2603 connectés
  Linux et OS Alternatifs
  Problème avec Gphoto et HP PhotoSmart 735
n°427388
jyp
>-<o>-<
Posté le 08-03-2004 à 20:41:19  profilanswer
Je n'arrive à transferer mes photos!
Avec gtkam, je les vois, je peux les avoir en grand mais pas à les sauvegarder
Avec la commande : env LANG=C gphoto2 --debug -P
J'ai ce message :
0.000161 main(2): TOUJOURS FOURNIR LES LIGNES CI-DESSOUS LORS DE L'ENVOI DE MESSAGE(S) DE DÉBOGAGE À LA LISTE DE DIFFUSION :
0.000297 main(2): gphoto2 2.1.4
0.000310 main(2): gphoto2 has been compiled with the following options:
0.000321 main(2):  + gcc (C compiler used)
0.000331 main(2):  + popt (for handling command-line parameters)
0.000342 main(2):  + exif (for displaying EXIF information)
0.000352 main(2):  + cdk (for accessing configuration options)
0.000363 main(2):  + aa (for displaying live previews)
0.000373 main(2):  + jpeg (for displaying live previews in JPEG format)
0.000383 main(2):  + readline (for easy navigation in the shell)
0.000402 main(2): libgphoto2 2.1.4
0.000414 main(2): libgphoto2 has been compiled with the following options:
0.000425 main(2):  + gcc (C compiler used)
0.000437 main(2):  + EXIF (for special handling of EXIF files)
0.000447 main(2):  + no ltdl (working around buggy libltdl, eh? :-)
0.000458 main(2):  + /proc/meminfo (adapts cache size to memory available)
0.000475 main(2): libgphoto2_port 0.5.1
0.000486 main(2): libgphoto2_port has been compiled with the following options:
0.000497 main(2):  + gcc (C compiler used)
0.000507 main(2):  + USB (for USB cameras)
0.000517 main(2):  + serial (for serial cameras)
0.000527 main(2):  + no resmgr (serial port access and locking)
0.000537 main(2):  + no baudboy (serial port locking)
0.000547 main(2):  + no ttylock (serial port locking)
0.000558 main(2):  + no lockdev (serial port locking)
0.000568 main(2):  + no ltdl (working around buggy libltdl, eh? :-)
0.000670 main(2): The user has not specified both a model and a port. Try to figure them out.
0.000711 gp-port-info-list(2): Loading io-drivers from '/usr/lib/gphoto2_port/0.5.1'...
0.001047 gphoto2-port-core(2): Loaded 'Universal Serial Bus' (usb:) from 'libgphoto2_port_usb.so'
0.001191 gphoto2-port-serial(2): Trying to lock '/dev/tts/0'...
0.001364 gphoto2-port-serial(2): Trying to lock '/dev/tts/1'...
0.001522 gphoto2-port-serial(2): Trying to lock '/dev/tts/2'...
0.005945 gphoto2-port-serial(2): Trying to lock '/dev/tts/3'...
0.009888 gphoto2-port-serial(2): Trying to lock '/dev/tts/4'...
0.067511 gphoto2-port-serial(2): Trying to lock '/dev/tts/5'...
0.073245 gphoto2-port-serial(2): Trying to lock '/dev/tts/6'...
0.077165 gphoto2-port-serial(2): Trying to lock '/dev/tts/7'...
0.083140 gphoto2-port-serial(2): Trying to lock '/dev/tts/8'...
0.087028 gphoto2-port-serial(2): Trying to lock '/dev/tts/9'...
0.091030 gphoto2-port-serial(2): Trying to lock '/dev/tts/10'...
0.095281 gphoto2-port-serial(2): Trying to lock '/dev/tts/11'...
0.099924 gphoto2-port-serial(2): Trying to lock '/dev/tts/12'...
0.104607 gphoto2-port-serial(2): Trying to lock '/dev/tts/13'...
0.108601 gphoto2-port-serial(2): Trying to lock '/dev/tts/14'...
0.112496 gphoto2-port-serial(2): Trying to lock '/dev/tts/15'...
0.116478 gphoto2-port-serial(2): Trying to lock '/dev/tts/16'...
0.120848 gphoto2-port-serial(2): Trying to lock '/dev/tts/17'...
0.124956 gphoto2-port-serial(2): Trying to lock '/dev/tts/18'...
0.130652 gphoto2-port-serial(2): Trying to lock '/dev/tts/19'...
0.135033 gphoto2-port-serial(2): Trying to lock '/dev/tts/20'...
0.139102 gphoto2-port-serial(2): Trying to lock '/dev/tts/21'...
0.143448 gphoto2-port-serial(2): Trying to lock '/dev/tts/22'...
0.147332 gphoto2-port-serial(2): Trying to lock '/dev/tts/23'...
0.151252 gphoto2-port-serial(2): Trying to lock '/dev/tts/24'...
0.155906 gphoto2-port-serial(2): Trying to lock '/dev/tts/25'...
0.160038 gphoto2-port-serial(2): Trying to lock '/dev/tts/26'...
0.165587 gphoto2-port-serial(2): Trying to lock '/dev/tts/27'...
0.171350 gphoto2-port-serial(2): Trying to lock '/dev/tts/28'...
0.175249 gphoto2-port-serial(2): Trying to lock '/dev/tts/29'...
0.179746 gphoto2-port-serial(2): Trying to lock '/dev/tts/30'...
0.235827 gphoto2-port-serial(2): Trying to lock '/dev/tts/31'...
0.240007 gphoto2-port-serial(2): Trying to lock '/dev/tts/32'...
0.243967 gphoto2-port-core(2): Loaded 'Port série 0' (serial:/dev/tts/0) from 'libgphoto2_port_serial.so'
0.244033 gphoto2-port-core(2): Loaded 'Port série 1' (serial:/dev/tts/1) from 'libgphoto2_port_serial.so'
0.244068 gphoto2-port-core(2): Loaded '' (^serial) from 'libgphoto2_port_serial.so'
0.244656 gphoto2-port-info-list(2): Counting entries (4 available)...
0.244712 gphoto2-port-info-list(2): 3 regular entries available.
0.244724 gphoto2-port(2): Creating new device...
0.244755 gphoto2-port-info-list(2): Getting info of entry 0 (4 available)...
0.245507 gphoto2-port(2): Setting timeout to 5000 millisecond(s)...
0.245550 gphoto2-port(2): Setting settings...
0.245564 gphoto2-abilities-list.c(1): Auto-detecting USB cameras...
0.245650 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245675 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x6bd, produit 0x403). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245695 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x6bd, produit 0x404). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245716 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245736 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245756 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245776 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245796 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245817 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245837 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245857 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245877 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a5, produit 0x3003). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245897 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3047). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245917 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3072). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245937 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x304d). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245957 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3066). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245976 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3075). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.245996 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3075). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246016 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x309b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246036 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3072). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246056 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3052). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246076 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3065). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246096 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3070). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246143 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3071). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246163 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246183 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3083). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246202 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3084). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246222 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3099). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246242 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3044). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246261 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3060). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246281 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3084). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246301 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3099). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246321 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3084). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246341 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3099). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246361 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3046). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246380 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x304b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246400 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x307b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246420 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246439 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3081). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246459 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x307f). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246479 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246499 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x304f). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246518 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3061). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246538 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x304e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246558 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3062). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246578 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3059). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246597 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3076). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246617 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3058). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246637 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3074). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246672 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3074). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246691 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3073). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246711 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3073). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246731 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x309a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246751 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x309a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246770 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3048). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246790 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3055). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246810 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246830 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306f). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246850 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3085). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246869 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3085). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246889 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3049). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246909 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3041). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246929 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3045). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246948 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3051). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246968 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3043). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.246988 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3065). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247008 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3070). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247027 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3071). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247047 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3057). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247067 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x304c). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247087 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3056). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247106 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3075). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247126 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306c). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247146 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x306d). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247165 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3077). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247198 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3072). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247218 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3050). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247237 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x305c). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247257 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x307a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247277 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4a9, produit 0x3078). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247296 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xc200). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247317 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247337 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247357 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247376 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3e8, produit 0x2182). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247396 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247416 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x41e, produit 0x400a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247436 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x41e, produit 0x400b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247456 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x84d, produit 0x3). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247475 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd64, produit 0x1021). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247495 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247515 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.247535 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248000 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x5da, produit 0x1020). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248024 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248044 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248064 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b8, produit 0x403). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248085 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b8, produit 0x402). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248105 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xdca, produit 0x2). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248125 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xdca, produit 0x2). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248145 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248166 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248203 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248223 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248243 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x797, produit 0x801c). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248262 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248282 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248302 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6502). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248322 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6302). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248342 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6602). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248362 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x7202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248382 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6302). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248401 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6802). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248421 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6402). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248441 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6702). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248461 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6a02). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248481 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x4202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248500 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x4302). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248520 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x4402). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248540 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x4102). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248560 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248580 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x784, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248600 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x3300). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248620 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248640 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x5da, produit 0x1006). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248660 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x0). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248679 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248699 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x84e, produit 0x1). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248731 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x560). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248751 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x565). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248771 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x535). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248791 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x566). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248811 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x574). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248831 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x573). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248851 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x571). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248871 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248891 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248910 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x121). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248930 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x110). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248950 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x111). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248970 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x130). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.248989 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x112). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249009 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x132). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249029 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x160). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249049 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x131). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249069 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x525). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249088 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x500). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249143 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x510). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249164 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x530). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249183 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x170). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249203 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x555). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249223 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x576). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249242 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x550). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249262 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x570). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249294 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x572). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249314 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x575). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249334 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x540). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249353 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x568). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249373 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x569). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249393 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x40a, produit 0x400). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249413 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4c8, produit 0x722). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249433 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x46d, produit 0x950). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249453 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249473 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x3300). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249493 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249512 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249532 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249551 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249571 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249591 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4102). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249611 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249631 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x84d, produit 0x3). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249650 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249670 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249690 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xc200). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249709 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xa350). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249729 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xc220). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249749 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xc420). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249769 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x55f, produit 0xc520). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249789 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x302). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249808 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x117). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249840 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x109). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249860 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x115). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249880 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x111). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249900 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x10f). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249919 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x10b). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249939 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x113). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249959 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x119). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249979 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x10d). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.249999 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x103). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250019 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x112). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250039 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x102). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250059 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x104). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250078 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250098 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4b0, produit 0x402). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250118 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250138 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250158 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250178 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250198 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250218 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250237 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250257 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x114). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250277 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250297 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250317 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250337 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x105). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250371 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x114). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250392 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x7b4, produit 0x114). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250411 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250431 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250452 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250472 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250492 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250512 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x784, produit 0x2888). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250532 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x546, produit 0xdaf). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250552 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250572 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x784, produit 0x5300). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250591 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250611 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xdca, produit 0x4). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250631 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x784, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250650 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x5ca, produit 0x2204). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250670 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x5ca, produit 0x2208). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250690 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x5ca, produit 0x2202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250712 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x797, produit 0x8901). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250732 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x797, produit 0x8909). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250752 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x797, produit 0x8911). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250771 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x84d, produit 0x1001). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250791 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250811 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x851, produit 0x1542). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250831 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xc77, produit 0x1011). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250851 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xc77, produit 0x1002). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250870 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xc77, produit 0x1010). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250890 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd64, produit 0x1001). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250921 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xc77, produit 0x1001). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250940 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x3300). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250960 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xdca, produit 0x2). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.250980 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xec7, produit 0x1008). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251000 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251020 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251054 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251075 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251095 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251114 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251134 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251154 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251173 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251193 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251213 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251232 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251252 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251272 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x54c, produit 0x4e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251292 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251312 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251331 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251351 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251371 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251390 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x2770, produit 0x9120). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251410 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251430 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251461 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251481 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x919, produit 0x100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251501 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251520 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x1132, produit 0x4337). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251540 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x3300). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251560 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd96, produit 0x4100). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251579 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x84d, produit 0x3). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251599 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x6d6, produit 0x2e). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251619 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x6d6, produit 0x2d). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251639 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x4fc, produit 0x504a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251659 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x797, produit 0x801a). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251678 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x553, produit 0x202). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251698 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0xd64, produit 0x1001). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251757 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x6, sous-classe 0xffffffff, produit 0xffffffff). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.251782 gphoto2-port-info-list(2): Getting info of entry 1 (4 available)...
0.252044 gphoto2-port(2): Setting timeout to 500 millisecond(s)...
0.252063 gphoto2-port(2): Setting settings...
0.252075 gphoto2-port-info-list(2): Getting info of entry 2 (4 available)...
0.252152 gphoto2-port(2): Setting timeout to 500 millisecond(s)...
0.252168 gphoto2-port(2): Setting settings...
0.252187 gphoto2-port(2): Freeing port...
0.252206 gphoto2-port(2): Closing port...
0.252253 setting/gphoto2-setting.c(2): Creating $HOME/.gphoto
0.252404 setting/gphoto2-setting.c(2): Loading settings from file "/home/jyp/.gphoto/settings"
0.252521 gphoto2-camera(2): Setting abilities ('HP PhotoSmart 735 (PTP mode)')...
0.253049 gphoto2-setting(2): Setting key 'model' to value 'HP PhotoSmart 735 (PTP mode)' (gphoto2)
0.253079 gphoto2-setting(2): Saving 8 setting(s) to file "/home/jyp/.gphoto/settings"
0.253279 gp-port-info-list(2): Loading io-drivers from '/usr/lib/gphoto2_port/0.5.1'...
0.253595 gphoto2-port-core(2): Loaded 'Universal Serial Bus' (usb:) from 'libgphoto2_port_usb.so'
0.253729 gphoto2-port-serial(2): Trying to lock '/dev/tts/0'...
0.253825 gphoto2-port-serial(2): Trying to lock '/dev/tts/1'...
0.253977 gphoto2-port-serial(2): Trying to lock '/dev/tts/2'...
0.257932 gphoto2-port-serial(2): Trying to lock '/dev/tts/3'...
0.261797 gphoto2-port-serial(2): Trying to lock '/dev/tts/4'...
0.266120 gphoto2-port-serial(2): Trying to lock '/dev/tts/5'...
0.271650 gphoto2-port-serial(2): Trying to lock '/dev/tts/6'...
0.277015 gphoto2-port-serial(2): Trying to lock '/dev/tts/7'...
0.281800 gphoto2-port-serial(2): Trying to lock '/dev/tts/8'...
0.285696 gphoto2-port-serial(2): Trying to lock '/dev/tts/9'...
0.290521 gphoto2-port-serial(2): Trying to lock '/dev/tts/10'...
0.294633 gphoto2-port-serial(2): Trying to lock '/dev/tts/11'...
0.298608 gphoto2-port-serial(2): Trying to lock '/dev/tts/12'...
0.302510 gphoto2-port-serial(2): Trying to lock '/dev/tts/13'...
0.307157 gphoto2-port-serial(2): Trying to lock '/dev/tts/14'...
0.311193 gphoto2-port-serial(2): Trying to lock '/dev/tts/15'...
0.315484 gphoto2-port-serial(2): Trying to lock '/dev/tts/16'...
0.319462 gphoto2-port-serial(2): Trying to lock '/dev/tts/17'...
0.323523 gphoto2-port-serial(2): Trying to lock '/dev/tts/18'...
0.327396 gphoto2-port-serial(2): Trying to lock '/dev/tts/19'...
0.333380 gphoto2-port-serial(2): Trying to lock '/dev/tts/20'...
0.337259 gphoto2-port-serial(2): Trying to lock '/dev/tts/21'...
0.342621 gphoto2-port-serial(2): Trying to lock '/dev/tts/22'...
0.346513 gphoto2-port-serial(2): Trying to lock '/dev/tts/23'...
0.350436 gphoto2-port-serial(2): Trying to lock '/dev/tts/24'...
0.354911 gphoto2-port-serial(2): Trying to lock '/dev/tts/25'...
0.359533 gphoto2-port-serial(2): Trying to lock '/dev/tts/26'...
0.363488 gphoto2-port-serial(2): Trying to lock '/dev/tts/27'...
0.367386 gphoto2-port-serial(2): Trying to lock '/dev/tts/28'...
0.371488 gphoto2-port-serial(2): Trying to lock '/dev/tts/29'...
0.377011 gphoto2-port-serial(2): Trying to lock '/dev/tts/30'...
0.433217 gphoto2-port-serial(2): Trying to lock '/dev/tts/31'...
0.437131 gphoto2-port-serial(2): Trying to lock '/dev/tts/32'...
0.441144 gphoto2-port-core(2): Loaded 'Port série 0' (serial:/dev/tts/0) from 'libgphoto2_port_serial.so'
0.441209 gphoto2-port-core(2): Loaded 'Port série 1' (serial:/dev/tts/1) from 'libgphoto2_port_serial.so'
0.441221 gphoto2-port-core(2): Loaded '' (^serial) from 'libgphoto2_port_serial.so'
0.441365 gphoto2-port-info-list(2): Looking for path 'usb:' (4 entries available)...
0.441404 gphoto2-port-info-list(2): Getting info of entry 0 (4 available)...
0.441444 gphoto2-camera(2): Setting port info for port 'Universal Serial Bus' at 'usb:'...
0.442074 gphoto2-port(2): Setting timeout to 5000 millisecond(s)...
0.442109 gphoto2-port(2): Setting settings...
0.442123 gphoto2-setting(2): Setting key 'port' to value 'usb:' (gphoto2)
0.442141 gphoto2-setting(2): Saving 8 setting(s) to file "/home/jyp/.gphoto/settings"
0.444506 gphoto2-camera(2): Listing files in '/'...
0.444585 gphoto2-camera(2): Initializing camera...
0.444681 gphoto2-port(0): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6a02). Assurez-vous qu'il est bien connecté à l'ordinateur.
0.444765 context(0): Une erreur est intervenue dans la bibliothèque d'entrée-sortie ('Mauvais paramètres'): Impossible de trouver le périphérique USB (fabricant 0x3f0, produit 0x6a02). Assurez-vous qu'il est bien connecté à l'ordinateur.
*** Erreur ***
*** Erreur (-2: 'Mauvais paramètres') ***
Message édité par jyp le 08-03-2004 à 20:42:20
Jyp
n°428458
jyp
>-<o>-<
Posté le 10-03-2004 à 10:13:36  profilanswer
up
[Gentoo] Problème de /sbin/agetty après installation ...[Debian] Problème de partitions
probleme d'istalation xvid4configprobleme avec la commande "tar"...
problème sur partitions reiserfs[debian] Problème de son en user
Knoppix 3.2 et 3.3 probleme récurent help please :([ Logiciels ] Problème de gravure avec K3B (cdrecord)
[Debian et autre] problème'tit problème de caractère accentué avec Mozilla...
Plus de sujets relatifs à : Problème avec Gphoto et HP PhotoSmart 735
