7107 connectés
  Specs G80 et R600 (successeur 7900 et X1900)
n°4619002
lonely
Posté le 01-02-2006 à 23:36:26  profilanswer
65nm
64 Shader pipelines (Vec4+Scalar)
32 TMU's
32 ROPs
128 Shader Operations per Cycle
800MHz Core
102.4 billion shader ops/sec
512GFLOPs for the shaders
2 Billion triangles/sec
25.6 Gpixels/Gtexels/sec
256-bit 512MB 1.8GHz GDDR4 Memory
57.6 GB/sec Bandwidth (at 1.8GHz)
WGF2.0 Unified Shader
Dispo dans début avril  :lol:
http://www.ati-power.fr/ATI-Caract [...] nh3935.htm
http://www.vr-zone.com/?i=3177
Nvidia G80 will make ATI stumble on April.Sources from anonymous mentioned that since the introduction of NV40 which was a very big leap over the defective NV30 with its spectacular features such as Shader Model 3.0 and SLI, in the next couple of months after G71 you will be promised to witness another new spectacular technology that will be brought by Nvidia to 3D Gaming community. It's been almost a year since Nvidia has not really altered much of its architecture just like what we see now in the G70, An increase in pipelines,the intro of MIMD and more vertex units. This is because Nvidia knows that ATI is currently having a hard time fixing and improving their bugged R5xx architecture so it isn't necessary for Nvidia to introduce an incredibly improved architecture. This is what you will see in G71, there will be 32pipes, increase in ROPs and a little speed bump over the coreclock, it is more like an absolute ultra pumped NV40based architecture. In the G80 however, Quad SLI it self can be implemented on a single card with two chips solution because it will carry the first dual core GPU ever with the support of DirectX10 and Shader Model 4.0. The development of G80 is also mentioned as being running very intensive since Nvidia's acquisition over ULi.
http://www.xpentor.com/
n°4726563
Li-QuiD
Salut toi.
Posté le 25-03-2006 à 18:53:30  profilanswer
lonely
n°4852361
mouarf2
Posté le 30-05-2006 à 09:15:41  profilanswer
n°5158023
clem77dvlp
Posté le 10-11-2006 à 08:12:22  profilanswer
R600 powaaa  :D
[TOPIC] Venez parler de vos X1900,tofs Page41Problème avec une x1900 xtx
Geforce 7800 vs Geforce 7900 vs Radeon X1900XTX - que choisir ?X1900 XT en stock
Fonctionnement Graveur HDD LG 7900y aura t-il un successeur au barton 3200 [socket A] ?
A propos des specs du dw1640casio 7900 gc urgent
specs carte graphique pour vieile configspecs Athlon 64 chez ldlc fausses?
Plus de sujets relatifs à : Specs G80 et R600 (successeur 7900 et X1900)
