11294 connectés
  Linux et OS Alternatifs
  Installation
  Des pros du kernel et de l'usb, j'en ai besoin
n°319118
Captain Fl​am
Le Web ouvre l'esprit...
Posté le 03-09-2003 à 19:15:36  profilanswer
Pourquoi mon modem adsl usb speedtouch ne s'allume pas avec un noyau recompilé sous la Slackware 9.0 (2.4.22) alors qu'avec le natif 2.4.20 de la distribution il n'y a pas de problème ???
Pour info :
un lsmod sous le 2.4.20 où la connexion marche :
Module                  Size  Used by    Tainted: P
parport_pc             14724   1 (autoclean)
lp                      6752   0 (autoclean)
parport                23264   1 (autoclean) [parport_pc lp]
emu10k1                61288   0 (unused)
ac97_codec              9512   0 [emu10k1]
soundcore               3332   4 [emu10k1]
emu10k1-gp              1352   0 (unused)
gameport                1452   0 [emu10k1-gp]
nvidia               1628288   0 (unused)
ide-scsi                8048   0
evdev                   4416   0 (unused)
scanner                 9304   0 (unused)
acm                     5856   0 (unused)
keybdev                 1952   0 (unused)
mousedev                4212   0 (unused)
hid                    18596   0 (unused)
input                   3200   0 [evdev keybdev mousedev hid]
usb-ohci               18856   0 (unused)
usbcore                58144   1 [scanner acm hid usb-ohci]
ppp_deflate             3256   0 (unused)
zlib_deflate           18200   0 [ppp_deflate]
bsd_comp                4312   0 (unused)
ppp_synctty             6016   0 (unused)
n_hdlc                  6304   0 (unused)
ppp_async               7520   0 (unused)
ppp_generic            15452   0 [ppp_deflate bsd_comp ppp_synctty ppp_async]
slhc                    5040   0 [ppp_generic]
nls_iso8859-15          3356   1 (autoclean)
nls_cp850               3580   1 (autoclean)
et un lsmod sous le 2.4.22 où les leds sont éteintes :
Module                  Size  Used by    Not tainted
parport_pc             13508   1  (autoclean)
lp                      6240   0  (autoclean)
parport                14336   1  (autoclean) [parport_pc lp]
ide-scsi               10192   0
evdev                   4640   0  (unused)
input                   3424   0  [evdev]
scanner                10616   0  (unused)
acm                     6272   0  (unused)
usb-ohci               19016   0  (unused)
usbcore                62816   1  [scanner acm usb-ohci]
ppp_deflate             3448   0  (unused)
zlib_inflate           18660   0  [ppp_deflate]
zlib_deflate           18104   0  [ppp_deflate]
bsd_comp                4344   0  (unused)
ppp_synctty             6304   0  (unused)
n_hdlc                  6752   0  (unused)
ppp_async               7680   0  (unused)
ppp_generic            16188   0  [ppp_deflate bsd_comp ppp_synctty ppp_async]
slhc                    5440   0  [ppp_generic]
nls_iso8859-15          3388   1  (autoclean)
nls_cp850               3612   1  (autoclean)
vfat                   10636   1  (autoclean)
fat                    32408   0  (autoclean) [vfat]
J'ai bien compilé les modules, il voit les ports usb au boot puis rien ne s'allume ???
J'ai besoin d'aide. MERCI
n°319167
Captain Fl​am
Posté le 03-09-2003 à 21:09:30  profilanswer
Eh ben...
n°319192
mirtouf
Light is right !
Posté le 03-09-2003 à 21:47:04  profilanswer
Je dirais bien que le noyau de la Slack est patché....
mais comme je ne suis pas un pro de la Slack je ne m'avancerai pas plus :o
n°319198
BMOTheKill​er
Posté le 03-09-2003 à 21:53:15  profilanswer
y a pas une feature speedtouch dans le noyau 2.4.22 ? dans character devices je crois...
n°319212
Captain Fl​am
Posté le 03-09-2003 à 22:08:06  profilanswer
Si mais ça sert à rien, je l'ai mis en module au cas où mais j'utilise les drivers de B. Papillault pour me connecter. C'est nickel. Mais le problème, c'est que dès que je recompile un kernel différent de Slack ou de kernel.org, mon bus usb ne voit plus aucun périphérique (scanner, speedtouch etc...) cat /proc/bus/usb/devices ne me montre rien. Pourtant j'ai la prise en charge de l'usb dans le kernel.
Si je tape mount -t usbdevfs none /proc/bus/usb, il me dit que c'est déja monté!!! Mon modem reste éteint... Qu'est-ce que j'ai oublié ??????
n°319215
- Fred -
007 Agent
Posté le 03-09-2003 à 22:12:34  profilanswer
Tu es sûr d'avoir compilé usbdevfs ? As-tu essayé de récupérer le .config de la Slack ?
Message édité par - Fred - le 03-09-2003 à 22:13:05
"You know the name, You know the number..."
n°319235
Captain Fl​am
Posté le 03-09-2003 à 22:22:36  profilanswer
J'ai bien récupéré le config de la Slack, et j'ai désactivé plein d'options qui me servent à rien. Aurais-je désactivé usbdevfs? Il se trouve où? Dans files system?
n°319240
Captain Fl​am
Posté le 03-09-2003 à 22:28:45  profilanswer
preliminary usb device filesystem est en Y dans mon kernel...
n°319247
mirtouf
Light is right !
Posté le 03-09-2003 à 22:33:01  profilanswer
Dans ton /etc/fstab y'a cette ligne ?
none   /proc/bus/usb usbdevfs defaults  0 0
n°319251
Captain Fl​am
Posté le 03-09-2003 à 22:38:10  profilanswer
non, elle n'y est pas mais ça n'empêche pas le 2.4.20 de charger les périphériques usb. J'y crois pas trop mais je vais rebooter.
n°319253
mirtouf
Light is right !
Posté le 03-09-2003 à 22:40:46  profilanswer
C'est un noyau à la vanille ou il a été patché ?
n°319256
Captain Fl​am
Posté le 03-09-2003 à 22:45:03  profilanswer
c'est un noyau 2.4.22 de kernel.org patché avec les lm_sensors.
Il tourne bien sauf l'usb. Je crois cependant avoir entendu que usbdevfs avait été remplacé par usbfs sous Slack. Notamment j'ai une ligne  :
usbfs /proc/bus/usb usbfs rw 0 0 dans mtab !
Qu'est ce que vous en pensez?
n°319260
mirtouf
Light is right !
Posté le 03-09-2003 à 22:53:03  profilanswer
Essaye avec usbfs alors.
n°319261
Captain Fl​am
Posté le 03-09-2003 à 22:59:16  profilanswer
Avec usbfs dans fstab ça ne marche pas. Je vais réessayer avec usbdevfs...
n°319379
Captain Fl​am
Posté le 04-09-2003 à 08:58:55  profilanswer
ça marche pas non plus :(:(:(
n°319532
Captain Fl​am
Posté le 04-09-2003 à 14:44:53  profilanswer
J'ai pas enlevé les headers du kernel qui fonctionne... Est-ce que mon Pb peut venir de là???
  Installation
usbcore et kernel[Kernel] Compilation auto de modules additionnels
Besoin d'aide pour Wine et DVDProfilerKDE + Ajout d application dans les menus !! Besoin de vous
[ mandrake 9.1 ] Pb bizarre après compilation kernelpb kernel 2.6.0-test4 et modules .o ???
kernel panic unable to mount root fsA tous les pros d IE6 et de FTP
Besoin d'aide pour faire fonctionner Alsa avec une AWE64Powerbook ppc oldworld bootx et compile kernel
Plus de sujets relatifs à : Des pros du kernel et de l'usb, j'en ai besoin
