5920 connectés
 Page :   1  2
Page Suivante
[Gentoo] Pb de modem ADSL interne à base de chipset Itex.
n°376326
Klaimant
Posté le 17-12-2003 à 22:49:21  profilanswer
ouais pis éditer ton texte pour que l'on comprenne :)
Fais le ou ne le fais pas, mais il n'y a pas d'essai !!!
n°376333
sorg
trop sur HFR depuis 2001
Posté le 17-12-2003 à 22:58:40  profilanswer
Ok, alors on s'y remet:
jai triché , je viens de trouver un pppd 2.4.0 patché aue je viens de de coller comme un sale sur la version que j'avais.
On avance...  le module se charge (voir le log ci dessous), la carte est detectee mais quand je lance pppd call adsl , il se passe pas grand chose... Si qqun as une idee ?
[s][g]Chargement du module[/g][/s]
Dec 17 23:48:35 localhost kernel: itexadsl: version= 2.2.7.ITEXPC86.0005 , built date= Thu Feb  7 11:16:17 PST 2002
Dec 17 23:48:35 localhost kernel: itexadsl: card# 0, ix=0x0, bus=0x0, fn=0x50, ven=0x1471, dev=0x188
Dec 17 23:48:35 localhost kernel: itexadsl: total 1 card(s) found.
Dec 17 23:48:35 localhost kernel: itexadsl: irq=0x5, ioaddr=0xe000, membase=0xe6000000
Dec 17 23:48:35 localhost kernel: itexadsl: card #0 - MAC: 00:90:96:1b:14:1d from eeprom.
Dec 17 23:48:35 localhost kernel: itexadsl: ITeX i90234 chip.
Dec 17 23:48:35 localhost kernel: init_module: cardcnt = 1
Dec 17 23:48:35 localhost kernel: Into the GenCRC10Table
Dec 17 23:48:35 localhost kernel: Finished the GenCRC10Table
Dec 17 23:48:36 localhost kernel: itexadsl: modem line disconnected.
Dec 17 23:48:38 localhost kernel: card #0 - current modem state : ACTIVATING.
Dec 17 23:48:40 localhost kernel: card #0 - current modem state : INITIALIZING.
Dec 17 23:48:48 localhost kernel: itexadsl: modem line connected. (card_no: 0)
Dec 17 23:48:48 localhost kernel: itexadsl: upstream latency - interleaved
Dec 17 23:48:48 localhost kernel: itexadsl: downstream latency - interleaved
Dec 17 23:48:48 localhost kernel: itexadsl: card #0 - data rate: 160 / 640  (line rate: 276 / 964) kbps
Dec 17 23:48:48 localhost kernel: connect_bh:tx cell per msec 1
Dec 17 23:48:48 localhost kernel: connect_bh: upstream rate 160
Dec 17 23:48:48 localhost kernel: card #0 - current modem state : SHOWTIME_L0.
[s][g]Là je fais "pppd call adsl"[/g][/s]
Dec 17 23:48:53 localhost kernel: CSLIP: code copyright 1989 Regents of the University of California
Dec 17 23:48:53 localhost kernel: PPP generic driver version 2.4.2
Dec 17 23:48:53 localhost kernel: itex_open: opening vpi.vci 8.35 on 0 NIC card
Dec 17 23:48:53 localhost kernel: itex_open: target cell rate (UBR) = 0 0 0 on 0 NIC card.
Dec 17 23:48:53 localhost kernel: InsertOAMF5Info: Vpi = 8, Vci = 35
Dec 17 23:48:53 localhost kernel: Finish InsertOAMF5Info
Dec 17 23:48:53 localhost kernel: Into the CAtmOAMF5Init
Dec 17 23:48:53 localhost kernel: Finish CAtmOAMF5Init
n°376338
sorg
Posté le 17-12-2003 à 23:10:19  profilanswer
Alors là, c pas mal...
Si j'en crois ce How-to:
http://www.wlug.org.nz/IA310
Mon log à la connection ppp indique que tout va bien ... le seul problème c'est que ifconfig, me renvoie des infos uniquement sur lo et eth0
n°376342
Klaimant
Posté le 17-12-2003 à 23:30:10  profilanswer
tu as bien configuré ppp ??
n°376344
sorg
Posté le 17-12-2003 à 23:35:18  profilanswer
Mon fichier /etc/ppp/peers/adsl a cette gueule:
# I have this file installed as /etc/ppp/peers/adsl
lock
noauth
asyncmap 0
defaultroute
usepeerdns
name USERNAME-GOES-HERE
user USERNAME-GOES-HERE
plugin /usr/lib/pppd/2.4.1/pppoatm.so
8.35
J'ai aussi mis mon couple user/mot de passe dans chap-secret et pap-secret ... Il y a autre chose à configurer ?
n°376346
Klaimant
Posté le 17-12-2003 à 23:37:07  profilanswer
Je sais pas trop, je connais pas ton modem et son installation :/
n°376565
sorg
Posté le 18-12-2003 à 17:22:11  profilanswer
:sweat:
n°376823
sorg
Posté le 19-12-2003 à 09:16:30  profilanswer
Bon, hier soir j'ai bataillé comme un russe (4 compilations de noyau en essayant les différentes options relatives à l'ATM; et 3 versions de ppp) : en vain !!!
De dépit ce soir je passe à l'ennemi et j'essaie une debian. Il y a quoi comme noyau dessus ?
n°376868
Klaimant
Posté le 19-12-2003 à 11:49:12  profilanswer
2.4.18 par défaut :)
n°376927
sorg
Posté le 19-12-2003 à 14:12:08  profilanswer
et j'ai besoin de quels CD ? le 1 suffit pour commencer ?
n°376932
Klaimant
Posté le 19-12-2003 à 14:20:07  profilanswer
oui
 Page :   1  2
Page Suivante
[Debian] Ma connection adsl ne fonctionne PLUS[Résolu][Gentoo] Pb pour ré-emerger Xine-lib-1_rc2
[ADSL] 9Online / mdk9.2Connection ADSL
Modem Bewan USB et Mdk9.2 : please ... help !Modem Speedtouch Ethernet
Utilisation du micro chipset intégréChipset son Ess 1878 et son horrible
paratage de connexion adsl[Gentoo] Modules?
Plus de sujets relatifs à : [Gentoo] Pb de modem ADSL interne à base de chipset Itex.
