7521 connectés
  Linux et OS Alternatifs
  Codes et scripts
  heartbeat 2 probleme avec le cib.xml
n°965142
maturin6
Posté le 17-10-2007 à 10:37:20  profilanswer
bonjour à tous
j'ai installer sur 2 machine une debian 4 et heartbeat 2.0.7-2.
machine 1 s'appelle debian1 et la 2 debian2
apres avoir lancer heartbeat j'ai ces mesages d'erreurs sur debian1
Oct 17 10:05:48 localhost heartbeat: [16605]: info: Heartbeat generation: 204
Oct 17 10:05:48 localhost heartbeat: [16605]: info: G_main_add_TriggerHandler: Added signal manual handler
Oct 17 10:05:48 localhost heartbeat: [16605]: info: Removing /var/run/heartbeat/rsctmp failed, recreating.
Oct 17 10:05:48 localhost heartbeat: [16605]: info: glib: ucast: write socket priority set to IPTOS_LOWDELAY on eth1
Oct 17 10:05:48 localhost heartbeat: [16605]: info: glib: ucast: bound send socket to device: eth1
Oct 17 10:05:48 localhost heartbeat: [16605]: info: glib: ucast: bound receive socket to device: eth1
Oct 17 10:05:48 localhost heartbeat: [16605]: info: glib: ucast: started on port 694 interface eth1 to 192.168.1.11
Oct 17 10:05:48 localhost heartbeat: [16605]: info: G_main_add_SignalHandler: Added signal handler for signal 17
Oct 17 10:05:48 localhost heartbeat: [16605]: info: Local status now set to: 'up'
debian1:/home/deb1/Desktop# tail /var/log/syslog
Oct 17 10:06:57 localhost crmd: [16720]: info: do_exit:control.c Performing A_EXIT_0 - gracefully exiting the CRMd
Oct 17 10:06:57 localhost cib: [16716]: info: MSG[3] : [cib_callopt=256]
Oct 17 10:06:57 localhost crmd: [16720]: ERROR: do_exit:control.c Could not recover from internal error
Oct 17 10:06:57 localhost cib: [16716]: info: MSG[4] : [cib_clientid=4e8c9143-d123-43cf-b598-240347f55e5a]
Oct 17 10:06:57 localhost crmd: [16720]: WARN: do_exit:control.c Inhibiting respawn by Heartbeat
Oct 17 10:06:57 localhost cib: [16716]: info: MSG[5] : [cib_clientname=16720]
Oct 17 10:06:57 localhost crmd: [16720]: info: do_exit:control.c [crmd] stopped (100)
Oct 17 10:06:57 localhost cib: [16716]: WARN: send_via_callback_channel:callbacks.c Cannot find client for token eb702e76-33da-4828-a3ef-378cc746102b
Oct 17 10:06:57 localhost cib: [16716]: WARN: do_local_notify:callbacks.c A-Sync reply to 16720 failed: client left before we could send reply
Oct 17 10:06:58 localhost attrd: [16719]: info: main:attrd.c Starting mainloop...
 que  faire merci d'avence
  Codes et scripts
probleme de montage dd externe avec knoppix 5.1postfix - problème de header_checks multiple
[QoS] Je ne comprends pas le problèmeProblème avec mplayer (pas de fermeture en fin de traitement de video)
DeepBurner gravure, Problème de DVD-RWprobleme avec Mon et heartbeat
Probleme avec heartbeatprobleme incomprehensible avec Heartbeat
Probleme avec heartbeat - Bide story
Plus de sujets relatifs à : heartbeat 2 probleme avec le cib.xml
