2777 connectés
  Problème de mise à jour du bios
n°2769380
parappa
taliblanc
Posté le 12-10-2003 à 17:10:18  profilanswer
Je voudrais mettre à jour le bios d'une vieille carte mère Intel SE440BX. Je vais donc chercher le bios sur le site d'Intel.
Le dernier bios en date se trouve ici : http://downloadfinder.intel.com/sc [...] nldID=1075
Je télécharge le fichier qui s'appelle donc "sebios12.exe".
Je télécharge également le readme.txt expliquant la procédure à suivre.
Voilà ce que dit le readme :
1.  Be sure to verify that the correct BIOS has been downloaded.
 a.  AMI BIOS:  the last three characters will be
     identical to the current BIOS version
 b.  PhoenixBIOS: the first eleven characters will be
2.  Enter BIOS SETUP upon boot up by following the on-screen
 prompt, ie F1 or F2 depending on the BIOS.
3.  Write down all settings that are unique to the system. These
 settings will be needed later to reconfigure the system.
4.  Create a bootable floppy diskette using the instructions at
 the beginning of this document.
5.  Extract ‘bios.exe’ to the bootable floppy: a.  In a DOS environment: Type "bios a:".
 b.  In a non-DOS environment: Create a new directory.
     Move 'bios.exe' into the directory. Double click on
     'bios.exe'. Copy all the files in the directory
     except 'bios.exe' to the bootable floppy.
6.  Place the bootable floppy containing the new BIOS into drive
 a: of the system to be upgraded and boot the system.
7.  Press ENTER when prompted.
8.  Highlight "Update Flash Memory From a File" and press ENTER.
9.  Highlight "Update System BIOS" and press ENTER.
10. Press TAB once to highlight the file name and press ENTER.
11. The system will now give a warning stating that continuing
 will destroy the current contents of the flash memory
 area. Press ENTER to continue.
12. When prompted that the BIOS has been successfully loaded,
 remove the bootable floppy from the drive and press ENTER
 to reboot the system.
13. Press F1 or F2 to enter SETUP.
14. On the first screen within SETUP, check the BIOS version to
 ensure that it is the new version.
15. In SETUP load the default values.
 a.  AMI BIOS: Press the F5 key.
 b.  PhoenixBIOS: Go to the exit submenu and highlight
     "Load Setup Defaults". Press ENTER.
     If you do not set the values back to defaults the system
     may function erratically.
16. If the system has unique settings, re-enter those settings
 now. Press F10 to save the values and exit Setup.
2 soucis donc : le premier, sans doute peu important, est que le fichier ne s'appelle pas "bios.exe" mais "sebios12.exe". Le second, beaucoup plus gênant, c'est qu'on ne peut rien extraire de ce fichier : lorsque je double clique dessus, il ouvre une fenêtre dos et la referme aussitôt. Si je l'execute depuis l'invite de commande win2000, il ne se passe rien non plus.
Une idée ? :/
Message édité par parappa le 12-10-2003 à 17:11:04
n°2769390
Prems
Just a lie
Posté le 12-10-2003 à 17:12:57  profilanswer
Si tu as winzip : bouton droit et "extract to"
Sinon, tu l'exécutes dans une fenêtre DOS avec le paramètre /?
Ratures - Cuisine
n°2769397
popoles
Posté le 12-10-2003 à 17:16:03  profilanswer
à priori, fo mettre une disquette... (l'extraction se fait sur la disquette)
n°2769398
parappa
taliblanc
Posté le 12-10-2003 à 17:16:39  profilanswer
Ne fonctionne pas, ni avec winzip ni avec winace.
Il ne se passe rien (enfin, j'ai pas l'impression).
n°2769400
parappa
taliblanc
Posté le 12-10-2003 à 17:17:05  profilanswer
Je vais essayer ça. :)
n°2769414
parappa
taliblanc
Posté le 12-10-2003 à 17:25:55  profilanswer
Rien ne fonctionne. 'l'a l'air louche, leur fichier.
Edit : ok, le téléchargement avait foiré. Bon, je retente. :D
Message édité par parappa le 12-10-2003 à 17:28:37
n°2769472
parappa
taliblanc
Posté le 12-10-2003 à 17:50:04  profilanswer
Forcément, ça fonctionne mieux. Merci. :)
bios carte mèreProblème matos, mais lequel ?
Probleme SCSIProblème avec mes ports USB.
flashage kt3v, mauvais biosgros probleme apres la mise a jour du bios (NF7-S)
probleme mise a jour de bios CompaqMSI NFORCE K7N420 : Problème après mise à jour Bios 2.3
PROBLEME DE MISE A JOUR DU BIOSProblème de Mise à Jour du BIOS sur une Asus P5-A pour install HDD WD
Plus de sujets relatifs à : Problème de mise à jour du bios
