6297 connectés
  Que pensez-vous de cette carte...
n°2142364
Lamit
Posté le 17-01-2003 à 12:51:16  profilanswer
http://www.prodimex.ch-Images_Pdts-30444.jpg
HIS Excalibur Radeon 9500 PRO 128M DDR/AGP8x/DVI-I/Tv-Out/DirectX9/Power DVD
Features ATI's TRUFORM?2.0, SMARTSHADER?2.0 and SMOOTHVISION?2.0, and HYPER?Z III technologies
SMARTSHAER?2.0 technology supports DirectX®9.0 and enables more complex and realistic lighting effects
Sharper-looking 3D graphics with ATI SMOOTHVISION?2.0 technology
TRUFORM?2.0 technology that makes the outlines of 3D characters and objects look smoother and more natural than ever before
Dual display support with HYDRAVISION?
Integrated TV-Out support up to 1024 x 768 resolution
Integrated DVI-compliant TMDS transmitter
Graphics Processor
- Powered by ATI RADEON? 9500 PRO Visual Processing Unit
- 275MHz Graphics Engine Clock
Memory Configuration
- 128MB DDR memory
- 540MHz DDR Memory Clock
- 128-bit memory interface
RAMDAC
- Dual integrated 10-bit per channel palette DACs
- operating at up to 400MHz
Bus Interface
- AGP 8X / 4X / 2X
Connectors
- On board 15-pin VGA connector for CRTmonitor
- On board S-Video connector for TV-Out
- On board DVI-I connector for Digital Flat Panel
- External DVI-I to VGA adapter for Secondary CRT monitor
- Independent resolutions and refresh rates for any two connected displays
Drivers Included
- Windows® XP
- Windows® 2000
- Windows® ME
System Requirement
- Radeon 9500 PRO requires connection to your PC's internal power supply for operation. A 300watt power supply or greater is recommended to ensure normal system operation where a number of other interanl devices are installed
- Intel® Pentium® 4/III/II, Celeron?, AMD® K6/Athlon® or compatible with AGP 8X / 4X / 2X slot
- 128MB of system memory
- Installation software requires CD-ROM drive
- DVD playback requires DVD drive
n°2142367
mareek
Et de 3 \o/
Posté le 17-01-2003 à 12:54:01  profilanswer
ben c'est une R9500Pro, donc a priori une bonne carte. Je ne sais pas ce que valent les cartes HIS au niveau qualité de fabrication par contre [:spamafote].
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
n°2142371
Lamit
Posté le 17-01-2003 à 12:56:42  profilanswer
Oui, c'est la ma question, que vaut HIS  :heink:
n°2142377
mareek
Et de 3 \o/
Posté le 17-01-2003 à 12:59:37  profilanswer
pas la peine de faire un te copier/coller alors, ça sert à rien
n°2142385
Ernestor
modo-coco :o
Posté le 17-01-2003 à 13:01:05  profilanswer
Et le seul interessant alors c'est la photo de la carte, mais on voit pas grand chose actuellement de ce cote la  :whistle:
n°2142417
Lamit
Posté le 17-01-2003 à 13:15:36  profilanswer
n°2142438
mareek
Et de 3 \o/
Posté le 17-01-2003 à 13:25:40  profilanswer
a priori, ça a l'air d'être le design standard, donc certainement produit par Saphire. Pas de souci à mon avis, tu peux l'acheter.
n°2142455
Lamit
Posté le 17-01-2003 à 13:31:18  profilanswer
ok merci, et au niveau perf, par rapport à Hercules qui est un peu plus chere  :whistle:
n°2142497
Ernestor
modo-coco :o
Posté le 17-01-2003 à 13:49:25  profilanswer
[:plusun]
Niveau perfs : environ 0% de difference  :whistle:
A moins que Hercules ait un BIOS special pour booster les perfs mais c'etait pas le cas pour la 9700 Pro.
n°2142727
Ernestor
modo-coco :o
Posté le 17-01-2003 à 15:18:24  profilanswer
A propos de cette carte : http://www.3dchips-fr.com/articles [...] p=1&IDa=81
Qu es ce que vous pensez de cette carte ???que pensez vous de cette carte graphique ????
Abit AT7 Max 2, que pensez vous de cette carteque pensez vous de cette carte mère ???
Que pensez-vous de cette carte mère??Que pensez-vous de la carte mère Elite K7S5AL ? Compatible Tbird ?
carte mere Jetway, vous en pensez quoi ?Pensez-vous que ma carte Asus Ti4200 DELUXE est bridée sur ma config ?
pensez vous que ma carte graphiqueest morte ??que pensez-vous de la carte MSI VIA KT333 KT3 Ultra2 6380...
Plus de sujets relatifs à : Que pensez-vous de cette carte...
