6297 connectés
  Soucie avec une PNY 6600GT 128Mo
n°4985722
greg541
Posté le 13-08-2006 à 16:58:35  profilanswer
Bonjour a vous tous je m'addresse a vous comme vous et des crack en info donc voila mon soucie !!
j'ai acheter une PNY GeForce™ 6 6600 GT AGP8X 128MB GDDR3 VGA + DVI + HDTV-out
voici le desciprtion de la carte video
Specifications
 NVIDIA® CineFX 3.0 engine
 Superscalar GPU architecture
 500MHz core clock
 128-bit high-speed DDR3 memory interface
 900MHz memory data rate
 16GB/sec. memory bandwidth
 4.0 billion texels/sec. fill rate
 375 million vertices/sec. setup
 8 pixels per clock (peak)
 16 textures per pixel (max in a single rendering pass)
 Dual 400MHz RAMDACs
 Maximum display resolution 2048 x 1536 @ 85Hz
 Flat-panel display support with resolutions up to 1920 x 1200
FEATURES & BENEFITS
 Superscaler GPU architecturee
Delivers up to 8X the shading power of previous generation products for outstanding gaming performance.
 High-speed DDR3 Memory Interface
Support for high-speed DDR3 memory delivers fluid frame rates for even the most advanced games and applications.
 64-bit Floating Point Texture Filtering and Blending
NVIDIA's® 64-bit texture implementation sets new standards for image clarity and quality through floating point capabilities in filtering, texturing and high dynamic range (HDR) lighting.*
 NVIDIA® UltraShadow™ II Technology
Enhances the performance of bleeding-edge games that feature complex scenes with multiple light sources and objects. Second-generation technology delivers more than 4x the shadow processing power over the previous generation.
 NVIDIA® Intellisample™ 3.0 Technology
Delivers ultra-realistic visuals with no jagged edges at lightning-fast speeds. Visual quality is taken to new heights through a new rotated grid sampling pattern.
 NVIDIA® Digital Vibrance Control™ 3.0 Technology
Allows the user to adjust color controls digitally to compensate for the lighting conditions of their workspace, in order to achieve accurate, bright colors in all conditions.
 Integrated HDTV Encoder with Video Scaling and Filtering
High-quality scaling and filtering technology improves video playback quality at any window size, including full-screen HDTV resolutions.
 Full MPEG Support
 Microsoft® DirectX® 9.0 Shader Model 3.0 Support
Ensures top-notch compatibility and performance for all Microsoft® DirectX 9.0® applications, including gaming titles utilizing Shader Model 3.0.
 On-chip video processor
Delivers a paramount multimedia experience. Hardware-accelerated decoding delivers smooth, artifact-free video performance, features and quality. PCI Express® support accelerates video editing by speeding up data transfer rates. Integrated HDTV-output brings content from your desktop to your high-definition TV.
 Microsoft®OpenGL® 1.5 Optimizations and Support
Ensures top-notch compatibility and performance for all OpenGL® applications.
voici le lien du fabrican -> http://www.pny.fr/fr/verto_gf6_6600_gt_agp.asp
mon Pc :
Amd Athlon 64 3000+
Carte mere MSI NEO2
1Go de ram (2 rams de 512)
Disque dur Sata Maxtor
Win XP PRO SP2
Donc mon soucie et que quand je lance un jeux C&c Général ,ou un FPS ou autre j'ai des Freeze de 1 a 2 mn de temps en temps dans le jeux !!  quelqun serai me dire si ma carte video a un soucie elle et neuve en plus !!
n°4986086
BDV
Posté le 13-08-2006 à 19:55:57  profilanswer
salut
quelle est la marque et la puissance de ton alim , les 6600gt sont très sensibles au voltage de l' alimentation.
tu as branché la prise molex sur la pny j' espère.
n°4986089
greg541
Posté le 13-08-2006 à 19:58:01  profilanswer
bonsoir mercii de m'avoir repondu donc le model et une L&c Technologie 400 wat c'est la boutique informatique qui ma vendu l'allime avec l'amd 64 et tout le reste !! et pour la prise molex oui c est mie il ventile bien !!
n°4986119
BDV
Posté le 13-08-2006 à 20:09:44  profilanswer
essaye de lancer un jeu en changant de prise molex sur ta 6600gt(une non utilisé en doublon) ou allège ta consommation en débranchant ex: un graveur, mais normalement avec 400 w ça passe.
n°4986133
greg541
Posté le 13-08-2006 à 20:14:16  profilanswer
ok j'ai essaie bon appare la marque de l'allim la prise molex c est la Prise allim qui ce branche appare sur la carte Genre une prise quond branche un Graveur ou lecteur ect... si je me trompe pas !!
n°4986151
greg541
Posté le 13-08-2006 à 20:28:05  profilanswer
bon je vien de tester pareille parcontre je vien de voir un truck en ouvrant la tour donc capot ouvert le jeux freezee pas et pourtemp j'ai un bon Ventilo cpu mais j'ai un doute sur la qualitée du ventilo de la 6600 en fait la jsuis perdu je c st pas du tout si ca vien de la Carte video ou de l'allim mais avec mon ancien carte fx5600 ca tourner super bien !!
n°4986152
BDV
Posté le 13-08-2006 à 20:28:15  profilanswer
oui c' est la même prise que le graveur ou lecteur dvd ou disque dur ide et pas le sata bien sur.
n°4986174
BDV
Posté le 13-08-2006 à 20:38:52  profilanswer
regarde les températures de ta carte, certaines 6600gt ont eu des ventilos mal montés, des coussinets caoutchouc entre le radiateur et le processeur graphique faisaient mauvais contact d' ou surchauffe et plantage, moi sur la mienne j' avais mis un zalman alucuivre.
n°4986188
Matth002
Posté le 13-08-2006 à 20:43:52  profilanswer
Bon. Désolé que ça tombe sur toi, mais y'en a marre.
1) la ponctuation, c'est pour les chiens?
2) C'est quoi cette manie de mettre des tas de féminins la ou y'en a pas? soucie, c'est mie... Comment on peut faire des fautes pareilles?
3) pour ton prob, +1 pour les coussinets.
Message édité par Matth002 le 13-08-2006 à 20:44:09
n°4986264
Angelus006​9
Posté le 13-08-2006 à 21:18:50  profilanswer
Salut tu met quoi comme réglage ,tu pousse ta carte peut être trop fort .
Moi avant je pouvais pas mettre tous a fond surtout en 1280x1024 sur un écran lcd.
ASUS P8Z77-V DELUXE Intel Core i7 3770K @4.8Ghz/2x8Go 1866MHz Hyper-X Fury /GTX 1080TI/Crucial M550 512 go /Crucial M4 256 /ssd intel 240 go /WDC WD10EARS-00Y5B1 (931 Go)   Ecran :Acer 32" LED - Predator XB321HK
[Conseil] Overclocking Athlon XP 2600+ et Geforce 6600GT6600GT PCI Express C'est bien ??
geforce 6600gt qui déconne(encore une..)msi 6600gt agp => ecran noir au demarrage
Brancher ma 6600GT sur ma TV cathodique6600GT ou 7300GT ?
Problème avec 6600gtchoix 6600GT vs 7600GS: température...
6600gt -> 6800gs - Changement de drivers?
Plus de sujets relatifs à : Soucie avec une PNY 6600GT 128Mo
