3968 connectés
  Alimentation
  seasonic
seasonic
n°7111511
vince7887
Posté le 12-09-2009 à 11:25:37  profilanswer
bonjour,
quelle est la différence entre seasonic ss-400et et ss-400es; il n'y a aucun élémentt d'information sur leur site... ?
n°7111554
El_diablo
Posté le 12-09-2009 à 11:52:25  profilanswer
pour la ss-400et
Input voltage  100-240 V
 Power frequency  47-63 Hz
 Power  400 W
 PFC  active
 Connectors
 ATX connector  20/24
 ATX  1
 5.25" power connectors  5
 S-ATA power connectors  2
 3.5" power connectors  1
 PCI-Express (6pin)  1
 4pin ATX 12V  1
 Output power
 Power +3.3V  20 A
 Power +5V  20 A
 Power +12V1  17 A
 Power +12V2  17 A
 Power -12V  0.8 A
 Power +5V standby  2,5 A
 max. combined power 3.3+5V  130 W
 max. combined power 12V  360
 max. combined power 3.3+5+12V  400 W
 Physical data
 Form factor  ATX
 Dimensions  150*140*86 mm
 Weight  1700 g
 Other data
 Fans  1* 120mm Lüfter
 Shortcut protection  yes
 80 plus Energy-Efficient  yes
 MTBF  100000 Hours
 Internal cables removable  no
et pour Modele SS-400ES
Spec
Type ATX12V V2.2 / EPS12V V2.91
Maximum Power 400W
Fans One Double Ball Bearing 8cm fan
PFC Active
Main Connector 20+4Pin
+12V Rails 2
PCI-Express Connector 1 x 6-Pin
SATA Power Connector 2
SLI No
CrossFire No
Modular No
Power Good Signal Signal Type: open collector +5DC, TTL compatible.
Logic Level: <0.4V while sinking 4 mA.
Logic Level High: between 2.4VDC and +5V output while souring 200 uA.
Efficiency > 80%
Energy-Efficient 80 PLUS Certified
Input Voltage 100 - 240 V
Input Frequency Range 50/60 Hz
Input Current 7A
Output +5V@20A, +3.3V@20A,+12V1@17A, +12V2@17A, -12V@0.8A, +5VSB@2.5A
MTBF Over 100,000 hours at 25°C, excluding the DC Fan
Approvals CB, CE, FCC, TUV, cUL, CCC
Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V(P4)
1 x 12V(8Pin)
6 x peripheral
2 x SATA
2 x Floppy
1 x PCI-E
Features PCI Express & Serial ATA ready
Double forward converter circuit
High efficiency and reliability
Low ripple & noise
Super low noise fan control
Short circuit protection on all outputs
Over voltage protection
Over power protection
100% hi-pot test
100% burn in, high temperature cycled on/off
Manufacturer Warranty
Parts 3 years limited
Labor 3 years limited
Message édité par El_diablo le 12-09-2009 à 11:53:53
Achat / Vente / Feed-Back
  Alimentation
  seasonic
P5w DH hors service ou Seasonic M12 600 morte[Alim] Seasonic certifiée Gold - X-Series - Nouvelle version Fanless
[clos] Remplacement d'une seasonic M12 600Seasonic S12 600w et CF 4870
Tensions Seasonic S12 II 500WBug alim seasonic???
Bruit d'ondulation avec Alim M12 500 seasonic ??[Résolu] Sifflements et chuintements Seasonic S12 et S12II 500W
Alimentation Seasonic S12 II - 500WNouvelle alim : Corsair HX ou Seasonic M ?
Plus de sujets relatifs à : seasonic
