5161 connectés
  Hardware - Périphériques
  Clavier / Souris
  Modèles tapis Everglide
n°24460
Kanzeltar
Posté le 02-11-2003 à 17:31:14  profilanswer
C'est quoi le best Everglide?
Svp répondez moi pas func ou x-board v2 :pt1cable:
Attack:
http://www.bigfootcomputers.com/Merchant2/graphics/00000001/everglide/attoptsmo_tmb.jpg
8" High
10-1/4" Wide
1/4" Deep
Tint: SMOKE
Reactive Agent: 8 Percent Reflective Particles
Enhanced features for optical mice include:
1. complete compatibility with all optics whereas most coloured pads fail
2. improved cordless optical mouse battery life
3. power saving features
Micro-beveled edges so as not to irritate your wrist combined with a circular cutout for wrist placement, a "Space Age Design".
Designed to improve the mousing experience and provide smooth scrolling for everyday use or a serious Frag Fest.  EverGlide gives you the edge over the competition.
The underside has 5 rubber footpads to grip it to your desktop surface and provides a slip resistant experience.
This EverGlide product is washable and can be scrubbed but we're not sure about dishwasher safe =)
Giganta:
http://www.bigfootcomputers.com/Merchant2/graphics/00000001/everglide/gigoptsmo_tmb.jpg
9-1/2" High
11-1/2" Wide
1/4" Deep
Tint: SMOKE
Destruck:
http://www.bigfootcomputers.com/Merchant2/graphics/00000001/everglide/dkt_big.jpg
14" High
17.5" Wide
1/16" (off the desk height)
High Precision Cloth Surface
Suregrip rubber backing to ensure it holds to almost any surface!
Should be just fine for Optical Mice
Long considered an innovator where mouse pads are concerned EverGlide makes some of the best mouse pads available.
Everyday desktop scrolling and tooling around an OS with this mouse pad will seem easier. The slick finished surface makes it easier to maneuver and with more exact movement there is less pressure put on your wrist to move around.
The durability of an EverGlide product combined with it's great mousing surface should make this pad a part of your system for a long time.
Ricochet:
http://www.bigfootcomputers.com/Merchant2/graphics/00000001/everglide/riccblack_big.jpg
Surfaces: DUO-Precision
Surface Dimensions: 290 x 230 mm
Outer Dimensions: 300 x 240 x 2.5 mm
Thickness: 2.52 mm
Available Colors: Magma(Red),Lava (Black), or Ash (White)
Non-slip Feet: 8 each side!
Everglide has done it again, in response to demands from pro-gamers around the world for a slim line (2.52mm) dual surface pad we sent our white coats back to the lab and the Ricochet is the result!
The durable single piece construction makes the pad easy to transport to those essential LAN events without hassle or damage.
Des info sur Ricochet vs Func ?
Message édité par Kanzeltar le 02-11-2003 à 17:37:47
n°24619
Kanzeltar
Posté le 03-11-2003 à 16:00:24  profilanswer
:bounce:
n°24681
FRACTAL
Posté le 03-11-2003 à 21:28:18  profilanswer
il le font plus le blanc special optique ?
n°24684
Kanzeltar
Posté le 03-11-2003 à 21:38:16  profilanswer
Tu veux dire l'Optica ?
Oui mé celui là est carrément hors concours. C'est pour ça que je l'ai pas mentionné:
http://www.bigfootcomputers.com/Merchant2/graphics/00000001/everglide/matopt_tmb.jpg
Beurk  :kaola:
n°24685
FRACTAL
Posté le 03-11-2003 à 21:41:05  profilanswer
il est censé donner les meilleures perfs...
moi j'ai le attack et je l'ai retourné car le milieu glissait beaucoup moins que les cotés a force.
n°24708
Kanzeltar
Posté le 03-11-2003 à 23:02:57  profilanswer
sav everglide ou détaillant ?
n°24712
xice007
Koudy vy îidete?
Posté le 03-11-2003 à 23:13:39  profilanswer
le top:http://www.ldlc.com/fiche/PB00001832.html
n°24718
chaced
Posté le 03-11-2003 à 23:55:46  profilanswer
le large attack, trop petit, le giganta, il y a 2 version, si tu te chope une version non vernis, au bout de 6mois, il sera bon a jeter.
n°24787
Kanzeltar
Posté le 04-11-2003 à 16:29:06  profilanswer
J'ai dit pas de "OMG Everglide S|_|x|3Z Func R|_|L3Z" :fou:
Pour avoir un func jdevrais le faire livrer des States et ca me couterais 40$CAD
Svp s'en tenir au topic.
La seule question que jai posé sur Func c'est comment il se débrouille vs Everglide Ricochet, et pour avoir une réponse éclairée, faut qqun qui a esseyé les 2, pas un fanboy vendu d'avance. :kaola:
Merci  :jap:
Message édité par Kanzeltar le 04-11-2003 à 16:31:02
n°24788
Kanzeltar
Posté le 04-11-2003 à 16:32:35  profilanswer
J'paris que si j'apelle BigFoot Computers (distributeur Everglide au Canada) y vont me dire "euh ? version ? ché po... ça doit être la meilleure (euh?)" :heink:
n°24793
chaced
Posté le 04-11-2003 à 16:43:36  profilanswer
ça se voit quand meme si le tapis est vernis ou pas :d
mais de toute façon, Everglide n'a plus la superbe du debut ou ils etaient les seul :d
n°24795
Kanzeltar
Posté le 04-11-2003 à 16:52:18  profilanswer
Les achats sont online, t'a la surprise en ouvrant la boîte :pt1cable:
n°24803
chaced
Posté le 04-11-2003 à 16:59:14  profilanswer
et si il n'est pas vernis... et hop, un dessous de plat pour la cuisine :lol:
n°24839
Kanzeltar
Posté le 04-11-2003 à 19:21:30  profilanswer
toi t'a quoi ?
n°24840
chaced
Posté le 04-11-2003 à 19:24:17  profilanswer
Kanzeltar a écrit :
toi t'a quoi ?
un Everglide large attack qui est mort, et maintenant, un xboard.
n°24870
nightmare6​82
Posté le 04-11-2003 à 22:49:32  profilanswer
J'ais eu un giganta, il me parraissait verni, il a duré 3 moi.
J'asis un func (ok c pas la marque que tu demandais) depuis 6 moi ps de prob avec.
n°24871
chaced
Posté le 04-11-2003 à 23:00:59  profilanswer
avec des collegues, on aime bien les lans,
Everglide Giganta -> 6mois, HS (avec grosse usure au niveau de la souris)
Everglide LargeAttack vernis -> 1ans, glisse beaucoup moins
Func -> 6 mois, les granulés de glisse ont disparu, il glisse beaucoup moins.
donc, on essye de trouver le tapis ultime qui ne s'use presque pas (a part le truc en verre :d)
n°24965
nightmare6​82
Posté le 05-11-2003 à 15:28:21  profilanswer
Je suis sur mon func depus 6 moi avec un sensi super basse (1.3) donc beaucoup de mouvement et pas de probs, mais je joues sur le coté lisse aussi, pour l'auter côté je ne sais pas.
Pour améliorer la glisse, je met des bout de scotch sous les patin de la souris, ça marche pas mal et c'est vite changé une foi usé.  :D
Quand je'avais mon func, je devait avoir une sensi au moins deux foi supérieur, donc moins de mouvements, et ça ne l'a pas empeché de me lacher apres 3 mois, donc pour moi everglide poubelle (à moins que j'entende partout qu'is ont sortit un new tapi qui fait l'unanimité, chui pas borné non plus :D )
Message édité par nightmare682 le 05-11-2003 à 15:30:53
n°24968
chaced
Posté le 05-11-2003 à 15:46:38  profilanswer
avec le XBoard, ils livrent 2 bandes de teflon :d
http://chaced.free.fr/photo/hardwarefr/patins.jpg
n°25007
nightmare6​82
Posté le 05-11-2003 à 18:46:37  profilanswer
Oui ça j'ais vu et ça m'a l'air pas mal, mais on peut pas acheter le teflon tout seul sans la tapis ???  :D
n°25013
chaced
Posté le 05-11-2003 à 19:04:57  profilanswer
si, ça s'apelle les Everglide Mouse Skatez.
n°25015
Kanzeltar
Posté le 05-11-2003 à 19:16:04  profilanswer
On dirait que personne connait le Ricochet ? :(
n°25017
chaced
Posté le 05-11-2003 à 19:21:12  profilanswer
http://www.nokytech.net/actualites/2947.html
n°25051
Kanzeltar
Posté le 05-11-2003 à 22:35:19  profilanswer
Heh exactement ce que j'veux pas voir: une gang de fanboys qui regardent l'image et disent "bah, de toute façon, mon func d'amour est surement meilleur"
Comparatifs avec tests à l'appuie svp!!! :sarcastic:
Les reviews je les trust plus ou moins parce que la plupart du temps elles sont faites par des sites qui vendent la cam en question (la plupart des reviews sur le Ricochet sont élogieuses) :pt1cable:
  Clavier / Souris
Cherche site avec premieres modeles de tft sonyDépartager moi entre ces 2 modeles !
Tapis de souris Ratpadz ?[Tapis Souris] Xboard V2 : Languette ?
Tapis de souris de gamer?[ecrans] choix TFT 15 pouces, modeles ViewSonic
Tapis de souris : Func ou Everglide ?Tapis de souris pour souris optique sans fil
Cherche tapis pour souris optique
Plus de sujets relatifs à : Modèles tapis Everglide
