4722 connectés
  A votre avis mon score 3DMARK est bon ??
n°3621729
poupouillo​ux
L'art et le cochon
Posté le 09-11-2004 à 21:37:50  profilanswer
je viens de fair eun test 3DMARK03
j'obtient 5406 .
mon matos :
-K7S8X
-XP 2600 Barton
-512Mo DDR PC3200 noname
-GEFORCE 9800 Pro  128Mo 256Bits POWERCOLOR
voici les infos que 3DMARK me donne au sujet de mon matos :
   SystemInfo version 3.4
XSLT StyleSheet version 3.1-d
 CPU Info
 CPU 1/1
AMD Athlon(tm) XP 2600+ 1.9 GHz
Manufacturer   AMD
Family   AMD Athlon(tm) XP 2600+
Internal Clock   1.9 GHz
Internal Clock Maximum   3.0 GHz
 External Clock   166.0 MHz
Socket Designation   Socket-A
Upgrade   Socket A
HyperThreadingTechnology   N/A
 Capabilities   MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version   AMD Athlon(tm) XP 2600+
 Caches
Level 1    128 KB
Level 2    512 KB
 DirectX Info
Version   9.0c
 Long Version   4.09.00.0904
DirectDraw
Version   5.03.2600.2180
 Primary Device   RADEON 9800 PRO
 Display Device 1/1
RADEON 9800 PRO        Driver 6.14.10.6483
Description   RADEON 9800 PRO
Manufacturer   ATI Technologies Inc.
Total Local Video Memory   128 MB
Total Local Texture Memory   128 MB
Total AGP Memory   54 MB
Driver File   ati2dvag.dll
Driver Version   6.14.10.6483
Driver Details   8.062-040929a-018115C-ATI
Driver Date   9-29-2004
Driver WHQL Certified   true
Max Texture Width   2048 px
 Max Texture Height   2048 px
Max User Clipping Planes   6
Max Active Hardware Lights   8
Max Texture Blending Stages   8
Fixed Function Textures In Single Pass   8
Vertex Shader Version   2.0
Pixel Shader Version   2.0
Max Vertex Blend Matrices   37
Max Texture Coordinates   8
VGA Memory Clock   337.5 MHz
VGA Core Clock   378.0 MHz
 PCI
Name   RADEON 9800 PRO
Vendor ID   0x1002
Device ID   0x4e48
SubSystem ID   0x00021002
Revision ID   0x00
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Vous en pensez quoi ?
Enfait je vous demande ça car à sims2 c'est vraiment pas très fluide et je me demande si j'ai pas un soucis quelquepart.
n°3621741
bebel31
Posté le 09-11-2004 à 21:41:47  profilanswer
il est pas mal regarde moi avec une config qui ressemble à la tienne (à part pour la carte graphique où...)j'ai à peu prés 2500...
n°3622550
poupouillo​ux
L'art et le cochon
Posté le 10-11-2004 à 07:06:44  profilanswer
pas d'autres avis ?
n°3622554
alexreunio​n
Posté le 10-11-2004 à 07:11:35  profilanswer
le score est normal.
pkoi tu demandes ça?
n°3622557
cyberfred
Posté le 10-11-2004 à 07:19:19  profilanswer
score normal pour une 9800 pro.
Les sims 2 est un jeu trés gourmand , proc + CG.
Message édité par cyberfred le 10-11-2004 à 07:19:35
n°3622559
alexreunio​n
Posté le 10-11-2004 à 07:23:55  profilanswer
Ma 6800GT 256Mo, Xp3200+ et 1Go de RAM en bave avec ce jeux....
c jamais fluide, toujours un peu saccadé dans les scrollings (enfin c tres commum ds ce type de jeux)
donc c normal que ça rame sur une 9800Pro.
n°3622587
poupouillo​ux
L'art et le cochon
Posté le 10-11-2004 à 08:21:10  profilanswer
ça me rassure.....
je pensai qu'avec mon ensemble Proc/CG qui ne sont totalement à la ramasse je pourrai faire tourner comme il faut n'importe quoi . Les jeux sont sacrément gourmand !!!
n°3622588
poupouillo​ux
L'art et le cochon
Posté le 10-11-2004 à 08:22:07  profilanswer
D'ailleurs depuis que j'ai ma 9800Pro dans SIMS 2 je ne voi plus les cinématique, l'écran devient noire lors des cinématique. à votre avis ça vient d'où ? driver ? config du jeu ?
n°3622880
glossypape​r
Motard des terrasses :o
Posté le 10-11-2004 à 11:41:53  profilanswer
"GEFORCE 9800 PRO" :love: [:rofl]
(score normal)
n°3623013
Gravit8
Posté le 10-11-2004 à 12:55:20  profilanswer
>> score normal ! : )
Jester Race
n°3623026
hakxe
Belgium compliant
Posté le 10-11-2004 à 13:02:09  profilanswer
Il est tres bon.
Bonne bran...
n°3623191
adonai_24
The trick is to keep breathing
Posté le 10-11-2004 à 14:17:10  profilanswer
Oui, score normal !!! c'est dans les 5500 environ donc c'est cool :)
Sinon "GEFORCE 9800 pro" :lol:
n°3623343
dylando11
Posté le 10-11-2004 à 15:30:27  profilanswer
comment ce fait il qu'il ai une frequence de 1,9Ghz sur son barton 2600 et que je n'ai que 1,8 Ghz sur mon sempron 3100+ ?
n°3623356
adonai_24
Posté le 10-11-2004 à 15:35:28  profilanswer
Car l'architecture donne un gain de perfs, qui n'a pas trop a voir avec la frequence. C'est pas comme les P4 ou + tu as une frequence elevée + ca va vite !!! regardes le Barton 3200+ a 2.2Ghz est a la traine derriere le A64 3000+ a 2Ghz, et meme derriere ton Sempron 3100+ a 1.8Ghz ...
http://www.hardware.fr/articles/525/page8.html
Quelques avis sur ma config : AMD 64 3500 .. [encore et tjs]Changement de Pc :Besoin d'avis...
Votre avis ? CG ou + de RAM ?score a cpu mark
3dmark 2005 (bon ou pas bon)Avis sur ma future config
Per de m... sous 3dmark 2001[AVIS] CM biproco socket 370, ca existe ? et pour proco differents ?
Avis sur configVotre avis sur les nouveaux CPU
Plus de sujets relatifs à : A votre avis mon score 3DMARK est bon ??
