5821 connectés
  Linux et OS Alternatifs
  Installation
  [Mandriva 2006 x86_64] Erreurs + kernel panic
n°836016
Tsuki_Kuro​i
ou Lune noire...
Posté le 18-08-2006 à 13:59:03  profilanswer
Je me tourne vers vous car les autres forums que j'ai testés ne semblent pas avoir de solution.  :cry:
Je viens juste d'installer ma Mandriva et lors du boot, j'obtiens :
ttys0 at I/O 0x3f8 (irq= 4) is a 16550A
ttys1 at I/O 0x2f8 (irq= 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 32000K size 1024blocksize
pktcdvd: v0.2.0a 2004-07-14 Jens Axboe (axboe@suse.de) and peter02@telia.com
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha 2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.0
PCI: Via IRQ fixup for 0000:00:0f.0
VP_IDE: chipset revision 7
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: Unknow VIA SouthBridge, disabling DMA
mice: PS/2 mouse device common for all mice
md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 4096 buckets, 32 Kbites
TCP etablished hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 byets)
TCP Hash tables configured (etablished 16384 blind 16384)
NET: Registered protocol family 1
ACPI wakeup devices:
PCI0 USB1 USB2 USB3 USB4 EHCI AC97 MC97 LAN1 PEXG PEX0 AZAC P2PBUAR1 PS2M PS2K
ACPI: (supports S0 S3 S4 S5)
BIOS EDD facility v0.16 2004_Jun-25, 1 devices found
devfs_mk_dev: could not append to parent for md/0
md: Autodetecting RAID arrays.
md: Autorun ...
md: ... autorun DONE
RAMDISK: Compressed image found at block 0
input: AT Translated Set 2 keyboard on isa0060/serio0
VFS: Mounted root (ext2 filesystem).
Red Hat nash version 4.2.17mdk starting
Loading jbd.ko module
Loading ext3.ko module
Mounting /proc filesystem
Mounting sysfs
Creating device files
Mounting tmpfs on /dev
Creating root device
Mounting root filesystem /dev/root
mount: error 6 mounting ext3 flags defaults
well, retrying without the option flags
well, retrying read-only without any flag
pivotroot: pivot_root(/sysroot,/sysroot/initrd) failed:2
umount /initrd/sys failed:2
Initrd finished
Freeing unused kernel memory: 224k freed
Kernel panic - not syncing: No initrd found. Try passing init= option to kernel.
_
On m'a dit que le système n'arrivait pas à monter mon disque dur.
Si vous voulez d'autres infos, pensez à lire mes autres posts ici et là et aussi par là
Je vous implore une aide !  :cry:  :cry:  :cry:
Enfin ceux qui peuvent m'aider... AiDeZ MoI !
Je suis ouvert à tout même au formatage puisqu'il n'y a rien sur ce PC (il est neuf).
Bref, merci à ceux qui pourront m'aider.
n°836029
wedgeant
Da penguin inside
Posté le 18-08-2006 à 14:22:29  profilanswer
Bonjour
C'est un peu bizarre, il semblerait que ton disque dur ne soit pas détecté (ce qui expliqerait qu'il ne veuille pas le monter ...).
C'est un sata ou un ide ?
Apparament, tu as installé une Mandriva ou une Mandrake, quel kernel as tu choisi ? (2.4, 2.6, ide, scsi ??)
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°836043
Tsuki_Kuro​i
ou Lune noire...
Posté le 18-08-2006 à 14:44:24  profilanswer
D'après ceci (from AIDA, mon HDD est un  HDT722516DLAT80, relevé avant l'installation de mdk)
Je n'en sais rien. J'ai tout installé à partir des 3 CD's de Mandriva 2006 x86_64... sûrement le 2.6.
Mais il arrive à me monter mon disque avec la console "recue" et tout ce que je peux faire après c'est de la ligne de commande (le mode rescue est prévu pour les 'petits' dépannages). On m'a conseillé de tout réinstaller et de mettre GRUB au lieu de LILO. C'est ce que je fais, on verra bien.
Je reviendrai poster si ça a marché ou échoué.
Merci quand même.
n°836052
Tsuki_Kuro​i
ou Lune noire...
Posté le 18-08-2006 à 14:59:00  profilanswer
Eh... non.
Il charge peut-être plus vite que LILO mais GRUB m'affiche le même écran avec les mêmes erreurs.
J'aurais voulu me dépanner avec mon HDD externe pour ensuite télécharger les dernières mises à jour...
Et si j'installais la version 32 bits, aurais-je droit aux mêmes erreurs ?
n°836056
Mjules
Parle dans le vide
Posté le 18-08-2006 à 15:22:49  profilanswer
c'est quoi ta config ?
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°836064
Tsuki_Kuro​i
ou Lune noire...
Posté le 18-08-2006 à 15:43:27  profilanswer
Ben si tu avais lu mes autres posts, tu l'aurai vite sus.
Bref, tu lis ça et tu regarde le fichier attaché : c'est ma config (de AIDA avant d'installer Mdk)
n°836068
Mjules
Parle dans le vide
Posté le 18-08-2006 à 15:54:16  profilanswer
écoute, si on est obligé de faire un jeu de piste pour trouver ta config, tu te débrouilleras tout seul
n°836086
Tsuki_Kuro​i
ou Lune noire...
Posté le 18-08-2006 à 16:28:30  profilanswer
Woaow, et en plein dans la tronche !
Donc je vais faire ici un super résumé pour pas que les messieurs ils aillent galopper ailleurs :
* Mon Problème : mount: error 6 mounting ext3
    Mon PC n'arrive donc pas à monter mon disque dur IDE.
    Est-il reconnu ? J'ai pu faire l'install' dessus plusieurs fois sans problèmes.
    Autre point, il arrive à tout me monter dans le mode "recue" avec le CD 1 de Mandriva.
    Est-ce LILO ? Non, GRUB me ramène au même écran avec les mêmes erreurs.
* Mais qu'est-ce que j'ai bien pu faire ?
     Rien, mon PC était neuf avec Windows XP et j'ai voulu installer Mandriva 2006 x86_64. (3 CD's)
     Pas de bidouillages dans le BIOS, actuellement tout est paramétré sur "Optimized default settings".
* Ton PC daterait-il de a préhistoire ?
     Non, on me l'a acheté il y a très peu de temps et il est globalement de 2005 (c'est un PC monté, je le rappelle).
* Bon alors c'est quoi ta config' ?
 Carte mère:
   Type de processeur   Unknown, 1600 MHz (8 x 200)
 Carte vidéo   VIA/S3G DeltaChrome IGP (64 Mo)
        Carte audio   Realtek HD Audio output
        Disque dur   HDT722516DLAT80
 Lecteur optique   TSSTcorp CD/DVDW SH-S182D
        Clavier   Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
 Souris   Souris compatible PS/2
 (CPUID) Propriétés:
   (CPUID) Fabricant   AuthenticAMD
   (CPUID) Nom du CPU   AMD Sempron(tm) Processor 3000+
        Propriétés de la carte mère:
   Identifiant de la carte mère   07/03/2006-K8M890-8237A-6A7L5M4DC-00
Comme j'ai la doc' j'ajoute que c'est une K9VGM-V Micro-ATX avec
+ Pont Nord : VIA K8M890
+ Pont Sud  : VIA VT8237A
Je vous met même ce qu'en dit le site officiel MSI
* Ce que j'ai déjà essayé de faire : Réinstaller en changeant la taille de chaque partition.
     De mettre "SATA Controller Mode" de RAID en IDE
     D'utiliser le mode rescue (je peux monter mon hdd mais après que faire ?)
     De remplacer LILO par GRUB
* Ce que j'aimerai faire.
     En gros arriver à aller dans ma session et télécharger les mises à jours pour que mes périphériques soient tous reconnus.
     -> Peut-être faut il que je boote sur un HDD externe.
     -> Peut-être qu'en installant la version 32 bits je pourrai tout configurer pour pouvoir ensuite "upgrader" vers la version 64 bits
     -> Peut-être qu'avec le mode rescue je peux charger chaque module les uns après les autres pour arriver à ma session
Voilà, je n'y connait pas grand chose et n'ai plus d'idée.
Je remercie tout ceux qui se penchent sur mon problème. (et je m'excuse Mjules)
Edit : Si vous cliquez sur 'ma configuration matérielle' juste au dessus de chacun de mes posts, vous verrez la config de mon vieux PC, celui sur lequel j'écris actuellement à défaut du neuf, voilà.
Message édité par Tsuki_Kuroi le 18-08-2006 à 16:30:34
  Installation
quel stage3, i686 ou x86, pr 1 Athlon XP ?[Carte tv][Mandriva]comment faire fonctionner une avertv hybrid+fm pci
Scan des erreurs des dvd gravéskernel panic au demarage debian sarge 3.1 (megaraid inside)
mandriva 2006 free, newbie (désolé) cherche aideBoot PXE / Initrd / Kernel
Importer les drivers wifi de BackTrack vers Mandriva ?Les droits des groupes sous Mandriva
Plus de sujets relatifs à : [Mandriva 2006 x86_64] Erreurs + kernel panic
