5146 connectés
  Probleme sappire radeon 9800 Pro 128 Mo 256 Bits
n°3781731
Nubs
Posté le 13-01-2005 à 12:49:31  profilanswer
:o Salut a tous, j espere que vous allez m aider
Ma config: CM Asus a7n8x-la
           512 Mo pc 2700
           Alim 380 Watt
           Radeon 9800 Pro
Voila alors dans catalyste j ai ca :
Windows Version 5.1.2600
DirectX Version 4.09.00.0904
Hardware Acceleration Setting Not Available
Driver Caps Item Number Not Available
CPU Type AMD Athlon(tm) XP  2800+
CPU Speed 2079 MHz
IRQ Table Not Available
BIOS Version Not Available
BIOS Date 10/15/03
RDTSC/MMX/SSE/3DNOW/SSE2 Not Available
North Bridge Chipset Vendor ID 10DE
North Bridge Chipset Device ID 1E0
North Bridge Chipset Revision Not Available
North Bridge Chipset Drivers Version Not Available
North Bridge Chipset Drivers Date Not Available
South Bridge Chipset Vendor ID 10DE
South Bridge Chipset Device ID 1E8
South Bridge Chipset Revision Not Available
South Bridge Chipset Drivers Version Not Available
South Bridge Chipset Drivers Date Not Available
Presence of Dual CPU No
System RAM Amount 511 MB
Driver Packaging Version 8.082-041130a-019577C-ATI
CATALYST™ Version 04.12
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.6497
2D Driver File Path System\CurrentControlSet\Control\Video\{C21C5201-8C3F-4DE8-B825-E285E3881702}\0000
Direct3D Version 6.14.10.0277
OpenGL Version 6.14.10.4776
CATALYST™ Control Center Version 1.0.1796.585
Graphics Card Manufacturer Built by ATI
Graphics Chipset RADEON 9800 PRO
Device ID 4E48
Vendor 1002
Subsystem ID 0002
Subsystem Vendor ID 1002
Bus Type AGP
Current Bus Setting AGP 8X
BIOS Version 008.017D.027.00
BIOS Part Number BK-ATI VER008.017D.027.000
BIOS Date 2004/03/04
Memory Size 128 MB
Memory Type DDR SGRAM / SDRAM
Core Clock in MHz 378 MHz
Memory Clock in MHz 338 MHz
Primary Display Yes
je ne comprends pas grand chose a tout ca mais ca m inquite.
En plus j ai lancé 3dmark2003 et la il me sort un peu moin de 3000
alors que j ai lu les test et elle tourne a 5900!!!!!!!
Aidez moi a y voir plus clair!! :hello:
n°3782288
Nubs
Posté le 13-01-2005 à 16:06:39  profilanswer
Dites moi quoi faire svp
Probleme lecture animation flashpb d'affichage avec ati pro
ATI Radeon 9000 Pro 128moun big probleme de coupure micro depuis quelques temps
Dual Screen avec une Radeon 9200 ?Problème sur une A8N-SLI deluxe - pas de signal à l'écran :/
en détresse : probleme affichageque choisir club3d radeon 9600xt ou msi gforce fx 5900zt ?
Help problème d' o/c athlon xp sur une dfi ad77
Plus de sujets relatifs à : Probleme sappire radeon 9800 Pro 128 Mo 256 Bits
