3234 connectés
  Linux et OS Alternatifs
  Installation
  pb avec xfree86 ss un imac
n°267946
chaos0007
Posté le 26-05-2003 à 10:09:49  profilanswer
voila g installé une debian ss un imac et g un pb avec le serveur x et je ne sais pas ou est le probleme : voila le log de xfree :
je precise ke c une souris usb un clavier usb et la carte graphique est une radeon 128
merci de m'aider
This is a pre-release version of XFree86, and is not supported in any
way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
 If the server is older than 6-12 months, or if your card is
 newer than the above date, look for a newer version before
 reporting problems.  (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.18-powerpc-smp ppc [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Mon May 26 10:02:03 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Generic Monitor"
(**) |   |-->Device "Generic Video Card"
(**) |-->Input Device "Generic Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "macintosh"
(**) XKB: model: "macintosh"
(**) Option "XkbLayout" "fr"
(**) XKB: layout: "fr"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
 Entry deleted from font path.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Open APM failed
(II) Module ABI versions:
 XFree86 ANSI C Emulation: 0.1
 XFree86 Video Driver: 0.4
 XFree86 XInput driver : 0.2
 XFree86 Server Extension : 0.1
 XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.0.0
 Module class: XFree86 Font Renderer
 ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 0.1.0
 ABI class: XFree86 Video Driver, version 0.4
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:0b:0: chip 106b,0020 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:10:0: chip 1002,524c card 1002,524c rev 00 class 03,80,00 hdr 00
(II) PCI: 01:0b:0: chip 106b,001f card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 01:12:0: chip 104c,8019 card 0000,0000 rev 00 class 0c,00,10 hdr 00
(II) PCI: 01:13:0: chip 1011,0019 card 0000,0000 rev 41 class 02,00,00 hdr 00
(II) PCI: 01:17:0: chip 106b,0022 card 0000,0000 rev 02 class ff,00,00 hdr 00
(II) PCI: 01:18:0: chip 106b,0019 card 0000,0000 rev 00 class 0c,03,10 hdr 00
(II) PCI: 01:19:0: chip 106b,0019 card 0000,0000 rev 00 class 0c,03,10 hdr 00
(II) PCI: 02:0b:0: chip 106b,001e card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
 [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
 [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:0:0), (-1,1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
(II) Bus 1 prefetchable memory range:
(II) Bus 2: bridge is at (0:0:0), (-1,2,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 2 I/O range:
(II) Bus 2 non-prefetchable memory range:
(II) Bus 2 prefetchable memory range:
(--) PCI: (0:16:0) ATI Rage 128 RL rev 0, Mem @ 0x94000000/26, 0x90000000/14, I/O @ 0x0400/8, BIOS @ 0x90020000/17
(II) Addressable bus resource ranges are
 [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
 [0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
 [1] -1 0 0x00000000 - 0x00000000 (0x1) MX[B]
 [2] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [3] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) Active PCI resource ranges:
 [0] -1 0 0x80081000 - 0x80081fff (0x1000) MX[B]
 [1] -1 0 0x80082000 - 0x80082fff (0x1000) MX[B]
 [2] -1 0 0x80000000 - 0x8007ffff (0x80000) MX[B]
 [3] -1 0 0x80080000 - 0x800803ff (0x400) MX[B]
 [4] -1 0 0x90020000 - 0x9003ffff (0x20000) MX[B](B)
 [5] -1 0 0x90000000 - 0x90003fff (0x4000) MX[B](B)
 [6] -1 0 0x94000000 - 0x97ffffff (0x4000000) MX[B](B)
 [7] -1 0 0x00000400 - 0x0000047f (0x80) IX[B]
 [8] -1 0 0x00000400 - 0x000004ff (0x100) IX[B](B)
(II) Inactive PCI resource ranges:
 [0] -1 0 0x80084000 - 0x80087fff (0x4000) MX[B]
 [1] -1 0 0x80083000 - 0x800837ff (0x800) MX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
 [2] -1 0 0x80081000 - 0x80081fff (0x1000) MX[B]
 [3] -1 0 0x80082000 - 0x80082fff (0x1000) MX[B]
 [4] -1 0 0x80000000 - 0x8007ffff (0x80000) MX[B]
 [5] -1 0 0x80080000 - 0x800803ff (0x400) MX[B]
 [6] -1 0 0x90020000 - 0x9003ffff (0x20000) MX[B](B)
 [7] -1 0 0x90000000 - 0x90003fff (0x4000) MX[B](B)
 [8] -1 0 0x94000000 - 0x97ffffff (0x4000000) MX[B](B)
 [9] -1 0 0x80084000 - 0x80087fff (0x4000) MX[B]
 [10] -1 0 0x80083000 - 0x800837ff (0x800) MX[B]
 [11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [12] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
 [13] -1 0 0x00000400 - 0x0000047f (0x80) IX[B]
 [14] -1 0 0x00000400 - 0x000004ff (0x100) IX[B](B)
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
 ABI class: XFree86 Server Extension, version 0.1
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
 Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "pex5"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading extension X3D-PEX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) LoadModule: "xie"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading extension XIE
(II) LoadModule: "r128"
(II) Loading /usr/X11R6/lib/modules/drivers/r128_drv.o
(II) Module r128: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 4.0.1
 Module class: XFree86 Video Driver
(II) LoadModule: "ati"
(II) Loading /usr/X11R6/lib/modules/drivers/ati_drv.o
(II) Module ati: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 6.3.6
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
 Module class: XFree86 XInput Driver
 ABI class: XFree86 XInput driver, version 0.2
(II) ATI: ATI driver (version 6.3.6) for chipsets: ati
(II) R128: Driver for ATI Rage 128 chipsets: ATI Rage 128 RE (PCI),
 ATI Rage 128 RF (AGP), ATI Rage 128 RG (AGP), ATI Rage 128 RK (PCI),
 ATI Rage 128 RL (AGP), ATI Rage 128 Pro PD (PCI),
 ATI Rage 128 Pro PF (AGP), ATI Rage 128 Pro PP (PCI),
 ATI Rage 128 Pro PR (PCI), ATI Rage 128 Mobility LE (PCI),
 ATI Rage 128 Mobility LF (AGP), ATI Rage 128 Mobility MF (AGP),
 ATI Rage 128 Mobility ML (AGP)
(II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
 ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
 ATI Radeon VE (AGP)
(--) Chipset ATI Rage 128 RL (AGP) found
(II) Loading sub module "r128"
(II) Reloading /usr/X11R6/lib/modules/drivers/r128_drv.o
(II) resource ranges after xf86ClaimFixedResources() call:
(WW) ****INVALID IO ALLOCATION**** b: 0x400 e: 0x4ff correcting
(II) window:
(II) resSize:
(II) window fixed:
(II) resource ranges after probing:
 [11] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
 [12] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
 [13] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
 [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B](B)
 [15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [16] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
 [17] -1 0 0x00000400 - 0x0000047f (0x80) IX[B]
 [18] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
 [19] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(II) R128(0): PCI bus 0 card 16 func 0
(**) R128(0): Depth 24, (--) framebuffer bpp 32
(II) R128(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) R128(0): Default visual is TrueColor
(**) R128(0): Option "UseFBDev" "true"
(==) R128(0): RGB weight 888
(II) R128(0): Using 8 bits per RGB (8 bit DAC)
(**) R128(0): Using framebuffer device
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 0.0.2
(--) R128(0): Chipset: "ATI Rage 128 RL (AGP)" (ChipID = 0x524c)
(--) R128(0): Linear framebuffer at 0x94000000
(--) R128(0): MMIO registers at 0x90000000
(--) R128(0): BIOS at 0x90020000
(II) R128(0): Video RAM override, using 32000 kB instead of 8192 kB
(**) R128(0): VideoRAM: 31744 kByte (64-bit SDR SGRAM 2:1)
(WW) R128(0): Video BIOS not detected in PCI space!
(WW) R128(0): Attempting to read Video BIOS from legacy ISA space!
(WW) R128(0): Video BIOS not found!
(II) R128(0): PLL parameters: rf=2950 rd=56 min=12500 max=25000; xclk=5010
(II) Loading sub module "ddc"
(II) Reloading /usr/X11R6/lib/modules/libddc.a
(==) R128(0): Using gamma correction (1.0, 1.0, 1.0)
(II) R128(0): Generic Monitor: Using hsync range of 30.00-57.00 kHz
(II) R128(0): Generic Monitor: Using vrefresh range of 43.00-72.00 Hz
(II) R128(0): Clock range:  12.50 to 250.00 MHz
(II) R128(0): Not using default mode "640x350" (vrefresh out of range)
(II) R128(0): Not using default mode "640x400" (vrefresh out of range)
(II) R128(0): Not using default mode "720x400" (vrefresh out of range)
(II) R128(0): Not using default mode "640x480" (vrefresh out of range)
(II) R128(0): Not using default mode "800x600" (vrefresh out of range)
(II) R128(0): Not using default mode "1024x768" (vrefresh out of range)
(II) R128(0): Not using default mode "1024x768" (hsync out of range)
(II) R128(0): Not using default mode "1152x864" (hsync out of range)
(II) R128(0): Not using default mode "1280x960" (hsync out of range)
(II) R128(0): Not using default mode "1280x1024" (hsync out of range)
(II) R128(0): Not using default mode "1600x1200" (hsync out of range)
(II) R128(0): Not using default mode "1792x1344" (hsync out of range)
(II) R128(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
(II) R128(0): Not using default mode "1856x1392" (hsync out of range)
(II) R128(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) R128(0): Not using default mode "1920x1440" (hsync out of range)
(II) R128(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) R128(0): Not using default mode "1400x1050" (hsync out of range)
(--) R128(0): Virtual size is 1024x768 (pitch 1024)
(**) R128(0): Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) R128(0): Modeline "1024x768"   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync
(**) R128(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) R128(0): Modeline "800x600"   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync
(**) R128(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) R128(0): Modeline "640x480"   25.20  640 656 752 800  480 490 492 525 -hsync -vsync
(++) R128(0): DPI set to (100, 100)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
 ABI class: XFree86 ANSI C Emulation, version 0.1
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
 [0] 0 0 0x90000000 - 0x90003fff (0x4000) MS[B]
 [1] 0 0 0x94000000 - 0x97ffffff (0x4000000) MS[B]
 [2] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
 [3] -1 0 0x00000000 - 0x00000000 (0x1) MX[B]
 [4] -1 0 0x80081000 - 0x80081fff (0x1000) MX[B]
 [5] -1 0 0x80082000 - 0x80082fff (0x1000) MX[B]
 [6] -1 0 0x80000000 - 0x8007ffff (0x80000) MX[B]
 [7] -1 0 0x80080000 - 0x800803ff (0x400) MX[B]
 [8] -1 0 0x90020000 - 0x9003ffff (0x20000) MX[B](B)
 [9] -1 0 0x90000000 - 0x90003fff (0x4000) MX[B](B)
 [10] -1 0 0x94000000 - 0x97ffffff (0x4000000) MX[B](B)
 [11] -1 0 0x80084000 - 0x80087fff (0x4000) MX[B]
 [12] -1 0 0x80083000 - 0x800837ff (0x800) MX[B]
 [13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
 [14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
 [15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
 [16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B](B)
 [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [18] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
 [19] -1 0 0x00000400 - 0x0000047f (0x80) IX[B]
 [20] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
 [21] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
[drm] failed to load kernel module "r128"
(II) R128(0): [drm] drmOpen failed
(EE) R128(0): [dri] DRIScreenInit failed.  Disabling DRI.
(II) R128(0): Memory manager initialized to (0,0) (1024,7936)
(II) R128(0): Reserved area from (0,768) to (1024,770)
(II) R128(0): Largest offscreen area available: 1024 x 7166
(==) R128(0): Backing store disabled
(==) R128(0): Silken mouse enabled
(II) R128(0): Using XFree86 Acceleration Architecture (XAA)
 Screen to screen bit blits
 Solid filled rectangles
 8x8 mono pattern filled rectangles
 Indirect CPU to Screen color expansion
 Solid Lines
 Dashed Lines
 Scanline Image Writes
 Offscreen Pixmaps
 Setting up tile and stipple cache:
  32 128x128 slots
  32 256x256 slots
  16 512x512 slots
(II) R128(0): Acceleration enabled
(II) R128(0): Using hardware cursor (scanline 3080)
(II) R128(0): Largest offscreen area available: 1024 x 7164
(**) Option "dpms"
(**) R128(0): DPMS enabled
(II) R128(0): Direct rendering disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
PEXExtensionInit: Couldn't open default PEX font file  Roman_M
(II) Keyboard "Generic Keyboard" handled by legacy driver
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/mouse"
(==) Configured Mouse: Buttons: 3
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
Fatal server error:
Caught signal 11.  Server aborting
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
n°267950
chaos0007
Posté le 26-05-2003 à 10:15:09  profilanswer
je mets aussi le XF86Config-4 :
### BEGIN DEBCONF SECTION
# XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
# Debian X Configuration tool, using values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# If you want your changes to this file preserved by dexconf, only make changes
# before the "### BEGIN DEBCONF SECTION" line above, and/or after the
# "### END DEBCONF SECTION" line below.
# To change things within the debconf section, run the command:
#   dpkg-reconfigure xserver-xfree86
# as root.  Also see "How do I add custom sections to a dexconf-generated
# XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
Section "Files"
 FontPath "unix/:7100"   # local font server
 # if the local font server has problems, we can fall back on these
 FontPath "/usr/lib/X11/fonts/misc"
 FontPath "/usr/lib/X11/fonts/cyrillic"
 FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/Type1"
 FontPath "/usr/lib/X11/fonts/Speedo"
 FontPath "/usr/lib/X11/fonts/100dpi"
 FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
 Load "GLcore"
 Load "bitmap"
 Load "dbe"
 Load "ddc"
 Load "dri"
 Load "extmod"
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "pex5"
 Load "record"
 Load "speedo"
 Load "type1"
 Load "vbe"
 Load "xie"
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
EndSection
Section "Device"
 Identifier "Generic Video Card"
 Driver  "r128"
 BusID  "PCI:0:16:0"
 VideoRam 32000
EndSection
Section "Monitor"
 Identifier "Generic Monitor"
 HorizSync 30-57
 VertRefresh 43-72
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier "Default Screen"
 DefaultDepth 24
 SubSection "Display"
  Depth  1
  Modes  "1024x768" "800x600" "640x480"
 EndSubSection
  Depth  4
 EndSubSection
  Depth  8
 EndSubSection
  Depth  15
 EndSubSection
  Depth  16
 EndSubSection
  Depth  24
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
EndSection
Section "DRI"
 Mode 0666
EndSection
n°267953
Aragorn_1e​r
Le jihad butlérian est proche
Posté le 26-05-2003 à 10:18:26  profilanswer
:sarcastic:
Edit : Verifie aussi du coter du module de ta carte G :
A+
Message édité par Aragorn_1er le 26-05-2003 à 10:20:05
n°274040
chaos0007
Posté le 07-06-2003 à 09:35:52  profilanswer
est ce que qq1 a déjà fait tourner un linux ss un imac et pourrait me filer un fichier de conf de xfree car la je patauge
n°274073
clockover
That's the life
Posté le 07-06-2003 à 12:52:18  profilanswer
Par contre moi je connais aps de radeon 128. C 'est aps plutot une Rage 128 ?
  Installation
installation linux sur imac : préparation du disque durXlib: extension "XFree86-DRI" missing on display ":0.0".
Radeon 9500 Pro et Mandrake 9.1 (XFree86 4.3.0)Fork de XFree86
[XFree86 & nVidia] le taux de raffraichissement verticalePB Xfree86 4.3 avec les Polices
[Help me please] Installer XFree86 sur DebianCarte supportée mais pas reconnue par XFree86
[XFree86 4.3.0] Hercules ATI Radeon 9700 Pro ...clavier belge sous cygwin/XFree86
Plus de sujets relatifs à : pb avec xfree86 ss un imac
