5203 connectés
  Afox Radeon HD 7850 (Single Slot) AF7850-2048D5S1
n°8413287
eiktee
Posté le 13-08-2012 à 01:49:09  profilanswer
Pas de trace de Afox sur ce forum... etrange.
Voici un produit interessant une carte graphique Radeon HD 7850 simple emplacement.
Marque et modele : Afox Radeon HD 7850 (Single Slot) AF7850-2048D5S1
Photo marketage [:pachyderme] :
http://tof.canardpc.com/preview/c25c62f9-feae-4725-9d8e-fee4247550ae.jpg
Fiche technique : http://www.afox-corp.com/en/produc [...] d=46&id=46
Graphics Engine     AMD Radeon HD7850
Bus Standard     PCI Express 3.0
Video Memory     GDDR5 2048MB
Engine Clock     860 MHz
Memory Clock     4800 MHz ( 1200 MHz GDDR5 )
RAMDAC     400MHz
Memory Interface     256-Bit
D-Sub Max Resolution     2048 x 1536
DVI Max Resolution     2560 x 1600
DVI Output     Yes x 1
Display Port     Yes x 2
HDMI     Yes x 1
HDCP Support     Yes
Accessories     1 x Driver CD
1 x Quick Guide
1 x Power cable
Ou acheter ? http://www.afox-corp.com/en/where_to_buy.asp?Id=19
En Europe de l'ouest des revendeurs en Belgique, Pays-Bas et Royaume-Uni de Grande Bretagne et d'Irlande. Ca fait pas besef... [:p'tit soleil:2]
Test : http://www.tomshardware.de/Afox-Radeon-HD_7850-Single-Slot,testberichte-241012.html (en allemand [:p'tit soleil:4])
Excusez le traducteur automatique, il ne sait pas vraiment traduire...
Volume
You at a constant room temperature of 22 ° C measured values expose now ruthlessly the problems of single-slot design. Just over 42 dB(A) for the hardware-accelerated video output are actually already way too much and disqualify this card thus in the original condition for use in a HTPC very clearly. With a manually adjusted fan curve you can express but quickly this value dB(A) under 39, if you can live with chip temperatures of abundant 80 ° C and ensures that the room temperature does not exceed 25 ° C. Otherwise, it will again according to.
What is gone in a melodrama by the winds of the fan, is gaming then quickly forgotten, because the values determined during the gaming are tolerable, if the in-game sound with a certain minimum level will be held again. The significantly above 50 dB at the stress test are however really annoying and demonstrate the limitations of the design.
Donc pas dans un mini-ITX a priori.  :cry:
A vous de jouer, si vous avez des informations complementaires postez [:rabzorgt] !
Message édité par eiktee le 13-08-2012 à 02:02:45
Probleme etrange avec une Radeon 7750Sapphire R. HD 7870 (oc) ou HIS R. HD 7870 IceQ X ?
Config HTPC + montage video HD (première pro)Radeon HD7850 : différence entre les modèles ?
Meilleure CG passive chauffant peu sur 1 slot en port agp et pci ?HD 7970 Gigabyte o/c ou GTX 670 Gigabyte o/c
Remplacement Radeon HD 6570 par la HD 7770 (pour 94€)Alimentation pour HD 7770 GHz edition
HD 6450 et son
Plus de sujets relatifs à : Afox Radeon HD 7850 (Single Slot) AF7850-2048D5S1
