6198 connectés
  Linux et OS Alternatifs
  Codes et scripts
  probleme montage repertoire linux sous poste travail XP
n°828735
munkycool
tu rends compte !!!!
Posté le 20-07-2006 à 19:31:09  profilanswer
Bonjour à tous, j'ai un petite souci de l'ordre de point de montage.
j'ai crée un serveur sous Suse 10.1 et je suis en train de configurer SAMBA, pour partager des répertoires sous un environnements windows.
Mon nom de domaine est SIEGE et netbios est: Srvaycad.
Voici mon script de démarrage, logon.bat :
net use z: \\siege\home\%USERNAME%
net use u: \\siege\home\samba\aycad
net use v: \\siege\home\samba\teamgreen
le répertoire de l'utilisateurs se monte bien mais pas les deux autres.
Voici mon smb.conf:
# smb.conf is the main Samba configuration file. You find a full commented
# version at /usr/share/doc/packages/samba/examples/smb.conf.SUSE if the
# samba-doc package is installed.
# Date: 2006-05-02
[global]
 workgroup = SIEGE
 printing = cups
 printcap name = cups
 printcap cache time = 750
 cups options = raw
 map to guest = Bad User
 include = /etc/samba/dhcp.conf
 logon path = \\%L\profiles\.msprofile
 logon home = \\%L\%U\.9xprofile
 logon drive = P:
 add machine script = /usr/sbin/useradd  -c Machine -d /var/lib/nobody -s /bin/false %m$
 domain logons = Yes
 logon script = logon.bat
 domain master = Yes
 local master = Yes
 os level = 65
 passdb backend = smbpasswd
 preferred master = Yes
 security = user
 netbios name = SRVAYCAD
[homes]
 comment = Home Directories
 valid users = %S, %D%w%S
 browseable = No
 read only = No
 inherit acls = Yes
[profiles]
 comment = Network Profiles Service
 path = %H
 read only = No
 store dos attributes = Yes
 create mask = 0600
 directory mask = 0700
[users]
 comment = All users
 path = /home
 read only = No
 inherit acls = Yes
 veto files = /aquota.user/groups/shares/
[groups]
 comment = All groups
 path = /home/groups
 read only = No
 inherit acls = Yes
[printers]
 comment = All Printers
 path = /var/tmp
 printable = Yes
 create mask = 0600
 browseable = No
[print$]
 comment = Printer Drivers
 path = /var/lib/samba/drivers
 write list = @ntadmin root
 force group = ntadmin
 create mask = 0664
 directory mask = 0775
[netlogon]
 comment = Network Logon Service
 path = /var/lib/samba/netlogon
 write list = root
[aycad]
 inherit acls = Yes
 path = /home/samba
 read only = No
 directory mask = 777
[teamgreen]
 inherit acls = Yes
 path = /home/samba
 read only = No
[commun]
 inherit acls = Yes
 path = /home/samba
 read only = No
Merci pour votre aide et si vous avez des tuto pour SUSE 10.1 aussi  ;)
Message édité par munkycool le 20-07-2006 à 22:10:44
n°828775
munkycool
Posté le 20-07-2006 à 22:13:38  profilanswer
petit UP merci !!
n°828807
Zzozo
Un peu, passionément, à la fol
Posté le 20-07-2006 à 23:24:03  profilanswer
je pense que tu voulais écrire
net use u: \\SRVAYCAD\aycad
net use v: \\SRVAYCAD\teamgreen
au lieu de
non ?  :??:
Enfin, d'après ce que je lis rapidement dans ton fichier de conf
C'est normal, que le partages aycad et teamgreen pointent sur le même répertoire (à savoir /home/samba, toujours d'après ce que je lis dans ton fichier de conf ) ?
« Ce qui ne vous tue pas vous rend plus fort » F. Nietzsche | « Vise_ la Lune. Si tu rates, au pire, t'es dans la merde » Un poète disparu dans le cercle
n°828818
munkycool
Posté le 20-07-2006 à 23:46:46  profilanswer
au lieu de
non ?  :??:
tout d'abord merci pour ta réponse
pour le montage des répertoires je vais essayer
par contre pour le chemin de aycad et temagreen je ne comprend pas j'ai pourtant crée avec Samba et non à la main donc cela devrait être juste ?
je vais corriger aussi pour voir.
Encore merci
n°829180
munkycool
Posté le 22-07-2006 à 16:47:12  profilanswer
Par contre quelqu'un peut m'expliquer comment mettre un script de connexion à tout un groupe de travail ?
Merci d'avance
n°829187
munkycool
Posté le 22-07-2006 à 18:42:08  profilanswer
Re-bonjour pour le srcipt c'est bon tout marche bien.
Par contre maintenant il me demande le mot de passe de Srvaycad pour que je puisse connecter un utilisateur à un des répertoires ??
De quoi cela peut venir ? Comment enlever ce mot de passe ?
Merci de votre réponse
Message édité par munkycool le 22-07-2006 à 22:10:16
n°829267
munkycool
Posté le 23-07-2006 à 11:45:00  profilanswer
Petit UP de la matinée
n°829342
Zzozo
Posté le 23-07-2006 à 19:20:39  profilanswer
Tu veux que tout le monde puisse accéder aux partages, sur le serveur Samba, sans décliner son identité, c'est bien ça ?
n°829404
munkycool
Posté le 23-07-2006 à 23:31:08  profilanswer
non pas pour tout le monde; seulement le groupe auquel j'ai attribué ou à l'utilisateur auquel je veux monter le répertoire, mais qu'il n'y est pas besoin de demander un mot de passe por le connecter.
n°829407
Zzozo
Posté le 23-07-2006 à 23:48:03  profilanswer
il te le demande une fois ton mdp ?
n°829445
munkycool
Posté le 24-07-2006 à 01:41:51  profilanswer
il me demande ce mot de passe lors de l'éxécution du script: "login Srvaycad" et ensuite le mot de passe.
n°829677
munkycool
Posté le 24-07-2006 à 18:47:15  profilanswer
Up
n°829739
munkycool
Posté le 24-07-2006 à 22:01:16  profilanswer
Up
n°829780
munkycool
Posté le 25-07-2006 à 00:45:21  profilanswer
Up
n°829994
munkycool
Posté le 25-07-2006 à 18:21:57  profilanswer
Bonjour, petit up
n°830347
munkycool
Posté le 26-07-2006 à 23:06:47  profilanswer
UP
n°830541
munkycool
Posté le 27-07-2006 à 15:38:52  profilanswer
UP
n°830566
Zzozo
Posté le 27-07-2006 à 17:08:01  profilanswer
Les utilisateurs sont authentifiés sur un "domaine windows" ?
n°830842
munkycool
Posté le 28-07-2006 à 15:58:38  profilanswer
Non les utilisateurs s'authentifient sur un contrôleur de domaine SAMBA, le domaine se nomme "siege".
Par contre les postes clients sont sous Windows XP.
Ma distrib est une Suse 10.1 pour le serveur.
n°830854
Zzozo
Posté le 28-07-2006 à 16:45:01  profilanswer
et ce controleur de domaine Samba, c'est Srvaycad ?
n°830885
munkycool
Posté le 28-07-2006 à 19:09:16  profilanswer
non c'est "siege", srvaycad est le nom du serveur.
n°831502
munkycool
Posté le 31-07-2006 à 19:56:54  profilanswer
Up merci !!
n°831818
munkycool
Posté le 02-08-2006 à 02:38:22  profilanswer
Petit UP  merci de m'aider.
n°948607
Philoo31
Posté le 31-08-2007 à 11:20:22  profilanswer
Je comprend pas bien sur quel tuto tu t'es basé, c'est izarre tes path dans les partages...
Je pense qu'il faut que tu partes sur une config du smb.conf dans ce type plutôt
[global]
        logon drive = Z:
        logon path = \\%L\profiles\%U
[homes]
        comment = Repertoires Homes
        path = /home/samba/homes/%U
        guest ok = no
        browseable = no
        writeable = yes
        create mode = 0700
[profiles]
       path = /home/samba/profiles
       read only = No
       writeable = Yes
       create mode = 0600
       directory mode = 0700
       browseable = No
       guest ok = No
       profile acls = Yes
Et pour le logon.bat tu n'auras plus qu'un truc du type :
@echo off
net time \\SRVAYCAD /set /yes
cls
En fait si il te demande un mot de passe c'est à cause de ça :
Il faut que ce soit samba lors de l'authentification qui monte le partage (comme montré dans la config du smb.conf) et non pas le faire faire par le logon.bat.
Je débute aussi mais ça fonctionne nickel comme ça chez moi...
By
Message édité par Philoo31 le 31-08-2007 à 11:59:12
  Codes et scripts
agrandir la partition linux avec un autre disque dur[Résolu] Postfix+postfixadmin+mysql problème d'authentification
probleme déconnection dongle wifi (obliger de débrancher-rebrancher)Problème d'installation de xen 3.0.2 sur ubuntu 6.06 TLS dapper drake
pb scanner sous linuxinstaller des softs et drivers sous mandriva? :) (newbs linux inside)
probleme demarrage serveur x (mais il démmarre avec "startx")probleme installation mandriva linux (prob d'affichage + CG)
Plus de sujets relatifs à : probleme montage repertoire linux sous poste travail XP
