7144 connectés
Sujet : Sauvegarder une partition ?? ok mais comment
romano http://www.powerquest.com/support/primus/id2245.html
fais une recherche sur NTFS sur leur site
[jfdsdjhfuetppo]--Message édité par romano--[/jfdsdjhfuetppo]
thekiller
panzemeyer a écrit a écrit :
avec Drive Image 5.0 oui
avec Ghost 2002 non
je me disais bien aussi  ;)
et les partitions novell qui a deja reussi ?
[jfdsdjhfuetppo]--Message édité par thekiller--[/jfdsdjhfuetppo]
panzemeyer romano tu peux filer le lien stp, je crois que tu as coupé des extraits (il manque les exemples  :D )
romano avec drive image 5 c'est possible
Solution: Creating or Restoring Images on a Local NTFS Partition or a Hidden Partition
If you use the Browse feature in ImageCenter to browse for the image file source or destination partition, you will notice that no drive letters are displayed for NTFS partitions. This is because DOS can only see and assign drive letters to FAT and FAT32 partitions, not NTFS partitions. For example, ImageCenter would display the following for a computer with two drives, where the first drive contains one FAT partition and two NTFS partitions, and the second drive contains two NTFS partitions:
C:\
\\.\disk1.part2
\\.disk1.part3
\\.disk2.part1
\\.disk2.part2
Consequently, when performing an imaging operation on a partition that is invisible to DOS, you must reference the partition by disk and partition number.
Following are some examples of the command line syntax required to run a script to perform an imaging operation (create or restore) on a local NTFS partition. The same principles apply to performing an imaging operation on a hidden partition. These examples assume that you have already created the necessary script file.
IMPORTANT!  Be sure to place your script file in a location that will not be affected by the imaging process. (For example, do not save the script file on the partition to which you are restoring the image.)
panzemeyer
thekiller a écrit a écrit :
euh sa partition NTFS il peux aussi la ghoster sur du ntfs ?
avec Ghost 2002 non
panzemeyer
seb31 a écrit a écrit :
vi c'est vrai valable aussi pour ghost faut du FAT 16 ou 32
mais justement pour Drive Image c'est faut : seule Ghost pose pb pour restaurer sur du NTFS.
C'est justement l'atout de Drive Image en attendant que Ghost se mette au point.
seb31
l'image du partoche NTFS doit être stocké sur du FAT16 ou FAT32 après il peut la restauré sur n'importe qu'elle type de partition. sinon il prend un DD identique et fais un disk to disk ça va à 600Mo/min 1 DD par port IDE et pas de maitre/slave
thekiller euh sa partition NTFS il peux aussi la ghoster sur du ntfs ?
noelemac Ok merci beaucoup tout le monde pour vos lumière :hello:
seb31
noelemac a écrit a écrit :
Ok donc je vais la metre en fat32.
Mais apres, il est possible de restaurer une partition NTFS ?
bien sûr tu sauvegarde une partion NTFS drive image te cré un fichier PQI sur une partiton FAT32
noelemac Ok donc je vais la metre en fat32.
thekiller Drive Image 5
seb31
Ok pour drive image5.
MAis j'ai fait une recherche sur le forum (eh oui ! ;) ) et y'a des personne qui on des pb car il parait qu'n ne peut pas sauvegarder l'image sur une partition NTFS.
C'est vrai ca ?
seb31
romano a écrit a écrit :
j'ai les deux et je prefere PQDI
moi aussi au moins je vois clairement ce que je fais et à la fin j'ai une résumé de l'opération
noelemac Ok pour drive image5.
Mais j'ai fait une recherche sur le forum (eh oui ! ;) ) et y'a des personnes qui on des pb car il parait qu'on ne peut pas sauvegarder l'image sur une partition NTFS.
C'est vrai ca ?
[jfdsdjhfuetppo]--Message édité par noelemac--[/jfdsdjhfuetppo]
seb31
mouyou a écrit a écrit :
ghost...
ghost à chier [:vomi]
romano j'ai les deux et je prefere PQDI
mouyou ghost...
romano Drive Image 5 (image)
noelemac Voila, j'ai une partition C: avec windows dessu.
J'aimerait la sauvegarder sur une autre partition au cas ou...
Avec quel logiciel puis-je faire ca ?
Faut faire une copie ou une image ?
Je précise que toutes mes partition son en NTFS et je tourne avec windows XP.
Merci pour votre aide
