6018 connectés
  Linux et OS Alternatifs
  Codes et scripts
  [gentoo] probleme emerge -u world : Blocked !
n°298412
k666
dites non à petitmou
Posté le 29-07-2003 à 05:06:01  profilanswer
hello
je ne peux plus faire de emerge -u world sous gentoo car il me sort que certains package bloquent d'autres, mais je comprends pas ce qu'il faut faire:
kpoman root # emerge -up world
These are the packages that I would merge, in order:
Calculating world dependencies ...done!
[blocks B    ] <dev-perl/ExtUtils-MakeMaker-6.05-r6 (from pkg dev-lang/perl-5.8.0-r12)
[blocks B    ] <dev-perl/Test-Simple-0.47-r1 (from pkg dev-lang/perl-5.8.0-r12)
[blocks B    ] <dev-perl/File-Spec-0.84-r1 (from pkg dev-lang/perl-5.8.0-r12)
[ebuild    U ] sys-apps/portage-2.0.48-r7 [2.0.48-r5]
*** Portage will stop merging at this point and reload itself,
    recalculate dependencies, and complete the merge.
[ebuild    U ] dev-lang/perl-5.8.0-r12 [5.8.0-r11]
[ebuild    U ] app-emulation/vmware-workstation-4.0.4460-r1 [4.0.4460]
[ebuild    U ] net-analyzer/ethereal-0.9.14 [0.9.13]
[ebuild    U ] app-shells/zsh-4.1.1 [4.1.0_pre7]
[ebuild    U ] media-libs/libmpeg3-1.5.1 [1.5-r1]
[ebuild    U ] sys-devel/binutils-2.14.90.0.5 [2.14.90.0.2]
[ebuild    U ] x11-libs/qt-3.1.2-r5 [3.1.2-r4]
[ebuild    U ] dev-php/mod_php-4.3.2-r4 [4.3.2-r3]
[ebuild    U ] dev-db/phpmyadmin-2.5.2 [2.5.1]
[ebuild    U ] media-sound/xmms-1.2.7-r24 [1.2.7-r22]
[ebuild  N   ] media-libs/libmad-0.15.0b
[ebuild  N   ] media-libs/libid3tag-0.15.0b
[ebuild  N   ] media-sound/madplay-0.15.0b
[ebuild    U ] media-sound/mad-0.15.0b [0.14.2b-r2]
[ebuild    U ] kde-base/arts-1.1.2-r1 [1.1.2]
[ebuild    U ] media-video/mplayer-0.90-r3 [0.90-r2]
[ebuild    U ] net-fs/nfs-utils-1.0.5-r1 [1.0.3]
[ebuild    U ] app-admin/webmin-1.100-r1 [1.100]
[ebuild  N   ] sys-apps/coreutils-5.0-r1
[ebuild    U ] sys-apps/fileutils-4.1.11-r2 [4.1.11-r1]
[ebuild  N   ] dev-libs/fribidi-0.10.4
[ebuild    U ] net-im/centericq-4.9.5-r1 [4.9.5]
[ebuild    U ] sys-apps/parted-1.6.6 [1.6.5]
[ebuild    U ] sys-apps/lilo-22.5.6-r2 [22.5.6-r1]
[ebuild    U ] sys-apps/textutils-2.1-r1 [2.1]
[ebuild    U ] net-print/cups-1.1.19-r1 [1.1.19]
[ebuild    U ] app-text/ghostscript-7.05.6-r3 [7.05.6-r2]
[ebuild    U ] media-gfx/imagemagick-5.5.7-r1 [5.5.7]
[ebuild    U ] app-editors/bluefish-0.10 [0.9]
[ebuild    U ] app-cdr/xcdroast-0.98_alpha14-r1 [0.98_alpha14]
[ebuild    U ] media-sound/soundtracker-0.6.7_pre5 [0.6.6]
[ebuild    U ] sys-devel/gcc-3.2.3-r2 [3.2.3-r1]
[ebuild    U ] app-text/acroread-5.07-r1 [5.07]
[ebuild  N   ] media-sound/speech-tools-1.2.3
[ebuild    U ] media-sound/festival-1.4.3 [1.4.2-r3]
[ebuild    U ] app-arch/zip-2.3-r2 [2.3-r1]
[ebuild    UD] app-office/openoffice-bin-1.0.3.1 [1.1_beta-r1]
[ebuild    U ] sys-apps/sh-utils-2.0.15-r1 [2.0.15]
[ebuild    U ] sys-apps/util-linux-2.12 [2.11z-r7]
[ebuild    U ] sys-apps/reiserfsprogs-3.6.10 [3.6.8]
[ebuild    U ] media-gfx/blender-2.28 [2.27]
[ebuild    U ] sys-apps/kbd-1.08 [1.06-r1]
[ebuild    U ] app-crypt/gnupg-1.2.2-r1 [1.2.2]
[ebuild    U ] net-www/mozilla-1.4-r2 [1.4]
[ebuild    U ] media-video/vlc-0.6.0-r1 [0.6.0]
[ebuild    U ] net-libs/nss_ldap-209.1 [207-r1]
[ebuild    U ] app-misc/gallery-1.3.4 [1.3.3]
[ebuild    U ] app-admin/ufed-0.33 [0.32]
[ebuild    U ] media-video/avifile-0.7.37.20030522-r2 [0.7.37.20030522-r1]
[ebuild    U ] net-im/amsn-0.80 [0.71]
[ebuild    U ] gnome-base/ORBit2-2.6.3 [2.6.2]
[ebuild    U ] x11-plugins/gkrellm-seti-0.7.0b-r1 [0.7.0b]
kpoman root #
si klekun a une idée je suis fort preneur, merci ;)
mangez du mozilla c le futur, c votre DESTIN ! http://www.mozilla.org/releases/
n°298420
Lolo-
Posté le 29-07-2003 à 09:05:58  profilanswer
emerge -u portage
emerge rsync
emerge unmerge dev-perl/ExtUtils-MakeMaker dev-perl/Test-Simple dev-perl/File-Spec
emerge world --deep -upv
si avec ca t'as pas tout cassé  :D
Message édité par Lolo- le 29-07-2003 à 09:07:53
n°298422
sT0ne
Posté le 29-07-2003 à 09:13:50  profilanswer
emerge -C ExtUtils-MakeMaker Test-Simple File-Spec
emerge -u perl ExtUtils-MakeMaker Test-Simple File-Spec
et voili, rien de bien compliqué.
n°298900
farib
Posté le 30-07-2003 à 00:15:15  profilanswer
je fais face à ce probleme et j'applique la solution donnée juste la, mais j'avois ne pas comprendre le pourquoi du commment ( concrètement, ce qu'est un blocage)
n°298913
bobor
tueur de n44b
Posté le 30-07-2003 à 00:41:55  profilanswer
c'est parce que perl intègre ces modules directement dans son ebuid dorénavant. Donc il faut supprimer les anciens modules (blocs) puis emerger perl
Gitan des temps modernes
n°298916
sT0ne
Posté le 30-07-2003 à 00:49:12  profilanswer
Je suis près à parier que dans un avenir proche, portage gérera les Blocks tout seul comme un grand...
n°298917
Threep
I'm a mighty pirate!
Posté le 30-07-2003 à 00:50:22  profilanswer
un blocage, c'est qd deux paquets ne peuvent pas être installés simultanement. Du coup, les deux paquets se bloquent l'un l'autre. Il vaut d'abord en virer un pour installer l'autre.
Pour le cas présent, comme l'a bobor, c'est paske la nouvelle version de perl intègre déjà ces modules.
+ d'infos dans la newsletter gentoo
http://www.gentoo.org/news/en/gwn/ [...] letter.xml
n°298921
farib
Posté le 30-07-2003 à 01:01:33  profilanswer
:jap: merci
  Codes et scripts
problème mandrake 9.1 et clavierProblème pour ouvrir un port sur ma passerelle
Aidez moi, j'ai un problème de dépendances avec ma sid et xfree4.3probleme avec IE : une barre ki veut pas partir
petit problème après install alsa[GENTOO] Carte son compatible - 5.1 ??
probleme de routage[Gentoo] Avoir les droits pour graver
[Noob] Problème : libqt2 ->libqt3SB 128 probleme de config d'Alsa
Plus de sujets relatifs à : [gentoo] probleme emerge -u world : Blocked !
