6122 connectés
  Linux et OS Alternatifs
  Installation
  [eclipse] pb a l'installation
n°751526
houam3012
Au pays des chauve souris
Posté le 12-11-2005 à 16:34:03  profilanswer
bonjour,
j'ai un pb a l'installation d'eclipse sous linux ubuntu.
j'ai téléchargé le fichier:
eclipse-SDK-3.1.1-linux-gtk.tar.gz.
j'ai le message suivant:
Code :
  1. at org.eclipse.osgi.framework.internal.core.OSGi.createFramework(OSGi.java:90)
  2. at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
  3. at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:215)
  4. at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:127)
  5. at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  6. at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  7. at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  8. at java.lang.reflect.Method.invoke(Method.java:324)
  9. at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
  10. at org.eclipse.core.launcher.Main.run(Main.java:704)
  11. at org.eclipse.core.launcher.Main.main(Main.java:688)
  12. !SESSION Sat Nov 12 16:09:50 CET 2005 ------------------------------------------
  13. !ENTRY org.eclipse.core.launcher 4 0 nov. 12, 2005 16:09:50.797
  14. !MESSAGE Exception launching the Eclipse Platform:
  15. !STACK
  16. java.lang.NullPointerException
  17. at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:138)
  18. at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  19. at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  20. at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  21. at java.lang.reflect.Method.invoke(Method.java:324)
  22. at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
  23. at org.eclipse.core.launcher.Main.run(Main.java:704)
  24. at org.eclipse.core.launcher.Main.main(Main.java:688)
quand j'execute la commande suivante:
./eclipse -vm /opt/j2sdk.1.4/bin/java
comment faire?
Merci :jap:
n°751529
mavk-t
Posté le 12-11-2005 à 16:47:27  profilanswer
Mauvaise VM, télécharge la 1.5 sur java.sun.com
&THEN :: t-shirts geek collectorZ:: fermeture pour noel ::  http://and.then.fr
  Installation
Monitorer les changements faits par l'installation d'un progautomatiser l'installation de logiciels supplémentaires
Problème installation pilotes linux mandrakeinstallation ocs inventory ng
Installation distrib linux sous MacOS 10Installation de J2SDK + Eclipse
Pb installation eclipse FC3Installation Eclipse, Crash lors du démarrage
[Debian] Installation de eclipse ne passe pas.Installation de l'IDE Eclipse [résolu]
Plus de sujets relatifs à : [eclipse] pb a l'installation
