7187 connectés
  CD/DVD/BD
  probleme avec graveur dvd Q28a
n°4462703
Darkblade6​666
Posté le 23-11-2005 à 11:10:26  profilanswer
quand je grave un iso ou un nrg avec nero 7, j ai sa comme ereur
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder:             <SONY DVD RW DW-Q28A>     Version: KYS1 - HA 1 TA 1 - 7.0.1.2
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <TOSHIBA  ODD-DVD SD-M1802>Version: 1030 - HA 1 TA 0 - 7.0.1.2
=== Scsi-Device-Map ===
DiskPeripheral       : WDC WD1200JB-00CRA1           nvatabus Port 1 ID 0  DMA: Off
CdRomPeripheral      : TOSHIBA ODD-DVD SD-M1802      nvatabus Port 1 ID 1  DMA: Off
CdRomPeripheral      : SONY DVD RW DW-Q28A           nvatabus Port 1 ID 2  DMA: Off
CdRomPeripheral      : LITE-ON LTR-52246S            nvatabus Port 1 ID 3  DMA: Off
CdRomPeripheral      : Generic DVD-ROM         1.0    d347prt Port 2 ID 0  DMA: Off
=== CDRom-Device-Map ===
TOSHIBA ODD-DVD SD-M1802   G:   CDRom0
SONY DVD RW DW-Q28A        H:   CDRom1
LITE-ON LTR-52246S         I:   CDRom2
Generic DVD-ROM            K:   CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1023MB (1048048kB)
Free physical memory: 421MB (432032kB)
Memory in use       : 58 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.11.2005
Graver une image DVD
10:58:52 #1 Text 0 File ThreadedTransfer.cpp, Line 525
 ReadBuffer-Pipe got 262144KB of Memory
10:58:52 #2 Text 0 File Reader.cpp, Line 124
 Reader running
10:58:52 #3 Text 0 File Writer.cpp, Line 113
 Writer H: SONY DVD RW DW-Q28A running
10:58:52 #4 IMAGEGEN -10 File ImageGen.cpp, Line 366
 Image was written as DAO.
 DAOI:
  MediaCatalogNumber = ''
  TocType = 0x00
  Finalized =  0
  First/Last Track =  1 /  1
   1: ISRC = ''
      Blocksize = 2048
      TrackMode = 'TRM_DATA_MODE1'
      TrackConfig = 0x00
      First/Last Index =  0 /  1
      Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4695425024
 CUES:
    0: Ctrl=0x41 Trk=  0 (0x00) Index=00 Start=00:00.00 (        0) RecDep=0x00
    1: Ctrl=0x61 Trk=  1 (0x01) Index=00 Start=00:00.00 (        0) RecDep=0x00
    2: Ctrl=0x61 Trk=  1 (0x01) Index=01 Start=00:00.00 (        0) RecDep=0x00
    3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=509:29.13 (  2292688) RecDep=0x00
 MTYP: Mediumtype =   (0x4005E)
 Image file name: <L:\Film repackter\the punisher.nrg>
10:58:52 #5 Text 0 File Burncd.cpp, Line 3302
 Turn on Disc-At-Once, using DVD media
10:58:52 #6 Text 0 File DlgWaitCD.cpp, Line 279
 Last possible write address on media:  2295103 (510:01.28, 4482MB)
 Last address to be written:            2292687 (509:29.12, 4477MB)
10:58:52 #7 Text 0 File DlgWaitCD.cpp, Line 291
 Write in overburning mode: NO (enabled: CD)
10:58:52 #8 Text 0 File DlgWaitCD.cpp, Line 2578
 Recorder: SONY DVD RW DW-Q28A, Media type: DVD+R
  Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
  Disc Application Code: 0, Extended Information Indicators: 7
10:58:52 #9 Text 0 File DlgWaitCD.cpp, Line 458
 >>> Protocol of DlgWaitCD activities: <<<
10:58:52 #10 Text 0 File ThreadedTransferInterface.cpp, Line 847
 Setup items (after recorder preparation)
  0: TRM_DATA_MODE1 (1 - DVD-ROM)
     2 indices, index0 (150) not provided
     original disc pos #0 + 2292688 (2292688) = #2292688/509:29.13
     not relocatable, disc pos for caching/writing not required/not required, no patch infos
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2292688 blocks [H: SONY DVD RW DW-Q28A]
10:58:52 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1059
 Prepare recorder [H: SONY DVD RW DW-Q28A] for write in CUE-sheet-DAO
 DAO infos:
  MCN: ""
  TOCType: 0x00; Session Closed, disc not fixated
  Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4695425024, ISRC ""
 DAO layout:
  __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
        0 |  lead-in |   0 |    0x41 | 0x00
        0 |        1 |   0 |    0x41 | 0x00
        0 |        1 |   1 |    0x41 | 0x00
  2292688 | lead-out |   1 |    0x41 | 0x00
10:58:52 #12 Text 0 File SCSIPassThrough.cpp, Line 36
 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:58:52 #13 Phase 24 File dlgbrnst.cpp, Line 1725
 Caching of files started
10:58:52 #14 Text 0 File Burncd.cpp, Line 4132
 Cache writing successful.
10:58:52 #15 Phase 25 File dlgbrnst.cpp, Line 1725
 Caching of files completed
10:58:52 #16 Phase 36 File dlgbrnst.cpp, Line 1725
 Burn process started at 8x (11 080 Ko/s)
10:58:52 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:58:52 #18 Text 0 File Cdrdrv.cpp, Line 8411
 ---- DVD Structure: Physical Format Information (00h) ----
 Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
  Book Type: DVD+R   (10), Part Version: 1.0x (1)
  Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
  Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
  Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
  Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
  End Physical Sector Number of Data Area:      26053F h
  End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
  Data in Burst Cutting Area (BCA) does not exist
   Disc Application Code: 0 / 0 h
   Extended Information indicators: 7 h
   Disc Manufacturer ID: MCC.....
   Media type ID: 004
   Number of Physical format information bytes in use in ADIP up to byte 63: 56
  Media Specific [16..63]:
       00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38    ...MCC.....004.8
       23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08    #T7..Tl.’_......
       01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00    ................
10:58:52 #19 Text 0 File DVDR.cpp, Line 5900
 Drive: SONY     DVD RW DW-Q28A
 Book Type request [LO], rev 1: DVD-ROM
 Changing the Book Type was finished successfully, return code 0
10:58:52 #20 CDR -1207 File DVDR.cpp, Line 5330
 Book Type automatically set to: DVD-ROM
10:58:52 #21 Text 0 File DVDPlusRW.cpp, Line 666
 Start write address at LBA 0
 DVD high compatibility mode: No
11:07:24 #22 Text 0 File WriterStatus.cpp, Line 116
 <H: SONY DVD RW DW-Q28A> start writing Lead-Out at LBA 2292688 (22FBD0h), length 0 blocks
11:07:25 #23 Text 0 File ThreadedTransfer.cpp, Line 228
 all writers idle, stopping conversion
11:07:25 #24 CDR -1 File ThreadedTransferInterface.cpp, Line 1937
 Unspecified Recorder Error
11:07:25 #25 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1937
 Could not perform end of Disc-at-once
11:07:25 #26 Phase 127 File dlgbrnst.cpp, Line 1725
 Generating DVD high compatibility borders
11:07:25 #27 CDR -1 File WriterStatus.cpp, Line 167
11:07:25 #28 TRANSFER -24 File WriterStatus.cpp, Line 167
11:07:25 #29 Phase 38 File dlgbrnst.cpp, Line 1725
 Burn process failed at 8x (11 080 Ko/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/03/2005 00:28:14 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
n°4462777
shinigami7​9
Screw you guy's I'm going home
Posté le 23-11-2005 à 11:58:51  profilanswer
Mets ton firmware à jour :
http://codeguys.rpc1.org/firmwares [...] .stock.rar
Et retest stp
http://www.worldcommunitygrid.org/ - FightAIDS@Home - Le topic WCG
  CD/DVD/BD
Problème d'installation de matos - pas d'affichageProblème reconnaissance graveur
problème disque dur inaccessibleproblème install xp
Gros probléme , je ne comprends plus (bip de carte méres) venez SVP :(Problème de RAM
Problème install xpProblème pour éteindre mon pc
probleme hub avec freebox
Plus de sujets relatifs à : probleme avec graveur dvd Q28a
