5569 connectés
 Page :   1  2
Page Suivante
Comment flasher ma GeForce2 TI ??? [ RESOLU ]
n°1086007
piper
Posté le 11-01-2002 à 18:30:44  profilanswer
tout juste walkman, j'ai pas fait gaffe. je cherche.
n°1086014
piper
Posté le 11-01-2002 à 18:32:37  profilanswer
walkman regarde là : http://www.x-bios.3dgames.ru/
n°1086048
piper
Posté le 11-01-2002 à 18:44:48  profilanswer
tiré de www.geforcefaq.com :
"Q. My card's Video BIOS is corrupted and I can't use my manufacturer's flash program to restore it. How can I restore it?
If you cannot get any display, get a PCI graphics card, put it in your system along with the GeForce, and plug your monitor into it. You should now be able to use NVFlash to reflash your GeForce's Video BIOS.
If you do not have a PCI graphics card spare, create a boot floppy disc on another system (select 'Copy system files' when you format it). Create a file called 'autoexec.bat' in the main directory of the floppy disc, and put the following line only inside:
nvflash -p -h -ffilename.ext
where filename.ext is the name of the BIOS flash file that you are going to use. Also copy nvflash.exe and dos4gw.exe into the main directory of the floppy disc.
Then put the disc in the drive and start the computer. The floppy disc should be read within 30 seconds or so. You should soon notice the keyboard lights going mad - this means that your video BIOS is being flashed. Your computer should reboot when finished, and hopefully your video card will then work.
If you want to get your original manufacturer's video BIOS back, try using WinAce to open your manufacturer's flash program file and see if you can extract the raw BIOS file from it. You can use NVFlash with this raw BIOS file. This has been tested with ASUS BIOS files.
You can download WinAce at the following website:
http://www.winace.com
Otherwise, you will have to find someone else with the same card and ask them to save their Video BIOS using NVFlash and then send you the file.
You can find out more about NVFlash in the 'Where can I get and how do I use NVFlash?' question." :bounce:
n°1086079
walkman
Posté le 11-01-2002 à 18:57:18  profilanswer
J'avais lu ça.
Le problème est que mon EEPROM n'est pas supportée par nvflash
avec ou sans carte PCI additionnelle.
Alors puis-je changer mon EEPROM ou la reprogrammer?
n°1086087
cpulloverc​lock
Posté le 11-01-2002 à 19:00:16  profilanswer
walkman a écrit a écrit :
vgabios teste un bios mais ne flashe pas l'eeprom avec
bizarre
enfin moi jai pousse max ma gf2 ti a 276MHz donc 552MHz DDR
4ns aussi
[edtdd]--Message édité par cpulloverclock--[/edtdd]
n°1086092
piper
Posté le 11-01-2002 à 19:01:43  profilanswer
Pour la changer, si tu as le matos pour le faire non soucis, mais c'est trés difficile de déssouder les boitiers plcc soudés direct sur ci. Mais surtout, il faut trouver une eeprom compatible (www.radiospares.fr).
Mais avant de faire tout ça, il faut essayer de la reflasher, mais faut voir si on peut le faire
n°1086105
piper
Posté le 11-01-2002 à 19:04:41  profilanswer
cpulloverclock : je parie que ta carte n'est pas une hercules !
n°1086178
cpulloverc​lock
Posté le 11-01-2002 à 19:19:55  profilanswer
une leadtek
n°1088657
piper
Posté le 12-01-2002 à 18:13:40  profilanswer
ma carte est stable à 280/460 maintenant.
n°1088684
piper
Posté le 12-01-2002 à 18:20:58  profilanswer
:fuck: up!
n°1089154
walkman
Posté le 12-01-2002 à 20:56:10  profilanswer
Je crois que je vais tester ça:
ftp://ftp.mplik.ru/os/Drivers/vid [...] NVMods.zip
 :eek2:
n°1089395
piper
Posté le 12-01-2002 à 22:02:59  profilanswer
:eek2: alors ?? :??:
n°1091178
walkman
Posté le 13-01-2002 à 19:30:21  profilanswer
Ca marche avec l'utilitaire de Prolink/Pixelview
http://forum.3dgames.ru/showthread.php?s=&threadid=724
Disponible ici:
http://www.cody.sk/
http://www.cody.sk/gf/utility/Plflash.ace
Alors
Vive la Russie, la Slovaquie, le Japon,
Et Vive la France!
n°1091197
piper
Posté le 13-01-2002 à 19:39:32  profilanswer
elle est en quadro, ca y est ?? j'ai essayé sous autocad avec le patch de elsa (quadroview), ca pousse !!
n°1091221
walkman
Posté le 13-01-2002 à 19:47:30  profilanswer
Pas encore Quadro-Hard
Mais maintenant que je sais que l'EEPROM est flashable
Je fais faire la modif dans quelques jours
R123->R124  (R121->R122 est d'origine)
Pour l'instant elle est Quadro-Soft
Deto 21.83 patchés avec SoftQuadro
n°1112828
m16
Posté le 21-01-2002 à 16:27:56  profilanswer
CA EN EST OU?
 Page :   1  2
Page Suivante
XP 1800+ ,A7V266, geforce2 TI et SB audigy. (mariage houleux?)cherche l'utilitaire pour flasher un bios de CUSL2 ?
flasher bios carte merela bakk1 pe m'aider a flasher mon bios ??
la meilleure GeForce2 Ti ??C'est quoi les diff. entre une GeForce2 MX 200 et une GeForce2 MX 400?
Pas de comparatif Geforce2 Ti/Ultra/Pro ?KT 266, qui a résolu ses prb d'USB ???
Flasher Bios ECS K7S5AMa GeForce2 TI ne fonctionne pas !
Plus de sujets relatifs à : Comment flasher ma GeForce2 TI ??? [ RESOLU ]
