3242 connectés
Sujet : formatage bas niveau : qu est ce que c est ??
sara merci à tous !
j'avais pas envie d'être bête meme si la question pouvait faire tache !
sara
sara merci à tous !
sara
hardcoregamer kelkes infos
As I have said (probably too often, sorry) modern drives do not need to be low-level formatted by the end user, and in fact cannot be LLFed outside the factory due to their precision and complexity. However, it seems that the need to LLF hard disks on the part of users has never gone away. Like some primordial instinct, many PC users seem to have a fundamental desire to LLF their modern disks. Maybe it is built into the genetic code in some way yet undiscovered. ;^) In fact, even if it were possible, the vast majority of the time that someone "needs" to LLF a hard disk today, it is not really necessary. Many users jump quickly to wanting to try an "LLF" whenever they have a problem with their hard disk, much the way many jump to re-installing their operating system whenever it gives them trouble.
Hard drive manufacturers have created for modern drives replacements for the old LLF utilities. They cause some confusion, because they are often still called "low-level format" utilities. The name is incorrect because, again, no utility that a user can run on a PC can LLF a modern drive. A more proper name for this sort of program is a zero-fill and diagnostic utility. This software does work on the drive at a low level, usually including the following functions (and perhaps others)
aussi, les outils sont specifiques au type de disc , au constructeur etc ...
[jfdsdjhfuetppo]--Message édité par hardcoregamer le 30-04-2002 à 15:24:43--[/jfdsdjhfuetppo]
mechkurt dis donc sara t'as soif d'apprendre en ce moment ;)
power600
ybet a écrit a écrit :
Pire, cette commande est réservée pour les disque durs IDE (en gros inférieur à 540 MB). Le formatage de bas niveaux fait perdre une grosse partie de la capacité des disques durs E-IDE actuels.
Cette commande n'existe plus dans les BIOS depuis déjà quelques années.
:ouch:
Je savais pas ça.... :D
ybet Pire, cette commande est réservée pour les disque durs IDE (en gros inférieur à 540 MB). Le formatage de bas niveaux fait perdre une grosse partie de la capacité des disques durs E-IDE actuels.
power600 Non,c'est autre chose que le FDISK..
Ca réécrit les secteurs,cylindres et tout ça sur le dur et c'est pas conseillé pour les disques durs actuels.
Par contre on peut le tenter quand le disque donne des signes de mort imminente et qu'on a plus rien à perdre,certains ont sauvé leur dur comme ça.
phileg Normalement, l'équivalent du "FDISK" sous DOS ou logiciel du constructeur du DD.
ou comment remettre un DD vierge de toute information, comme neuf. :)
sara merci de m eclairer.
sara
