7554 connectés
 Page :   1  2
Page Suivante
[MDK 9.1] L'interface graphique ne se lance pas
n°320697
Dark_Schne​ider
Close the World, Open the Net
Posté le 06-09-2003 à 19:39:44  profilanswer
Code :
  1. # File generated by XFdrake.
  2. # **********************************************************************
  3. # Refer to the XF86Config man page for details about the format of
  4. # this file.
  5. # **********************************************************************
  6. Section "Files"
  7.     # Multiple FontPath entries are allowed (they are concatenated together)
  8.     # By default, Mandrake 6.0 and later now use a font server independent of
  9.     # the X server to render fonts.
  10.     FontPath "unix/:-1"
  11. EndSection
  12. Section "ServerFlags"
  13.     #DontZap # disable <Crtl><Alt><BS> (server abort)
  14.     AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
  15.     #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
  16. EndSection
  17. Section "Module"
  18.     Load "dbe" # Double-Buffering Extension
  19.     Load "v4l" # Video for Linux
  20.     Load "extmod"
  21.     Load "type1"
  22.     Load "freetype"
  23.     Load "glx" # 3D layer
  24. EndSection
  25. Section "InputDevice"
  26.     Identifier "Keyboard1"
  27.     Driver "Keyboard"
  28.     Option "XkbModel" "pc105"
  29.     Option "XkbLayout" "fr"
  30.     Option "XkbCompat" ""
  31.     Option "XkbOptions" ""
  32. EndSection
  33. Section "InputDevice"
  34.     Identifier "Mouse1"
  35.     Driver "mouse"
  36.     Option "Protocol" "IMPS/2"
  37.     Option "Device" "/dev/psaux"
  38.     Option "ZAxisMapping" "4 5"
  39. EndSection
  40. Section "Monitor"
  41.     Identifier "monitor1"
  42.     VendorName "Generic"
  43.     ModelName "640x480 @ 60 Hz"
  44.     HorizSync 31.5
  45.     VertRefresh 50-61
  46.
  47.     # Sony Vaio C1(X,XS,VE,VN)?
  48.     # 1024x480 @ 85.6 Hz, 48 kHz hsync
  49.     ModeLine "1024x480"    65.00 1024 1032 1176 1344   480  488  494  563 -hsync -vsync
  50.
  51.     # TV fullscreen mode or DVD fullscreen output.
  52.     # 768x576 @ 79 Hz, 50 kHz hsync
  53.     ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
  54.
  55.     # 768x576 @ 100 Hz, 61.6 kHz hsync
  56.     ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
  57. EndSection
  58. Section "Device"
  59.     Identifier "device1"
  60.     VendorName "ATI"
  61.     BoardName "ATI Mach64 Utah"
  62.     Driver "ati"
  63.     Option "DPMS"
  64. EndSection
  65. Section "Screen"
  66.     Identifier "screen1"
  67.     Device "device1"
  68.     Monitor "monitor1"
  69.     DefaultColorDepth 16
  70.
  71.     Subsection "Display"
  72.         Depth 8
  73.         Modes "640x480"
  74.     EndSubsection
  75.
  76.     Subsection "Display"
  77.         Depth 15
  78.         Modes "640x480"
  79.     EndSubsection
  80.
  81.     Subsection "Display"
  82.         Depth 16
  83.         Modes "640x480"
  84.     EndSubsection
  85.
  86.     Subsection "Display"
  87.         Depth 24
  88.         Modes "640x480"
  89.     EndSubsection
  90. EndSection
  91. Section "ServerLayout"
  92.     Identifier "layout1"
  93.     InputDevice "Keyboard1" "CoreKeyboard"
  94.     InputDevice "Mouse1" "CorePointer"
  95.     Screen "screen1"
  96. EndSection
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°320701
bobor
tueur de n44b
Posté le 06-09-2003 à 19:47:02  profilanswer
je mettrais pour voir large (keyboard et autre sans changement):
Section "Monitor"
    HorizSync   31.5 - 60.0
    VertRefresh 60 - 85
    Option "DPMS"
EndSection
Section "Device"
    Driver "ati"
EndSection
Section "Screen"
    Device "device1"
    Monitor "monitor1"
        Depth 16
        Modes "640x480"
    EndSubsection
EndSection
    Screen "screen1"
EndSection
Gitan des temps modernes
n°320717
NerOcrO
PrOut
Posté le 06-09-2003 à 20:08:43  profilanswer
Merci pour toute vos réponses les gars.
Je pars en vacance demain matin pour une semaine et ce soir, c'est la teuf lol.
Donc on reprend ce topic dans une semaine.
Ciaciao
Mieux vaut partir sur des rires de qualités que sur un silence de quantité.
 Page :   1  2
Page Suivante
SId: XFree se lance plus depuis la dernière mise à jour[MDK 9.1] de 256 à 2*512mo possible ????
[MDK 9.1] plantée au premier boot -> resoluBug graphique [RH9] {GeForce4 Go 488}
Démarrer en mode graphique ...Probléme MDK 9.1
Récupérer la config du noyau d'origine de l'install sur Mdk 91Pb de géométrie avec Lilo de MDK 9.1
[UPDATE] Interface graphique qui a disparue
Plus de sujets relatifs à : [MDK 9.1] L'interface graphique ne se lance pas
