4364 connectés
  CPU Charts
CPU Charts
n°6411498
stealz
Posté le 03-06-2008 à 23:47:18  profilanswer
Hello everyone,
if you're interested to see cpu charts and you want to have a possibility of quick comparision between many cpus same time, i give you these links:
http://benchit.pl/cpu/charts
http://benchit.pl/cpu/comparision - script allows you to add few cpus same time and compare their specifications and benchmarks results. You can also see a 'theoretical' test performance of the cpu which doesn't take a part in.
This site is my student project, it's not commercial, but at the moment it's in polish only. English version comming soon.
  CPU Charts
CM mini ITX & CPU XeonCPU mort ?
Bruit lors de l'utilisation du CPU [Résolue][Résolu] Changement CM+RAM+CPU, besoin de conseil
Compatibilité ventilo CPU Scythe+Asrock DUAL SATA 2 +Boitier Antecnouveau CPU ?
conseil d'upgrade : CPU ou carte graphique ?Problème de boot (Température CPU trop élevée?)
CPU et CM de bus différent ?Sondes pour GPU, CPU, et boitier
Plus de sujets relatifs à : CPU Charts
