4531 connectés
  Linux et OS Alternatifs
  Installation
  Pb d installation du Thomson Speedtouch 330 sous linux debian
n°341606
gunti
Posté le 19-10-2003 à 17:11:09  profilanswer
Bonjour tt le monde,
J ai recemment installe linux distribution debian sur mon ordinateur. J ai donc voulu installer mon modem usb speedtouch 330 pour avoir l adsl. A l aide de deux aides trouvees en ligne j ai essaye mais ca ne marche pas. Voici une copie du syslog ou ca semble peche :
Oct 10 18:06:19 Jerome modem_run[254]: modem_run version 1.2-beta2 started by root uid 0
Oct 10 18:06:21 Jerome kernel: usb_control/bulk_msg: timeout
Oct 10 18:06:21 Jerome kernel: usbdevfs: USBDEVFS_BULK failed dev 3 ep 0x85 len 512 ret -110
Oct 10 18:06:41 Jerome modem_run[254]: ADSL synchronization has been obtained
Oct 10 18:06:41 Jerome modem_run[254]: ADSL line is up (608 kbit/s down | 160 kbit/s up)
Oct 10 18:07:14 Jerome pppd[258]: pppd 2.4.1 started by root, uid 0
Oct 10 18:07:14 Jerome pppd[258]: Couldn't get channel number: Input/output error
Oct 10 18:07:14 Jerome pppd[258]: using channel 2
Oct 10 18:07:14 Jerome pppd[258]: Using interface ppp0
Oct 10 18:07:14 Jerome pppd[258]: Connect: ppp0 <--> /dev/pts/0
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 259), status = 0x7f
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 261), status = 0x7f
Oct 10 18:07:14 Jerome pppd[258]: Modem hangup
Oct 10 18:07:14 Jerome pppd[258]: Connection terminated.
Oct 10 18:07:14 Jerome pppd[258]: using channel 3
Oct 10 18:07:14 Jerome pppd[258]: Couldn't attach to channel 3: No such device or address
Oct 10 18:07:14 Jerome pppd[258]: using channel 4
Oct 10 18:07:14 Jerome pppd[258]: Couldn't attach to channel 4: No such device or address
Oct 10 18:07:14 Jerome pppd[258]: using channel 5
Oct 10 18:07:14 Jerome pppd[258]: Couldn't attach to channel 5: No such device or address
Oct 10 18:07:14 Jerome pppd[258]: using channel 6
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 266), status = 0x7f
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 265), status = 0x7f
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 264), status = 0x7f
Oct 10 18:07:14 Jerome pppd[258]: Script /usr/local/sbin/pppoa3 -m 1 -c -vpi 8 -vci 35 finished (pid 267), status = 0x7f
Merci d avance pour votre aide,
a bientot,
Gunthi
Message édité par gunti le 20-10-2003 à 08:39:19
n°341611
Piksou
Posté le 19-10-2003 à 17:19:29  profilanswer
précisions vu que c moi qui lui ai fait l'install:
c'est un 330, les drivers sont les derniers sppedtouch (ils supportent normalement le thomson), le firmware vient du même endroit http://speedtouch.sourceforge.net/
le chargement, du firmware se fait bien (erreur USB normale indiquée dans la FAQ), puis pppd se lance sans erreur mais.. pas de ppp0 :/
j'ai configuré en CHAP avec 8 et 35 comme valeurs puisque c'est d'après le howto les valeurs wanadoo
je comprends pas trop :/
mais bon chuis pas expert: chez moi c'est en ethernet pppoe (roxor :o)
Message édité par Piksou le 19-10-2003 à 17:20:44
« Le verbe "aimer" est le plus compliqué de la langue. Son passé n'est jamais simple, son présent n'est qu'imparfait et son futur toujours conditionnel. » Jean Cocteau
n°341913
Piksou
Posté le 20-10-2003 à 08:37:58  profilanswer
up du lundi matin
n°342255
Piksou
Posté le 20-10-2003 à 20:02:48  profilanswer
n°342321
mean
Posté le 20-10-2003 à 22:27:52  profilanswer
Lance pppd a la main avec debug 7 kdebug nodaemon
(de memoire)
Ca te donnera la cause de l'echec
n°342335
Piksou
Posté le 20-10-2003 à 22:49:26  profilanswer
concrètement ça done quoi sur ma ligne de commande ?
au lieu de
# pppd call adsl
je lance
# pppd call adsl debug 7 kdebug nodaemon
  Installation
changer resolution sous linux en failsafe[Debian Woody] TFT Hercules ProphetView non reconnu ... HELP
y-a un moyen de fixer un irq manuellement sous linux ?[ GATOS ] installation et configuration
[Debian] resolution Xfree bloquée en 800*600 je vais peter un cable !Config réseau (linux)
[Gentoo] installation sur controleur highpoint HPT 372Debian en Sid : badaboum
Probleme d'affichage sur portable GeForce FX 4200 Debian[GNU/Linux et OpenSource] ascension irrésistible
Plus de sujets relatifs à : Pb d installation du Thomson Speedtouch 330 sous linux debian
