5140 connectés
Sujet : DRIVER_IRQL_NOT_LESS_OR_EQUAL ---> ????????? kesako
cpulloverclock
Kulte a écrit a écrit :
Lut tout le monde
J ai un ecran bleu qd je redemarre Windows xp ki me dit ca....
vous pour vez m aider svp ?
K.
tas oc?
cpulloverclock
Lut tout le monde
K.
tas oc?
[dufff]hide
deuf a écrit a écrit :
Stop 0x000000D1 or DRIVER_IRQL_NOT_LESS_OR_EQUAL
The Stop 0xD1 message indicates that the system attempted to access pageable memory using a kernel process IRQL that was too high. Drivers that have used improper addresses typically cause this error.
Interpreting the Message
This Stop message has four parameters:
Memory referenced.
IRQL at time of reference.
Type of access (0x00000000 = read operation, 0x00000001 = write operation).
Address that referenced memory.
Resolving the Problem
For additional troubleshooting suggestions that apply to all Stop errors, see "Stop Message Checklist" later in this appendix.
Stop 0xD1 messages can occur after installing faulty drivers or system services. If a driver is listed by name, disable, remove, or roll back that driver to confirm that this resolves the error. If so, contact the manufacturer about a possible update. Using updated software is especially important for backup programs, multimedia applications, antivirus scanners, DVD playback, and CD mastering tools.
For more information about Stop 0xD1 messages, see the Microsoft Knowledge Base link on the Web Resources page at http://www.microsoft.com/windows/reskits/webresources. Search using keywords winnt, 0x000000D1, and 0xD1
OUAI !
kulte thx
Donc c est un driver ki merde ?
chaud pour trouver lequel c est....
deuf
Lut tout le monde
K.
Memory referenced.
kulte Lut tout le monde
K.
