3390 connectés
  Linux et OS Alternatifs
  Installation
  perl Makefile.PL
perl Makefile.PL
n°408794
burgergold
5$? va chez l'diable!
Posté le 13-02-2004 à 14:26:01  profilanswer
Je tente d'installer la librairie perl DCE-Perl-0.21 mais j'obtiens l'erreur suivante lorsque je tente de faire mon perl Makefile.PL
Perl 5.8.2
j'ai tenté avec une vieille version de perl (5.005_03) et je n'ai pas l'erreur.
Le tout sur AIX 4.3.3
yaberge2@info1 ==> /perl5/usr/local/bin/perl Makefile.PL
WARNING: TYPEMAPS takes a array reference not a string/number.
         Please inform the author.
Can't use string ("../typemap" ) as an ARRAY ref while "strict refs" in use at /usr/local/lib/perl5/5.8.2/ExtUtils/MM_Unix.pm line 3958.
yaberge2@info1 ==> cat Makefile.PL
use ExtUtils::MakeMaker;
WriteMakefile (
     TYPEMAPS => '../typemap',
     NAME => "DCE::ACL",
     VERSION_FROM => "ACL.pm",
yaberge2@info1 ==> cat ../typemap
perlrpcsub              T_PV
DCE::Registry           T_PTROBJ
DCE::Registry::era      T_PTROBJ
DCE::cursor             T_PTROBJ
DCE::RegistryCursor     T_PTROBJ
DCE::Login              T_PTROBJ
DCE::UUID               T_PTROBJ
DCE::RPC                T_PTROBJ
DCE::login_name         T_PTROBJ
uuid_t                  T_PTR
uuid_t *                T_PTR
handle_t                T_PTROBJ
rpc_auth_identity_handle_t      T_PTR
rpc_if_handle_t         T_PTROBJ
rpc_ns_handle_t         T_PTROBJ
rpc_ns_handle_t *       T_PTR
unsigned_char_p_t       T_PV
unsigned_char_p_t *     T_PV
sec_login_flags_t       T_IV
boolean32               T_IV
sec_login_handle_t *    T_PTROBJ
sec_login_handle_t      T_PTR
sec_passwd_rec_t *      T_PTR
boolean32 *             T_PV
sec_login_auth_src_t    T_IV
error_status_t *        T_PV
error_status_t          T_IV
signed32                T_IV
unsigned32              T_IV
sec_rgy_bind_auth_info_type_t   T_IV
sec_rgy_handle_t        T_PTR
sec_rgy_login_name_t *  T_PTR
unsigned_char_t         T_U_CHAR
unsigned_char_t *       T_PV
sec_rgy_domain_t        T_IV
sec_rgy_pgo_flags_t     T_IV
sec_rgy_pname_t         T_PV
unsigned16              T_IV
sec_rgy_name_t          T_PV
sec_passwd_type_t       T_IV
sec_passwd_version_t    T_IV
sec_rgy_acct_key_t      T_IV
sec_rgy_acct_user_flags_t       T_IV
sec_rgy_acct_admin_flags_t      T_IV
sec_rgy_acct_auth_flags_t       T_IV
sec_timeval_sec_t       T_IV
sec_timeval_period_t    T_IV
sec_rgy_plcy_pwd_flags_t        T_IV
si quelqu'un a une idée à me suggérer
  Installation
  perl Makefile.PL
DEBIAN : startx introuvable et PERL déconfigurédroits pr un utilisateur d'utiliser la commande "perl" et "newusers"
[KDevelop] A propos du makefile ..."depmod : ...Makefile is not an ELF file" ca veut dire koi ? pliz help
script perl pour irssi[newbie] comment lancer un fichier sh ou perl depuis Konqueror ?
installation module perl pr apache... marche poaNCPAN-perl ..... mouai
Modifier le path de lib pour perlCompiler perl dans un autre arborescence
Plus de sujets relatifs à : perl Makefile.PL
