5847 connectés
  Linux et OS Alternatifs
  Installation
  [RESOLU] [GRUB] impossible de lancer grub
n°829763
mobyfab
The power of dreams.
Posté le 24-07-2006 à 22:45:42  profilanswer
bonjour  :hello:
j'ai acheté deux disques sata, et je les ai montés en raid0 via ma carte mere qui possede un chipset silicon image 3112...
j'en ai pas mal chié avec dmraid mais j'ai réussi à installer le systeme (dapper) !
le probleme c'est que grub ne se lance pas !
au boot j'ai le droit à un grub loading et apres ça bloque :cry:
fdisk -l /dev/mapper/sil_agahdcajcfff
Disk /dev/mapper/sil_agahdcajcfff: 320.0 GB, 320080609280 bytes
255 heads, 63 sectors/track, 38914 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
                       Device Boot      Start         End      Blocks   Id  System
/dev/mapper/sil_agahdcajcfff1   *           1       36364   292093798+   7  HPFS/NTFS
/dev/mapper/sil_agahdcajcfff2           36365       38806    19615365   83  Linux
/dev/mapper/sil_agahdcajcfff3           38807       38914      867510    5  Extended
/dev/mapper/sil_agahdcajcfff5           38807       38914      867478+  82  Linux swap / Solaris
voilà mon fichier menu.lst
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default         0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout         5
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title         Windows 95/98/NT/2000
# root          (hd0,0)
# makeactive
# chainloader   +1
# title         Linux
# root          (hd0,1)
# kernel        /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root= ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,1)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash vga=791
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## ## End Default Options ##
title           Ubuntu, kernel 2.6.15-23-386
root            (hd0,1)
kernel          /boot/vmlinuz-2.6.15-23-386 root=/dev/mapper/sil_agahdcajcfff2 ro quiet splash
initrd          /boot/initrd.img-2.6.15-23-386
savedefault
boot
title           Ubuntu, kernel 2.6.15-23-386 (recovery mode)
root            (hd0,1)
kernel          /boot/vmlinuz-2.6.15-23-386 root=/dev/mapper/sil_agahdcajcfff2 ro single
boot
title           Ubuntu, memtest86+
root            (hd0,1)
kernel          /boot/memtest86+.bin
boot
title           Windows XP
rootnoverify    (hd0,0)
chainloader     +1
### END DEBIAN AUTOMAGIC KERNELS LIST
j'ai installé grub sur le mbr avec un setup (hd0), le root sur (hd0,1) et device (hd0) /dev/mapper/sil_agahdcajcfff
l'install n'a pas posé de problemes...
j'ai essayé de changer de groot en mettant hd0,0 mais ça change rien ... (en meme temps c'etait une tentative déséspérée lol)
voilà en esperant que vous trouviez le probleme  :sweat:
Message édité par mobyfab le 25-07-2006 à 04:21:12
n°829764
mirtouf
Light is right !
Posté le 24-07-2006 à 22:50:19  profilanswer
n°829767
mobyfab
Posté le 24-07-2006 à 23:03:47  profilanswer
aparement vas faloir que je fasse une partoche /boot  :sweat:
grub> root (hd0,1)
Error 18: Selected cylinder exceeds maximum supported by BIOS
n°829768
mirtouf
Light is right !
Posté le 24-07-2006 à 23:06:28  profilanswer
effectivement il est plus que recommandé de mettre /boot à part en cas de RAID.
n°829769
mobyfab
Posté le 24-07-2006 à 23:08:01  profilanswer
oui je viens de lire qu'il faut le metre au tout début du disque...
bon ben au boulot  :sweat:
n°829787
mobyfab
Posté le 25-07-2006 à 04:20:53  profilanswer
bon j'ai fini par y arriver mais j'en ai chié un max  :fou:
merci mirtouf  :jap:
  Installation
[résolu pour les générations futures] Xinerama cassé[résolu]émuler fichier .msi avec wine...
[résolu] Probleme avec mrtgSauvegarde de données d'un portable GRUB
[PB résolu] mandriva ne se lance pas (à cause de CUPS?)debian impossible d'installer de nouveaux paquets
[resolu] sftp[Résolu] Postfix+postfixadmin+mysql problème d'authentification
résolu [procmail] /etc/procmailrc & recettes qui ne fonctionne pas[Resolu] Ne reboot pas apres un "reboot"
Plus de sujets relatifs à : [RESOLU] [GRUB] impossible de lancer grub
