8565 connectés
  Linux et OS Alternatifs
  Installation
  Debian testing : pb d'installation kde-3
n°206416
- Fred -
007 Agent
Posté le 30-12-2002 à 23:19:14  profilanswer
J'ai installé ma deb avec le CD Woody 3.0r0 (en fait, c'est une r0i3 ...), j'ai mis à jour mes sources selon le fichier que voici :
sources.list
deb http://http.us.debian.org/debian testing main contrib non-free
deb http://non-us.debian.org/debian-non-US testing/non-US main contrib non-free
deb http://security.debian.org testing/updates main contrib non-free
# Uncomment if you want the apt-get source function to work
deb-src http://http.us.debian.org/debian testing main contrib non-free
#deb-src http://non-us.debian.org/debian-non-US testing non-US
Et voici le message d'erreur que j'obtiens lorsque je veux installer kde (apt-get install kde) :
Reading Package Lists...
Building Dependency Tree...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  kde: Depends: kdebase but it is not going to be installed or
                kdebase3 but it is not installable
       Depends: kdebase-libs but it is not going to be installed or
                kdebase3-libs but it is not installable
       Depends: konqueror but it is not going to be installed or
                konqueror3 but it is not installable
       Depends: kate but it is not going to be installed or
                kate3 but it is not installable
       Depends: konsole but it is not going to be installed or
                konsole3 but it is not installable
       Depends: kpackage but it is not going to be installed
       Depends: kghostview but it is not going to be installed
       Depends: ksirc but it is not going to be installed
       Depends: koffice but it is not going to be installed
       Depends: knewsticker but it is not going to be installed
J'aîmerais savoir s'il y a une solution ... l'install est toute propre, et j'ai vraiment besoin de KDE. De plus, la Deb est qd même réputée pour la qualité de ses package, ça a toujours roulé impec' chez moi, jusqu'aujourd'hui ...
D'ailleurs, j'avais des pbs avec le boot, il semblerait que quelques bidouilles avec Grub et lilo en viennent à bout. J'aurais d'ailleurs une autre question : où se trouve le fichier menu.lst de Grub après une installation sur Debian ?
Message édité par - Fred - le 30-12-2002 à 23:21:19
"You know the name, You know the number..."
n°206420
BigBen
M'enfin
Posté le 30-12-2002 à 23:29:55  profilanswer
bah déjà, la testing ne comporte que KDE 2.0, pas 3.0
Pour avoir le 3, faut ajouter bon dossier du ftp de kde (je te laisse chercher, mais bon, y a des packages tout propres... ;)
Pour ton pb, j'ai eu ce genre de message en essayant par erreur d'installer KDE 2 et 3 en même temps (oui, je sais, fais parfois des trucs bizarres...) T'aurais pas un programme déjà installé qui nécéssiterait KDE 3 ? (et qui donc empecherait l'install des fichiers que tu cites, qui appartiennent à KDE 2)
bref, en fait, pour installer kde 3, une fois que t'as mis la bonne adresse dans le sources.list, essaie apt-get install kdebase
et pas
apt-get install kde (y vas rééssayer d'installer le 2)
ou
apt-get install kde kdebase ... comme j'ai été assez con pour le faire... ;)
n°206421
parano
Time... to die...
Posté le 30-12-2002 à 23:31:47  profilanswer
Déja kde3 est pas du tout integré dans les package officiels de debian donc ton source-list suffira pas.
Voici un lien provenant de apt-get.org
deb http://shakti.ath.cx/debian/kde3.1 ./
tu as fait un "apt-get update" puis un "apt-get dist-upgrade" avant de poursuivre aussi ?
n°206458
- Fred -
007 Agent
Posté le 31-12-2002 à 09:07:28  profilanswer
J'ai effectivement fait les apt-get update" et "apt-get dist-upgrade" de rigueur avant d'installer tout ça, et je n'ai rien installé avant ... plutôt curieux ... je vais tester vos solutions, merci ;)
  Installation
RedHat 8.0 L'installation se bloque sur Partition Check hda[debian] QoS et options noyau
[debian] pb affichage fenetre X venant d'un autre pcfilecopy.pm et debian
Impossible de copier certains fichier lors de l'installation de xpcarte reseau d'un shuttle ss51g et debian
il arrive quand le linux kernel 2.4.20 dans la Debian Sarge ?[debian] Probleme a l'installation des drivers nvidia.
[debian] reseau . pour avoir une configuration automatique ??
Plus de sujets relatifs à : Debian testing : pb d'installation kde-3
