11430 connectés
  Linux et OS Alternatifs
  Installation
  gros pb avec console-data (debian testing)
n°226521
Aiua
PSN : Aiua / GT : Aiua42
Posté le 20-02-2003 à 21:52:20  profilanswer
j'ai le message d'erreur suivant lors ce que je tente un update ou un apt-get install -f
Selecting previously deselected package console-data.
(Reading database ... 11852 files and directories currently installed.)
Unpacking console-data (from .../console-data_2002.12.04dbs-5_all.deb) ...
Setting up console-data (2002.12.04dbs-5) ...
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/policy.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/ignored.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/family.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/azerty/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/dvorak/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/fggiod/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/qwertz/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/qwerty/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/template/layout.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/qwerty/estonian/variant.
... (il doit tous les faire je pense :D)
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/full.
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/powerpcadb.
Looking for keymap to install:
/var/lib/dpkg/info/console-data.postinst: line 13: /usr/share/console/getkmapchoice.pl: No such file or directory
dpkg: error processing console-data (--configure):
 subprocess post-installation script killed by signal (Segmentation fault)
Errors were encountered while processing:
 console-data
E: Sub-process /usr/bin/dpkg returned an error code (1)
j'ai essayé de purger, de réinstaller...
rien n'y fait, impossible de le faire marcher :/
c quoi le pb ?
n°226588
911GT3
en roue libre
Posté le 21-02-2003 à 09:11:47  profilanswer
Il semble que /usr/share/console/getkmapchoice.pl ne soit pas trouvé ou executable, or ceci appartient à console-common (du moins sous Sid).
Tu devrais t'assurer qu'il est là...
n°226663
Aiua
Posté le 21-02-2003 à 11:56:25  profilanswer
en fait console-common aussi merde
si je vire console-data pour ça bloque sur console-common :
Unpacking console-common (from .../console-common_0.7.19_all.deb) ...
debconf: warning: possible database corruption. Will attempt to repair by adding back missing question console-data/keymap/qwerty/danish/variant.
dpkg: error processing /var/cache/apt/archives/console-common_0.7.19_all.deb (--unpack):
 subprocess pre-installation script killed by signal (Segmentation fault)
n°226675
911GT3
en roue libre
Posté le 21-02-2003 à 12:36:13  profilanswer
mouais :/
question conne: est-ce que tu utilises toujours la même archive depuis ton cache ou est-ce que tu as déjà essayé de la reprendre sur un FTP ? (désolé  :sweat: )
Sinon :??:
n°228167
Aiua
Posté le 25-02-2003 à 09:47:01  profilanswer
j'ai déjà essayé de reprendre :/
"The pen is mightier than the sword if the sword is very short, and the pen is very sharp." TP. Mes Jeux. Mes Ventes. Groupe HFR sur PlayFire.
n°228175
kelus
Posté le 25-02-2003 à 10:05:47  profilanswer
meme probleme :/
n°228179
Aiua
Posté le 25-02-2003 à 10:26:01  profilanswer
Kelus a écrit :
meme probleme :/
ça me fait presque plaisir de savoir que je suis pas tout seul :D
n°228192
kelus
Posté le 25-02-2003 à 10:40:34  profilanswer
mais aucune solution trouvee :D
n°228197
Aiua
Posté le 25-02-2003 à 10:46:51  profilanswer
moi non plus, et là je suis à court d'idée
j'ai purgé console-common et console-data
j'ai essayé de les réinstaller plusieurs fois, j'ai meme changé de ftp au cas où... rien n'y fait, j'ai toujours mon "possible database corruption." :/
n°233004
Posté le 05-03-2003 à 14:41:43  answer
 /var/cache/apt/archives/console-common_0.7.21_all.deb
moi j'ai ça sur ma sid après apt-get update et apt-get dist-upgrade  [:razorbak83]
Posté le 05-03-2003 à 14:41:43  profilanswer
n°233203
HuGoBioS
Posté le 05-03-2003 à 19:13:15  profilanswer
meme pb sur ma sid mais bon ca m'empeche pas de dormir !
-= In Kik00 101 I trust :o =-
n°233227
Posté le 05-03-2003 à 19:44:15  answer
j'ai installé xmms-mad depuis (donc l'apt continuer de marcher)
[j'ai cette erreur:]
Setting up console-tools (0.2.3dbs-31) ...
Installing new version of config file /etc/console-tools/config ...
Installing new version of config file /etc/init.d/console-screen.sh ...
Setting up general console font...set_kernel_font: Invalid argument
cannot (un)set powersave mode
[néanmoins le processus suit son cours:]
You already have a LILO configuration in the file /etc/lilo.conf
Checking your /etc/lilo.conf for incompatible options...
Install a boot block using your current LILO configuration? [Yes]
WARNING: Even if lilo runs successfully, see /usr/share/doc/lilo/INCOMPAT.gz
         for changes in the usage of the /etc/lilo.conf file.
         If needed: edit /etc/lilo.conf and rerun '/sbin/lilo -v'
Running lilo...
/sbin/lilo: line 23: 23362 Segmentation fault      $0.real "$@"
ERROR: correct /etc/lilo.conf manually and rerun /sbin/lilo
dpkg: error processing lilo (--configure):
 subprocess post-installation script returned error exit status 1
Setting up man-db (2.4.1-6) ...
[les packages se configurent normalement et finalement:]
Setting up xmms-mad (0.5.3-3) ...
 lilo
le problème c'est qu'il n'y a rien d'anormal dans le fichier lilo.conf puisque la ligne 23 c'est:
boot=/dev/hda
et quand je tape:
 lilo -v
j'ai encore le message: /sbin/lilo: line 23: 23705 Segmentation fault      $0.real "$@"
n°233400
Posté le 06-03-2003 à 09:29:45  answer
up
  Installation
[Debian Sid] Dépendances et packages sources de mplayerDebian serveur mail...
choix du window manager en mode console (startx)[debian] c'est très dangereux les sources apt non-officielles ?
Pkoi pas de php4 4.3.0 sous debian ?Mandrake 9.0 et Dell Dimension 2350 : Gros probleme Xfree
[Debian Sarge]Problème d'installation d'openofficeDebian : Comment vire kdm etc du demarrage ?
zip usb 250 avec debianComment detecter sa souris sous Debian Woody ?
Plus de sujets relatifs à : gros pb avec console-data (debian testing)
