3415 connectés
  Linux et OS Alternatifs
  Codes et scripts
  probleme de connection a mon srv ftp
n°184170
nikauch
http://nikauch.dyndns.org
Posté le 05-11-2002 à 13:17:05  profilanswer
voila, j utilise proftp et j ai fai des regles iptables mais le probleme est que lorsque mes regles sont active il est impossible de se connecter a mon ftp.
en gros je dois mettre dans filter "input et forward" en accept.
# Generated by iptables-save v1.2.2 on Sat Jan 26 16:02:22 2002
*nat
:PREROUTING ACCEPT [42:4177]
:POSTROUTING ACCEPT [80:6965]
:OUTPUT ACCEPT [83:7557]
-A POSTROUTING -s 192.168.0.0/255.255.255.0 -j MASQUERADE
COMMIT
# Completed on Sat Jan 26 16:02:22 2002
*mangle
:PREROUTING ACCEPT [1179:478951]
:OUTPUT ACCEPT [1173:104477]
COMMIT
*filter
:INPUT ACCEPT [854:419769]
:FORWARD ACCEPT [0:0]
-A INPUT -s 127.0.0.1 -d 127.0.0.1 -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i eth1 -p udp -m udp --sport 68 --dport 67 -j ACCEPT
-A INPUT -i eth1 -p tcp -m tcp --sport 68 --dport 67 -j ACCEPT
-A INPUT -i eth1 -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A INPUT -i eth1 -p tcp -m tcp --sport 67 --dport 68 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --sport 1024:65535 --dport 20 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --sport 1024:65535 --dport 21 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --sport 1024:65535 --dport 22 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --sport 1024:65535 --dport 53 -j ACCEPT
-A INPUT -p udp -m state --state NEW -m udp --sport 1024:65535 --dport 53 -j ACCEPT
-A INPUT -p tcp -m state --state new -m tcp --sport 1024:65535 --dport 80 -j ACCEPT
-A INPUT -p tcp -m state --state new -m tcp --sport 1024:65535 --dport 443 -j ACCEPT
-A INPUT -p udp -m state --state NEW -m udp --sport 1024:65535 --dport 27015 -j ACCEPT
-A INPUT -p tcp -m state --state new -m tcp --sport 1024:65535 --dport 10000 -j ACCEPT
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -s 192.168.0.0/255.255.255.0 -m state --state NEW -j ACCEPT
COMMIT
Moi je ve input et forward en drop !
comment faire?
Message édité par nikauch le 05-11-2002 à 13:18:00
http://nikauch.dyndns.org/board/
  Codes et scripts
Problème de connection internet (Linux Mandrake 9.0) HELP !!!!!problême connection XDM sur terminalX distant...
FreeSco probleme de connection au webpanel[PengAol] Probleme de connection
[SAMBA] probleme de connection... je peux me logguer qu'en guest :/Problème de connection console série en "root"
free> probleme de connectionpop3 : probleme delai de connection depassé avec outlook
[sos newbie idiot][mdk 8.1] speedtouch usb - probleme a la connectionprobleme avec connection SSH....
Plus de sujets relatifs à : probleme de connection a mon srv ftp
