3226 connectés
  DRIVER_IRQL_NOT_LESS_OR_EQUAL ---> ????????? kesako
n°1068228
kulte
Posté le 05-01-2002 à 19:37:10  profilanswer
Lut tout le monde
J ai un ecran bleu qd je redemarre Windows xp ki me dit ca....
vous pour vez m aider svp ?
K.
n°1068257
deuf
Posté le 05-01-2002 à 19:43:24  profilanswer
Kulte a écrit a écrit :
Lut tout le monde
K.
Stop 0x000000D1 or DRIVER_IRQL_NOT_LESS_OR_EQUAL
The Stop 0xD1 message indicates that the system attempted to access pageable memory using a kernel process IRQL that was too high. Drivers that have used improper addresses typically cause this error.
Interpreting the Message
This Stop message has four parameters:
Memory referenced.
IRQL at time of reference.
Type of access (0x00000000 = read operation, 0x00000001 = write operation).
Address that referenced memory.
Resolving the Problem
For additional troubleshooting suggestions that apply to all Stop errors, see "Stop Message Checklist" later in this appendix.
Stop 0xD1 messages can occur after installing faulty drivers or system services. If a driver is listed by name, disable, remove, or roll back that driver to confirm that this resolves the error. If so, contact the manufacturer about a possible update. Using updated software is especially important for backup programs, multimedia applications, antivirus scanners, DVD playback, and CD mastering tools.
For more information about Stop 0xD1 messages, see the Microsoft Knowledge Base link on the Web Resources page at http://www.microsoft.com/windows/reskits/webresources. Search using keywords winnt, 0x000000D1, and 0xD1
n°1068274
kulte
Posté le 05-01-2002 à 19:49:31  profilanswer
thx
Donc c est un driver ki merde ?
chaud pour trouver lequel c est....
n°1068291
[dufff]hid​e
Posté le 05-01-2002 à 19:54:17  profilanswer
Memory referenced.
OUAI !
n°1068293
cpulloverc​lock
Posté le 05-01-2002 à 19:54:57  profilanswer
Lut tout le monde
K.
tas oc?
Driver + bios 2.3 pour hpt370/372 ...Driver OEMCD001
Logitech cordless optical + Windows XP : pas de driver ?Quel est le meilleur driver pour une GeForce 256 SDRAM sous Win98SE ?
impression avec generic/text only comme driver d'imprimanteActualizer les driver de ma soundblaster 128 PCI
new driver eciDriver pour Scanner et Imprimante sous WinXP!
Quel driver pour V 5 5500Driver graphique sous W2K
Plus de sujets relatifs à : DRIVER_IRQL_NOT_LESS_OR_EQUAL ---> ????????? kesako
