5072 connectés
  Linux et OS Alternatifs
  Installation
  Mandriva 2007 + snort
n°903108
lepounch
Posté le 13-04-2007 à 14:49:02  profilanswer
je souhaite auditer mon réseau, je dispose pour cela de la distribution Mandriva 2007
et la toute dernière version de snort-2.6.1.4
donc j'ai téléchargé ce dernier snort-2.6.1.4.tar.gz
tar -xvzf snort-2.6.1.4.tar.gz
cd ./snort-2.6.1.4
puis je tape
snort-2.6.1.4]$ ./configure --with-mysql                puisque je veux gérer snort avec une base de données
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for ranlib... ranlib
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... (cached) ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking whether byte ordering is bigendian... no
checking for sparc alignment... no
checking for strings.h... (cached) yes
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking for inet_ntoa in -lnsl... yes
checking for socket in -lsocket... no
checking whether printf must be declared... no
checking whether fprintf must be declared... no
checking whether syslog must be declared... no
checking whether puts must be declared... no
checking whether fputs must be declared... no
checking whether fputc must be declared... no
checking whether fopen must be declared... no
checking whether fclose must be declared... no
checking whether fwrite must be declared... no
checking whether fflush must be declared... no
checking whether getopt must be declared... no
checking whether bzero must be declared... no
checking whether bcopy must be declared... no
checking whether memset must be declared... no
checking whether strtol must be declared... no
checking whether strcasecmp must be declared... no
checking whether strncasecmp must be declared... no
checking whether strerror must be declared... no
checking whether perror must be declared... no
checking whether socket must be declared... no
checking whether sendto must be declared... no
checking whether vsnprintf must be declared... no
checking whether snprintf must be declared... no
checking whether strtoul must be declared... no
checking for snprintf... yes
checking for strlcpy... no
checking for strlcat... no
checking for strerror... yes
checking for __FUNCTION__... yes
checking for floor in -lm... yes
checking for pcap_datalink in -lpcap... no
   ERROR!  Libpcap library/headers not found, go get it from
   http://www.tcpdump.org
   or use the --with-libpcap-* options, if you have it installed
   in unusual place
 il me dit qu'il ne trouve pas libpcap mais pourtant j'ai ce rpm qui a été téléchargé sur pbone.net.
Quand je vérifie dans le drakconf il est bien présent. Par contre en console quand je fais un whereis libpcap il me repond rien du tout
Donc je ne comprend pas très bien...
Pouvez vous m'aider svp..??
merci d'avance de vos réponses et bonne journée
n°903109
memaster
M.arc a volé mon 62
Posté le 13-04-2007 à 14:57:03  profilanswer
au lieu de compiler snort, tu devrais faire :
urpmi snort et voila boum hue, ça fonctionne en 2sec.
n°903127
lepounch
Posté le 13-04-2007 à 15:44:55  profilanswer
oui mais ensuite je fais comment pour installer et implémenter ma base de données mysql à snort ?
merci encore
n°903128
memaster
M.arc a volé mon 62
Posté le 13-04-2007 à 15:49:02  profilanswer
merci encore
tu te renseignes sur les fonctionnalités de snort. :(
on ne fait pas le boulot des autres ici ;)
n°903151
lepounch
Posté le 13-04-2007 à 16:23:41  profilanswer
J'avais trouver pour un fichier tar.gz mais pour le rpm, je ne vois pas où agir
je ne suis pro du linux...
si tu peux m'aider sur ce point ou quelqu'un d'autre, ce serait extra
merci encore
n°903156
memaster
M.arc a volé mon 62
Posté le 13-04-2007 à 16:27:01  profilanswer
merci encore
merci d'être précis, car la je comprend pas de quel rpm tu parles?
quel est exactement ce que tu veux faire?
je vois bien snort, je vois bien mysql mais je vois pas de rapport avec les 2 ensembles.
pour installer proprement snort, tu vas dans une console, tu te loggues en root et tu tappes:
#urpmi snort
pour installer proprement mysql server et client, tu vas dans une console, tu te loggues en root et tu tappes:
#urpmi mysql mysql-server
ps : j'insiste sur les termes en gras. tu n'as pas besoin recuperer quelque tar.gz que ce soit. :non:
Message édité par memaster le 13-04-2007 à 16:28:05
n°903164
Dark_Schne​ider
Close the World, Open the Net
Posté le 13-04-2007 à 16:58:23  profilanswer
[admin@info1 12-04-2007]$ urpmq --list | grep snort
airsnort
snort
snort-bloat
snort-community-rules
snort-inline
snort-inline+flexresp
snort-mysql
snort-mysql+flexresp
snort-plain+flexresp
snort-postgresql
snort-postgresql+flexresp
snort-prelude
snort-prelude+flexresp
snort-rules
snortcenter
snortconf
snortreport
pour avoir le support mysql pour snort, il te faudra installer le package snort-mysql.
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°903175
lepounch
Posté le 13-04-2007 à 17:15:33  profilanswer
je voudrais tout d'abord te remercier de ton aide
effectivement cette méthode d'installaation je l'ai faîtes, mais ce que je n'arrive pas à faire c'est à associer la base de donnée à snort, pour que les rapport d'erreurs ou les alertes soient repertoriés dans une base de données.Je sais que c'est possible mais comment..ça je ne sais pas.. je n'arrive pas à trouver la procédure
  Installation
Gravure mandriva [RESOLU][RESOLU] [Mandriva 2007] [ATI] pas d'acceleration 3D
Comment lancer sshd sous Mandriva 2007 ??probleme au lancement du live cd de mandriva
Snort et MySql[mandriva] problèmes fenêtres + serveur
Installation firefox sous Mandriva 2007
Plus de sujets relatifs à : Mandriva 2007 + snort
