7390 connectés
Erreur ldap
n°1269950
anzian
Posté le 14-03-2011 à 12:48:22  profilanswer
Bonjour à tous,
Je suis en train de mettre en place un serveur ldap esn suivant ce tuto: http://www.badministrateur.com/fr/node/67.
Au lancement du service ldap, tout se passe bien, mais que je fait ldaptest, jai cette erreur :
/etc/openldap/slapd.conf: line 29: warning: no by clause(s) specified in access line (ignored).
/etc/openldap/slapd.conf: line 35: warning: no by clause(s) specified in access line (ignored).
/etc/openldap/slapd.conf: line 40: warning: no by clause(s) specified in access line (ignored).
voici le contenu de mon fichier slapd.conf:
include         /etc/openldap/schema/core.schema
include         /etc/openldap/schema/cosine.schema
include         /etc/openldap/schema/inetorgperson.schema
include         /etc/openldap/schema/nis.schema
include         /etc/openldap/schema/samba.schema
include         /etc/openldap/schema/misc.schema
allow bind_v2
pidfile         /var/run/openldap/slapd.pid
argsfile        /var/run/openldap/slapd.args
database        bdb
suffix          "dc=domain,dc=com"
rootdn          "cn=Manager,dc=domain,dc=com"
rootpw          {SSHA}RzhPz/jqN+zA0sTmIlsHg+QG1X9X+929
directory       /var/lib/ldap
index   objectClass                     eq,pres
index   ou,cn,mail,surname,givenname    eq,pres,sub
index   uidNumber,gidNumber,loginShell  eq,pres
index   uid,memberUid                   eq,pres,sub
index   nisMapName,nisMapEntry          eq,pres,sub
index   sambaSID,sambaPrimaryGroupSID,sambaDomainName   eq
access to attrs=userPassword ---------------------------------------------------------> ligne 29
by dn="cn=Manager,dc=domaine,dc=com" write
by self write
by anonymous auth
by * none
access to attrs=sambaLMPassword,sambaNTPassword ----------------------> ligne 35
by dn="cn=Manager,dc=domain,dc=com" write
by self write
by anonymous auth
by * none
access to * --------------------------------------------------------------------------------------> ligne 40
Pourriez me donner un coup de main ?
n°1269952
e_esprit
Posté le 14-03-2011 à 13:37:19  profilanswer
Faut tabuler les lignes "by blablabla" qui se trouvent dessous tes "access to ..." pour qu'openldap voit qu'il s'agit d'un même bloc.
Enfin il me semble :D
n°1270270
anzian
Posté le 16-03-2011 à 09:55:48  profilanswer
j'ai tabulé, y a pas de changement, toujours le même message d'erreur.
config file testing succeeded
n°1270276
e_esprit
Posté le 16-03-2011 à 10:04:09  profilanswer
Tu peux reposter ton slapd.conf ?
n°1270334
anzian
Posté le 16-03-2011 à 16:15:31  profilanswer
allow bind_v2
database bdb
rootpw  {SSHA}RzhPz/jqN+zA0sTmIlXHg+QGLXCX+929
by self write
by  anonymous auth
by  *  none
by  self  write
by  anonymous  auth
by  *  none
access  to  *
by  dn="cn=Manager,dc=domain,dc=com"  read
by  *  none
n°1270341
e_esprit
Posté le 16-03-2011 à 16:21:31  profilanswer
Tu peux le mettre entre balises "fixed" ou "citation" ou "code" ?
Parce que là je vois pas les tabulations :D
n°1270343
e_esprit
Posté le 16-03-2011 à 16:23:59  profilanswer
Ah si je les vois dans le code source de ton message.
Tu les as pas mis au bon endroit :o
allow bind_v2
database bdb
<TAB>by dn="cn=Manager,dc=domain,dc=com"  write
<TAB>by self write
<TAB>by anonymous auth
<TAB>by  *  none
<TAB>by  self  write
<TAB>by  *  none
access  to  *
<TAB>by  dn="cn=Manager,dc=domain,dc=com"  read
<TAB>by  *  none
Bien sûr faut pas écrire <TAB>, c'est juste pour que tu vois bien où les placer :D
Message édité par e_esprit le 16-03-2011 à 16:26:41
n°1270345
anzian
Posté le 16-03-2011 à 16:26:31  profilanswer
allow bind_v2
database bdb
by self write
by  anonymous auth
by  *  none
by  self  write
by  anonymous  auth
by  *  none
access  to  *
by  *  none
n°1270351
anzian
Posté le 16-03-2011 à 16:34:40  profilanswer
cool.
Merci, c'est vraiment les tabulations.
Je poursuis ma config, je reviendrai vers vous en cas de nouveau soucis.
Merci encore
n°1270507
anzian
Posté le 17-03-2011 à 14:34:59  profilanswer
Rebonjour à tous,
j'ai poursuivi ma configue qui s'est bien terminé coté ldap.
J'ai donc entamé la config samba qui me ramène une erreur à la saisie de la commande net getlocalsid. Voici mon erreur:
[2011/03/17 13:26:46, 0] lib/smbldap.c:smbldap_connect_system(982)
failed to bind to server ldaps://srvmail.dsm.rk:636 with dn="cn=Manager,dc=domain,dc=com" Error: Can't contact LDAP server
error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
SID for domain SRVMAIL is: S-1-5-21-3378974079-1277803776-1392800262
Je vois qu'il dit ne pas pouvoir contacter le serveur ldap.
Pourriez vous encore me donner un coup de main
n°1270543
e_esprit
Posté le 17-03-2011 à 19:16:02  profilanswer
problème de certificats / LDAPS
Essaye en LDAP dans un premier temps. Passe au LDAPS (sécurisé) quand ça marchera ;)
n°1270578
anzian
Posté le 18-03-2011 à 10:04:05  profilanswer
Avec le ldap, voici le message d'erreur que j'ai:
[2011/03/18 08:56:57, 0] lib/smbldap.c:smb_ldap_start_tls(610)
  Failed to issue the StartTLS instruction: Connect error
C'est ce qui m'a fait aller vers le ldaps, avec lui au moins j'ai mon SID
Authentification globale via LDAP/ Front End Web LDAP[serveur debian lenny] erreur hda
Serveur LTSP et Authentification Ldap des clientsSingle Sign On: Comment organiser ldap? NetAdmin
Erreur : Connection refused[Ubuntu] Monter .img, message d'erreur
Erreur connection de FIllezillaPDC Samba-LDAP et groupes secondaires
[Résolu][PAM-LDAP] Restreindre accès à un posixGroup.Samba+LDAP>Erreur de connection... a 127.0.01
Plus de sujets relatifs à : Erreur ldap
