4094 connectés
  Linux et OS Alternatifs
  Installation
  linux ne redemarre pas
n°201811
taotao
Posté le 14-12-2002 à 18:03:12  profilanswer
j'ai installe linux debian woody sur mon portable hp xe 4500, mais , au redemarrage, j'ai un message "kernel panic, try to kill idle...", et ca reste bloque.. MAis j'arrive a demarrer avec une disquette.
Qui a une idee? Merci pour d'avance pour votre aide
n°201827
BMOTheKill​er
Posté le 14-12-2002 à 19:13:47  profilanswer
Code :
  1. When starting WinLinux I receive the message:
  2. Aiee, killing interrupt handler
  3. Unable to handle kernel paging request.
  4. Kernel panic: Attempted to kill the idle task!
  5. In Swap task - not syncing
  6. Code: 89 02 85 c0 74 03 89 50 04 68 01 00 00 00 eb 07 90 8d 74 26
  7. Then the computer freezes. What do I do?Some users had reported this problem.  In most cases, they are using
  8. Laptops and the error happens when the PCMCIA service is started.
  9. If this is your case, do the following:
  10. 1) Open the Configuration Utility.
  11. 2) Click on Advanced.
  12. 3) Check the box "Disable PCMCIA" and click ok.
  13. 4) Finish the Configuration Utility.
  14. 5) Restart WinLinux.
  15. This will let you start WinLinux 2001 without problems. Please don't use the
  16. Desktop icon to start WinLInux.
  17. 6) Once in WinLinux 2001, log as root.
  18. 7) Edit the file /etc/sysconfig/pcmcia, adding the folloiwng changes:
  19. PCMCIA=yes
  20. ALLOW BOOT
  21. PCIC=i82365
  22. PCIC_OPTS=  #if you have something written here, delete it.
  23. CORE_OPTS=
  24. 8) Save the file and exit.
  25. 9) On a terminal window, type "/etc/rc.d/init.d/pcmcia start" without the
  26. quotes and press enter.
  27. 10) If no error message appears ("Starting pcmcia  [FAILED]" ), you're ready
  28. to use your pcmcia devices.
  29. Your problem should be fixed now.
source : http://www.winlinux.net/2001/faq/f [...] ion=wl2001
n°201829
BMOTheKill​er
Posté le 14-12-2002 à 19:15:22  profilanswer
tu dois avoir ce problème donc essaye en désactivant le démon PCMCIA en démarrant en mode rescue ou à partir de la disquette
n°202004
taotao
Posté le 15-12-2002 à 15:19:06  profilanswer
Merci de ta réponse, je vais essayer tout de suite, et je vais te dire si c'est ca
n°202029
taotao
Posté le 15-12-2002 à 16:41:19  profilanswer
merci, c'est bien ca le probleme
  Installation
NDLR & Linux Debian : comment les concilier ?[Linux Mandrake 9] Kernel Panic :(
Graver des DVDs sous linux ?Problem install de linux sur mon disque secondaire
fusion utilisateur win NT linux avec winbind?opera 6 sous linux
[MAC] Débutant aimerai installer Linux[vtun , vpn , linux , freebsd] @ l'aide !!!
Quels sont les modems v92 externes qui marchent sans pb sous linux?kel linux?
Plus de sujets relatifs à : linux ne redemarre pas
