3093 connectés
  Linux et OS Alternatifs
  Installation
  [MPlayer] J'ai beau chercher sans comprendre :(
n°269654
agent007se
<=@_|_@=>
Posté le 28-05-2003 à 22:48:40  profilanswer
ve_divx4.c:190: request for member `framerate' in something not a structure or union
ve_divx4.c:192: request for member `quality' in something not a structure or union
ve_divx4.c: In function `put_image':
ve_divx4.c:235: structure has no member named `mvs'
ve_divx4.c:240: structure has no member named `quant'
ve_divx4.c:241: structure has no member named `intra'
ve_divx4.c:248: `ENC_OPT_ENCODE_VBR' undeclared (first use in this function)
ve_divx4.c:249: structure has no member named `quantizer'
ve_divx4.c:251: structure has no member named `is_key_frame'
ve_divx4.c:253: structure has no member named `quantizer'
ve_divx4.c:253: structure has no member named `is_key_frame'
ve_divx4.c:254: structure has no member named `total_bits'
ve_divx4.c:254: structure has no member named `texture_bits'
ve_divx4.c:261: structure has no member named `quant'
ve_divx4.c:262: structure has no member named `intra'
ve_divx4.c:264: structure has no member named `motion_bits'
ve_divx4.c:265: structure has no member named `texture_bits'
ve_divx4.c:266: structure has no member named `total_bits'
ve_divx4.c:268: structure has no member named `quant'
ve_divx4.c:269: structure has no member named `intra'
ve_divx4.c:272: structure has no member named `is_key_frame'
ve_divx4.c:273: structure has no member named `motion_bits'
ve_divx4.c:274: structure has no member named `texture_bits'
ve_divx4.c:275: structure has no member named `total_bits'
ve_divx4.c:276: structure has no member named `quantizer'
ve_divx4.c:279: structure has no member named `is_key_frame'
make[1]: *** [ve_divx4.o] Erreur 1
make[1]: Leaving directory `/home/djkarim007/Desktop/MPlayer-0.90/libmpcodecs'
make: *** [libmpcodecs/libmpcodecs.a] Erreur 2
voila quand je fais make (apres avoir faire ./configure --enable-gui)  :ouch:
n°269667
HuGoBioS
Posté le 28-05-2003 à 23:02:13  profilanswer
heu ... un pb de codecs dirait on
n°269671
agent007se
<=@_|_@=>
Posté le 28-05-2003 à 23:11:08  profilanswer
tu te souviens de moi ? ;) heu le divx_4 donc ? j'le supprime comment ? (y'a xvid de tt les facons)
n°269975
Le Ouinhin​ Pervers
Posté le 29-05-2003 à 14:32:55  profilanswer
Configure avec ca:
./configure --disable-divx4linux --machin --machin2 --etc
n°270064
Je@nb
Kindly give dime
Posté le 29-05-2003 à 16:24:55  profilanswer
J'aurais dit plutot un probl de header. Il manquerait une lib :( enfin c mon avis :p
  Installation
rv9 / (g)mplayer / gentooKnopix 3.2 MIB (j'insiste sur le MIB) : c bon c beau, à choper d'urge
mplayer sur PPCmplayer
Rendre LILO plus beau ?mplayer et -vop pp
mplayer et dvd interlacéQuestion mplayer
[mplayer]Il ne lit que certains dvd (résolu)Chercher des fichiers sur le web grace aux extension??
Plus de sujets relatifs à : [MPlayer] J'ai beau chercher sans comprendre :(
