3904 connectés
probleme virus
n°3915384
alex49
Posté le 03-03-2005 à 17:48:47  profilanswer
voila j'ai le virus funner-A (w32.funner) et norton me l'a detecter eet il me dirige vers symantec
http://securityresponse.symantec.c [...] unner.html
et il me dise d'ajouter une valeur dans un dossier nommée winlogon que je n'ai pas
voila ce k'il dise :
When W32.Funner is executed, it performs the following actions:
Copies itself as:
%System%\IEXPLORE.EXE
%System%\EXPLORE.EXE or %System%\EXPLORER.EXE
%Windir%\rundll32.exe
%System%\userinit32.exe
c:\funny.exe
and executes the first three files listed.
Notes:
The three files make sure that the other two are running and will restart them if any are stopped.
These files require the MSVBVM60.DLL file, which is a component of the Microsoft Visual Basic run-time environment.
%System% is a variable that refers to the System folder. By default this is C:\Windows\System (Windows 95/98/Me), C:\Winnt\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP).
%Windir% is a variable that refers to the Windows installation folder. By default, this is C:\Windows or C:\Winnt.
Creates a log file named %System%\bsfirst2.log.
Adds the value:
"Userinit"="userinit32.exe,"
to the registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
so that the userinit32.exe runs when you start Windows.
Adds the value:
"MMSystem"="%Windir%\rundll32.exe "%System%\mmsystem.dll"", RunDll32"
to some of the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
so that the rundll32.exe runs when you start Windows.
May add the line:
Shell = %System%\explore.exe
to the [boot] section of the system.ini file.
Attempts to send c:\funny.exe to contacts in the Microsoft MSN Messenger instant message program.
May contact the www.78p.com domain and download various components.
n°3915388
Down to th​e Devil
Posté le 03-03-2005 à 17:51:05  profilanswer
C'est pas un problème hardware ça, il me semble.
Virus? probléme l'écran reste noirprobleme de virus envahissant!
problème de virus help!!!problème de virus...
(probleme virus) important plzprobleme virus sous 98 ?
help probleme virus ?un probleme de virus
Plus de sujets relatifs à : probleme virus
