4411 connectés
  Linux et OS Alternatifs
  Installation
  apres un urpmi de 294 mo.... ca foire :(
n°238487
piloud
Posté le 19-03-2003 à 20:46:29  profilanswer
je fais un urpmi --auto-select
apres 100 mo et qq(ou peut etre tout) il s'arrete
les paquets suivant sont pas signes ...:
blablabla * 7 ou 8
voulez vous poursuivre l'installe ? oui
blabla
Préparation...              ##################################################
L'installation a échoué:
        file /usr/share/man/fr/man1/backend.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/filter.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lp.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lpoptions.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lppasswd.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lpq.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lpr.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lprm.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man1/lpstat.1.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man3/cups-config.3.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man5/classes.conf.5.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man5/cupsd.conf.5.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man5/mime.convs.5.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man5/mime.types.5.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man5/printers.conf.5.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/accept.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/cups-lpd.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/cups-polld.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/cupsaddsmb.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/cupsd.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/enable.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/lpadmin.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/lpc.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/lpinfo.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/lpmove.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
        file /usr/share/man/fr/man8/reject.8.bz2 from install of cups-common-1.1.18-1.1mdk conflicts with file from package man-pages-fr-0.9.5-9mdk
ensuite je refais un urpmi --auto-select ... retour au point de depart , 294 mo sauf que la il essaye d'installer direct vu que les paquets sont deja telecharges mais ca bug quand meme !
help
n°238506
Mjules
Parle dans le vide
Posté le 19-03-2003 à 21:12:24  profilanswer
j'ai eu le même pb de conflit entre cups-common et man-page-fr.
la seule solution que j'ai trouvé pour m'en sortir a été de désinstaller man-pages-fr
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°238560
zeb_
Posté le 19-03-2003 à 22:40:46  profilanswer
Dans ce cas, tu peux faire un urpmi --allow-force (c'est comme un --force avec rpm) car ce fichier sera remplacé sans dommages.
Relance avec --noclean, comme ca il ne retéléchargera pas les paquets (ils sont toujours dans ton cache).
n°238939
piloud
Posté le 20-03-2003 à 20:34:54  profilanswer
le force ca marche , merci :)
n°238973
zeb_
Posté le 20-03-2003 à 22:52:46  profilanswer
Le --force est très déconseillé sauf quand on est sûr. Là le problème concernait des doublons dans les pages de manuels (man), donc là le risque n'était pas très élevé.  :hello:
  Installation
Quelles sources urpmi utiliser avec mandrake 9.1 béta ?urpmi (install paquetage) :"Tout a deja été installé"...alors que non!
apt-get dist-upgrade et urpmi --auto-selecturpmi et acces ftp a travers un firewall
MDK9 : Vous utilisez quoi comme ftp pour urpmi?ping qui foire et lenteur d'accès à mon serveur
le kernel 2.4 il foire sur les nforces ?[linux] ls sur cd qui foire ...
urpmi, ca marche bien ?Petit probléme URPMI (mandrake)
Plus de sujets relatifs à : apres un urpmi de 294 mo.... ca foire :(
