4034 connectés
  Linux et OS Alternatifs
  Installation
  Plus de clavier avec l'hyper threading
n°644788
dr-freuder​ick
Asymétrie Cognitive.
Posté le 04-03-2005 à 12:08:23  profilanswer
Bonjour !
quand je compile mon noyau 2.6 ou meme si je prend les binaire de la sid en smp, je n'ai plus de clavier au demarrage !
Quelqu'un a une idée ?
frederick
était
Quand je comprile mon noyau avec le support du ht, l'installation des modules finit par ça
if [ -r System.map ]; then /sbin/depmod -ae -F System.map  2.6.11; fi
WARNING: /lib/modules/2.6.11/kernel/drivers/char/istallion.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/istallion.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/istallion.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/moxa.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/moxa.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/moxa.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/generic_serial.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/generic_serial.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/generic_serial.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/generic_serial.ko needs unknown symbol sti
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ip2main.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ip2main.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ip2main.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/epca.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/epca.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/epca.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/stallion.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11/kernel/drivers/char/stallion.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/stallion.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol sti
WARNING: /lib/modules/2.6.11/kernel/drivers/char/rio/rio.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11/kernel/drivers/char/rio/rio.ko needs unknown symbol save_flags
et quand je tente de le demarrer tout se passe bien mais pas de clavier !
quelqu'un a une idée ?
Message édité par dr-freuderick le 09-03-2005 à 19:16:15
n°644826
arghbis
salops de dauphins
Posté le 04-03-2005 à 12:41:59  profilanswer
chezmoisçamarche (2.6.11-ck1)
t'as mis des patchs ou pas?
n°644833
dr-freuder​ick
Posté le 04-03-2005 à 12:46:23  profilanswer
nein pas ck1 :)
(je reessaye)
Message édité par dr-freuderick le 04-03-2005 à 12:49:38
n°644845
dr-freuder​ick
Posté le 04-03-2005 à 13:25:11  profilanswer
Pareille
if [ -r System.map ]; then /sbin/depmod -ae -F System.map  2.6.11-ck1; fi
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/istallion.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/istallion.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/istallion.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/moxa.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/moxa.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/moxa.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/generic_serial.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/generic_serial.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/generic_serial.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/generic_serial.ko needs unknown symbol sti
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ip2main.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ip2main.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ip2main.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/epca.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/epca.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/epca.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/stallion.ko needs unknown symbol cli
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/stallion.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/stallion.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol save_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/ftape/lowlevel/ftape.ko needs unknown symbol sti
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/rio/rio.ko needs unknown symbol restore_flags
WARNING: /lib/modules/2.6.11-ck1/kernel/drivers/char/rio/rio.ko needs unknown symbol save_flags
n°644846
arghbis
salops de dauphins
Posté le 04-03-2005 à 13:27:26  profilanswer
ton .config est correct? si tu l'as récupéré d'un 2.6.10, tu as fait le make oldconfig?
n°644848
dr-freuder​ick
Posté le 04-03-2005 à 13:31:58  profilanswer
j'avais fait un export d'une config debian
et import sur celui la .
c'est ça tu crois ?
n°644852
arghbis
salops de dauphins
Posté le 04-03-2005 à 13:35:42  profilanswer
quand tu importes un .config d'une autre version, faut toujours faire un make oldconfig pour voir les choses qui changent
mais ça résoudra p'tet pas le pb (probablement pas d'ailleurs)
les utilitaires noyau sont à jour?
n°644858
dr-freuder​ick
Posté le 04-03-2005 à 13:44:47  profilanswer
J'ai pris le config du noyau debian or la c'est un noyau du site patché ck1
Il faudrais que j'efface la config (comment ?) et que je recommence manuellement ??
Utilitaire du noyau sont a jour debian sid updaté ce matin
Message édité par dr-freuderick le 04-03-2005 à 13:44:56
n°644859
dr-freuder​ick
Posté le 04-03-2005 à 13:47:18  profilanswer
A noté qu'a l'operation MODPOST du make j'ai déja
  GZIP    arch/i386/boot/compressed/vmlinux.bin.gz
  LD      arch/i386/boot/compressed/piggy.o
  LD      arch/i386/boot/compressed/vmlinux
  LD      arch/i386/boot/setup
  OBJCOPY arch/i386/boot/vmlinux.bin
  BUILD   arch/i386/boot/bzImage
Root device is (8, 17)
Boot sector 512 bytes.
Setup is 5471 bytes.
System is 1262 kB
Kernel: arch/i386/boot/bzImage is ready
  MODPOST
*** Warning: "restore_flags" [drivers/char/stallion.ko] undefined!
*** Warning: "cli" [drivers/char/stallion.ko] undefined!
*** Warning: "save_flags" [drivers/char/stallion.ko] undefined!
*** Warning: "save_flags" [drivers/char/rio/rio.ko] undefined!
*** Warning: "restore_flags" [drivers/char/rio/rio.ko] undefined!
*** Warning: "restore_flags" [drivers/char/moxa.ko] undefined!
*** Warning: "cli" [drivers/char/moxa.ko] undefined!
*** Warning: "save_flags" [drivers/char/moxa.ko] undefined!
*** Warning: "restore_flags" [drivers/char/istallion.ko] undefined!
*** Warning: "cli" [drivers/char/istallion.ko] undefined!
*** Warning: "save_flags" [drivers/char/istallion.ko] undefined!
*** Warning: "save_flags" [drivers/char/ip2main.ko] undefined!
*** Warning: "restore_flags" [drivers/char/ip2main.ko] undefined!
*** Warning: "cli" [drivers/char/ip2main.ko] undefined!
*** Warning: "sti" [drivers/char/generic_serial.ko] undefined!
*** Warning: "save_flags" [drivers/char/generic_serial.ko] undefined!
*** Warning: "restore_flags" [drivers/char/generic_serial.ko] undefined!
*** Warning: "cli" [drivers/char/generic_serial.ko] undefined!
*** Warning: "sti" [drivers/char/ftape/lowlevel/ftape.ko] undefined!
*** Warning: "save_flags" [drivers/char/ftape/lowlevel/ftape.ko] undefined!
*** Warning: "restore_flags" [drivers/char/ftape/lowlevel/ftape.ko] undefined!
*** Warning: "restore_flags" [drivers/char/epca.ko] undefined!
*** Warning: "cli" [drivers/char/epca.ko] undefined!
*** Warning: "save_flags" [drivers/char/epca.ko] undefined!
n°645004
arghbis
salops de dauphins
Posté le 04-03-2005 à 17:49:42  profilanswer
bon, pour tes warnings, je sais pas. si t'utilises pas ces drivers, ça posera aucun problème.
pour ce qui est du clavier, le drivers adéquat est en module sous debian, donc si tu fais pas de initrd ou que tu le mets pas en dur, ben pas de clavier...
n°645127
dr-freuder​ick
Posté le 04-03-2005 à 22:55:15  profilanswer
n°647484
dr-freuder​ick
Posté le 09-03-2005 à 19:16:24  profilanswer
Mise a jour
  Installation
[less] se deplacer avec les flèches du clavierPlus de clavier sous KDE (3.4 beta)
Freesbie Mettre clavier frproblème souris ou clavier sous xorg
Probleme de clavier suisse[Auto-Résolu]clavier en chinois
problème à l'installation : clavier !??controler un modem rtc avec le clavier
pas de clavier ni de sourisRedirection des I/O et lecture du clavier
Plus de sujets relatifs à : Plus de clavier avec l'hyper threading
