8069 connectés
  MSI 6382 Ca vaut le coup ou pas? please help me
n°1785705
rorouk
Posté le 06-09-2002 à 13:39:28  profilanswer
voila on me propose un carte mere MSI6382 micro atx pour 350frs
MSI 6382 (KT266), 1.5Ghz+, UDMA 33/66/100
socket A micro ATX mobo from MSI using the KT266/VT8366 and VT8233 chipset. It is capable of running cpu's up to 1.5Ghz. Uses DDR memory 200/266FSB for fast prosessing, 2 slots up to 2GB. (The memory speed can be set independently of FSB so allowing 100FSB with 266 DDR memory). UDMA 33/66/100. FSB 100/133. 1 AGP (2.0 1x/2x/4x), 3 PCI, on board creative sound pci 128(with line in, line out, mic and games socket), 1FDD, 2 serial, 1 parallel, 2 USB ports (with 4 aditional via cables from the mobo, cables not supplied). Size 24.3cm x 23.3cm. Please note that this board is an OEM version from MSI and comes without a CNR socket or hardware monitoring
QQ sait quel CPU je peux mettre dessus Athlon XP peut etre??
HELP ME!!!!!!!!!!!!!!! Notice motherboard?????Dézonner le Lite-on LTD 163 help needed
[help] vidage de la memoire sous win2k gros pb!Que vaut le DVD Pioneer 16/40 SCSI ?
ati et driver help je panne rienventilateurs 69U6 et MSI KT3 ULTRA
MSI ou ASUS[MSI-6191] Détection de RAM
MSI KT3 Ultra + XP1800+ XP = freeze/rebootPour ts ceux qui ont une MSi Kt7 turbo 2
Plus de sujets relatifs à : MSI 6382 Ca vaut le coup ou pas? please help me
