zLQ9Lw8wEQCaeQTe>
  29. Apr  9 11:44:31 edenamourbis postfix/virtual[7482]: fatal: bad string length 0 < 1: virtual_mailbox_base =
  30. Apr  9 11:44:32 edenamourbis postfix/master[7368]: warning: process /usr/lib/postfix/virtual pid 7482 exit status 1
  31. Apr  9 11:44:32 edenamourbis postfix/master[7368]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Cordialement.
Message édité par spider117 le 09-04-2016 à 21:16:39
n°1389513
Arcan_-
Posté le 18-04-2016 à 16:25:54  profilanswer
A première vue il s'agit plus d'un problème de configuration de Postfix :
http://www.postfix.org/postconf.5. [...] ilbox_base
Pouvez vous nous montrer la configuration de postfix (main et master) ?
Bon courage
  Installation
Ajout automatique d'un disclaimer dans tous mails sortant par PostfixDifférencier 2 adresses mails avec le même nom
[RESOLU] Crontab daemon m'envoi des mails de troppython comment afficher les emails d'un seul destinataire
Mettre à jour roundcube version 0.8 ou + sur Debian[Thunderbird] -NE PAS effacer les mails sur un serveur Hotmail (POP3)?
Restaurer une sauvegarde des mails de QMAILkmail ne fonctionne pas (pas de rapatriement mails) [Résolu]
[résolu] mails non reçus via roundcube imap
Plus de sujets relatifs à : [Roundcube] les mails reçus ne s'affichent pas !
