6059 connectés
  quelle ram?
quelle ram?
n°4388794
cocoraton
Posté le 19-10-2005 à 15:15:32  profilanswer
Mon amie a un AMD K6 2 450Mhz carte mere Soltek SL56G5 avec 192Mb ram. J'aimerais rajouter 512Mb sdram pc 100 mais j'ai peur de ne pas prendre les bonnes alors voici ce que Everest dit concernant la memoire "K6-2 450Mhz Magig pro MP-VIP4-L PC100 sdram.
DIMM1: 64Mo pc100 sdram
DIMM2: 128Mo pc 133 sdram
Propriete du module memoire
Numero de serie: aucun
Taille du module: 64Mo(2rows, 4banks)
Type de module: unbuffered
Type de memoire: SDRAM
Vitesse de memoire pc100(100mhz)
Largeur de module: 64 bit
Voltage de volume: LVTTL
Methode de detection d'erreur: aucune
Taux de rafraichissement: normal(15.625us,self-refresh)
Performance memoire
100Mhz: 3.0-2-2-5(CL-RCD-RP-RAS)
100Mhz: 2.0-2-2-5(CL-RCD-RP-RAS)
Fonctionalite du module memoire...il y en a 4 de cocher et géré:
early ras#precharge
auto-precharge
precharge all
write 1/read burst
Sur le manuel est inscrit ceci...
system memory 3x dimm sockets max 768MB SDRAM
et encore ceci...
Memory rang from 4Mb (minimum) to 768 Mb (maximum) with DRAM table free configuration.
Support SDRAM with 8/10ns
Supports 3pcs of 168 pin dimm sockets 3.3V unbuffered 4 clock type
IMPORTANT
Make sure that the SDRAM module not only has to be 168 pin dimm but designed for 3.3V unbuffered SDRAM supllier before install any SDRAM.
The mainboard manufactuer has no obligation to any damage of the board by using the incorrect specification of SDRAM.
For 100 Mhz cpu environnement, the SDRAM must compliant PC-100 specification, otherwise, the system maybe unstable.
User must dedicated UDMA66 IDE cable when connects UDMA66 hard disk or any other devices support UDMA66
Main memory configuration
This Apolli MVP3 mainboard supports 168pin dimm (3.3V unbuffered type) of 4Mb, 8Mb, 16Mb, 32Mb, 64Mb, 128Mb to from a memory size between 4Mb to 768 (total of 6 rows are supported)
En bref si je comprends bien, je peux monté jusque 768Mram en SDR 100 bien ?
Je peux franchement acheter celle-ci alors ? http://www.rueducommerce.fr/info/s [...] _id=353481
Ou celle-la ? c'est encore moins cher !
http://www.rueducommerce.fr/Ordina [...] -SDRAM.htm
J'ai posé la question chez Materiel.net et voici ce qu'il me répondent...
Votre carte mère est beaucoup trop ancienne pour accepter nos barrettes en 512 Mo
En effet celle ci risque de ne pas fonctionner du tout
Cependant cette barrette compatible en PC 100 et surtout compatible avec les anciennes cartes ne devrait pas poser de problème
http://www.materiel.net/details_DP133-064323E.html
Qu'en pensez-vous ???
Je vous remercie beaucoup d'eclairer mes lanternes !  :)
coco
ps: désolée d'avoir été si longue ! :D
n°4388809
Fraisouill​e
Grouik Grouik
Posté le 19-10-2005 à 15:21:52  profilanswer
Tu peux monter à 768 Mo mais seulement en utilisant les tailles de barettes citées au dessus. Donc 128 Mo maximum.
Si tu prends une barette de 512 Mo, t'en auras que 128 Mo exploitables... Si elle marche ;)
n°4388960
cocoraton
Posté le 19-10-2005 à 16:24:49  profilanswer
mais je ne comprends pas leur calcul ! on peut monter jusque 768 avec 128 max chacune et il n'y a place que pour 3 !!! 3x128=384 donc impossible de monter jusque 768 !!!
alors je devrais peut-être prendre celle que monsieur Materiel me propose 256 pc133 en 16 composant ? et 8 composants ça peut aller aussi ?
En tous cas, merci de ta réponse rapide ;)
n°4390545
Fraisouill​e
Grouik Grouik
Posté le 20-10-2005 à 12:57:24  profilanswer
Et ouais, c'est la magie du marketing. Le controleur mémoire supporte jusqu'à 768 Mo mais tu peux en mettre que 384 :D
Eventuellement, la 256 Mo en 16 composants pourrait passer mais chuis pas sûr. En fait, c'est pas la taille de la barette mais la taille de chaque puce qui pose problème. 256/16 = 16. Donc des puces de 16 Mo. Normalement, ça doit pouvoir passer... Pas contre, les puces de 32 Mo (Donc 8 composants pour 256 Mo), c'est pas la peine, ça passera pas. Enfin, si ça passera mais tu pourras utiliser que la moitié de la barette.
Message édité par Fraisouille le 20-10-2005 à 12:57:33
n°4390767
cocoraton
Posté le 20-10-2005 à 14:39:55  profilanswer
Ok merci beaucoup me voilà rassurée ou en tous cas bien informée !!!
Merci ! ;)
  quelle ram?
Plus de sujets relatifs à : quelle ram?
