4080 connectés
  Linux et OS Alternatifs
  Installation
  Proftpd - Comment ca marche
n°594423
cortx
Posté le 22-11-2004 à 14:34:06  profilanswer
Bonjours voila je viens d'installer proftpd sur mon nux (redhat9)
rpm -ivh proftpd*
Ensuite je vasi pour le configurer:
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName   "CortX's FTP server"
ServerType standalone
DefaultServer   on
# Port 21 is the standard FTP port.
Port    21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask    022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances   30
# Set the user and group under which the server will run.
User    nobody
Group    nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
#DefaultRoot ~
# Normally, we want files to be overwriteable.
AllowOverwrite  on
# Bar use of SITE CHMOD by default
<Limit SITE_CHMOD>
  DenyAll
</Limit>
# A basic anonymous configuration, no upload directories.  If you do not
# want anonymous users, simply delete this entire <Anonymous> section.
<Anonymous ~ftp>
  User    ftp
  Group    ftp
  # We want clients to be able to login with "anonymous" as well as "ftp"
  UserAlias   anonymous ftp
  # Limit the maximum number of anonymous logins
  MaxClients   10
  # We want 'welcome.msg' displayed at login, and '.message' displayed
  # in each newly chdired directory.
  DisplayLogin   welcome.msg
  DisplayFirstChdir  .message
  # Limit WRITE everywhere in the anonymous chroot
  <Limit WRITE>
    DenyAll
  </Limit>
</Anonymous>
J'y ai donc modifier servername, le reste des option me convenait pour un debut.
Seulement voila, j'ai desormais un gros souci.
Ou configure t'on les dossier accessible.
J'ai suivi le tuto sur lea-linux
Et il aprle de section global etc masi moi je n'ai rien dans mon fichier de conf.
Quelqu'un pourrait t'il me donner un tuto ou carrement poster son fichier de conf pour me permettre de configurer mes partage car tout les tuto que j'ai trouver n'en parle pas :'(.
Merci a vous
n°594426
black_lord
Truth speaks from peacefulness
Posté le 22-11-2004 à 14:37:26  profilanswer
/var/ftp si je me souviens bien
n°594438
cortx
Posté le 22-11-2004 à 14:42:21  profilanswer
J'ai aucun dossier ftp dans /var
j'ai un /var/run/proftpd mais il ne contient que  proftpd.scoreboard
et dans /var/www comme pour apache ya rien non plus
Message édité par cortx le 22-11-2004 à 14:47:41
n°594442
KIKAduKANA
Le JungleCore, ça pootre!!
Posté le 22-11-2004 à 14:46:34  profilanswer
comment qu'on fait pour restreindre l'accés au repertoire de l'utilisateur loggué afin qu'il ne puisse pas se balader en dehors du ledit repertoire?
n°594448
black_lord
Posté le 22-11-2004 à 14:48:58  profilanswer
DefaultRoot ~
(ou le chemin que tu veux)
Message édité par black_lord le 22-11-2004 à 14:49:22
n°594451
KIKAduKANA
Posté le 22-11-2004 à 14:50:22  profilanswer
ca pète, je teste ca ;)
edit : :jap: a black_lord
Message édité par KIKAduKANA le 22-11-2004 à 14:54:06
n°594452
cortx
Posté le 22-11-2004 à 14:50:38  profilanswer
Si j'ai bien compris ta question:
La reponse est la: http://lea-linux.org/pho/read.php?5,177231
EDIT: too late
Message édité par cortx le 22-11-2004 à 14:50:59
n°594453
black_lord
Posté le 22-11-2004 à 14:51:23  profilanswer
yeah [:franck75]
n°594463
KIKAduKANA
Posté le 22-11-2004 à 15:02:29  profilanswer
est-ce que c'est possible de limiter la bande passante du ftp avec proftp?
n°594474
cortx
Posté le 22-11-2004 à 15:20:01  profilanswer
ouai aussi, meme lien que en haut, le site de lealinux en parle je crois que j'ai vu ca ce matin en cherchant mes infos.
apropos petit up du rpemier post, ou configurer els acces utilisateur
KIKAduKANA tu as du reussi r a le faire au point ou tu en est,...
n°594483
KIKAduKANA
Posté le 22-11-2004 à 15:51:26  profilanswer
vui vui, mon ftp marche bien ( 64ko/s d'up, merci Free )
y'a plusieurs comptes
par contre c'est dla configuration trés basique, et surement pas secure ^^
faut que je cherche comment faire pour avoir 2 types de configuration possible :
- compte ftp avec login et pwd
et
- comte ftp en anonymous par défaut ( ftp://mon.ip/ tombe direct dedans )
spossible de faire les 2 avec proftpd?
gooooooooooooooooooooooooogle? t là? :D
Message édité par KIKAduKANA le 22-11-2004 à 15:52:32
n°594781
cortx
Posté le 23-11-2004 à 09:25:26  profilanswer
Ouai mais comment tu configure les dossier de chacun, je n'ai rien dans mon fichier de conf me donnat des renseignement.
Et tout les tuto sur le net en parle aps.
Ilparle de sction global etc et moi je ne l'ai pas cette section.
n°594783
tigrou lib​re
Posté le 23-11-2004 à 09:27:58  profilanswer
DefaultRoot ~
le '~' indique le home de chacun!
n°594908
goldyfruit
Je me lève et je confirme !
Posté le 23-11-2004 à 14:07:34  profilanswer
Moi j'utilise une interface pour configurer proftpd.
http://mange.dynup.net/linux.html
n°594914
cortx
Posté le 23-11-2004 à 14:13:15  profilanswer
k merci je regarde ca et je vous tiens au courant.
n°594921
cortx
Posté le 23-11-2004 à 14:28:08  profilanswer
goldyfruit: c'ets du graphique :/
Je suis sur un portable qui n'accepte pas le mode graphique, j'arrive pas a lui installer.
http://forum.hardware.fr/forum2.ph [...] 0&subcat=0
Si tu as le mem en console, je prend.
n°595136
dam1330
Posté le 23-11-2004 à 19:59:20  profilanswer
comment tu fais pour le lancer ?? il fau etre root, et ca ne se lance pas aveec alt+f2 sous kde ++  root et mdp
n°595142
goldyfruit
Posté le 23-11-2004 à 20:04:12  profilanswer
je le lance dans une console en root
n°595149
dam1330
Posté le 23-11-2004 à 20:09:27  profilanswer
fo faire de l'export display alors ? c'est koi la commande ?
porttable:/home/damien/gproftpd-8.1.7# gpro
gprof      gproftpd   gprostats
porttable:/home/damien/gproftpd-8.1.7# gproftpd
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
(gproftpd:7371): Gtk-WARNING **: cannot open display:
n°595206
goldyfruit
Posté le 23-11-2004 à 21:27:36  profilanswer
ba chez moi j'ai fais un
Code :
  1. dpkg -i gproftpd.xxxx.deb
ensuite j'ai fais un
Code :
  1. apt-get install -f
parceque il manquait des dépendances et aprés j'ai lancé une console en root et j'ai tapé gproftpd c'est tout. :/
n°595243
dam1330
Posté le 23-11-2004 à 22:53:52  profilanswer
moi l'install ne pose pas de probleme, mais je ne   peux pas l'executer
n°595271
lenainquit​ue
Posté le 23-11-2004 à 23:48:18  profilanswer
je viens de l'installer et ça fonctionne très bien. Je le lance en root depuis une console.
Bon je n'ai pas regardé encore la configuration du serveur, car il est tard, mais ça m'a l'air sympa.
n°595278
dam1330
Posté le 24-11-2004 à 00:05:58  profilanswer
se connecter en root graphique c'est le mal, d'ailleurs je ne peux plus le faire. a la fois avec kdm et gdm je ne peux plus logguer en root
message "le super user ne peut se connecter en graphique ..."
je suis en debian sid, jai essayé de modifier les options de kdm, mais rien n'y fait.
alors si quelqu'un sait comment on fait de l'export display (il me semble que ca soit ca). je me loguge avec mon user, su dans une console.
n°595311
lenainquit​ue
Posté le 24-11-2004 à 08:54:07  profilanswer
J'ai jamais dit que j'avais fait ça ...  :ange: Je me suis loggué en root via la console, j'ai fait un Su quoi, voilà et j'ai lancé cette interface.
n°595360
dam1330
Posté le 24-11-2004 à 12:38:57  profilanswer
donc comme moi, mais ca ne marche pas ca me met l'erreur que j'ai donné ds un post plus haut
  Installation
smb://192.168.0.2 ne marche plus dans konqueror[Gentoo] emerge -f world & emerge world qui ne marche pas
FTP, comment ça marche?Proftpd -> connexion et changement de rep très lent
[ipCop] Config pour Serveur FTP marche pas ...[mdk 10] echec activation eth0, mais service network restart marche
proftpd et limitation d'ULmsn ne marche pas..
proftpd, ca marche nickel (trop meme....)desinstaller proftpd make uninstall marche po
Plus de sujets relatifs à : Proftpd - Comment ca marche
