4583 connectés
  forceware 71.50 ou 71.24 ?
n°3810743
FanGY
Posté le 23-01-2005 à 01:38:52  profilanswer
bonjours
voila sur le site de grub j'ai vu quond pouvais dl la version 71.50 mais sont t"il mieux que les 71.24 ? merci de vos reponse
n°3810778
glossypape​r
Motard des terrasses :o
Posté le 23-01-2005 à 02:25:19  profilanswer
Avec les 71.24 j'avais des bugs de textures sous JO que je n'ai pas avec les 71.50.
Ce sera ma seule contribution :o
n°3811486
guigotech
Posté le 23-01-2005 à 13:32:17  profilanswer
ben moi jme suis balader sur le net et plus particulierement sur www.guru3d.com dsl pour la pub ....
et sur leur site on peut lire ca :
Windows 2000/XP
ForceWare Logo (200 x 30)Leadtek released new 71.50 drivers through their live update. The drivers mostly support Leadtek graphics cards. This is the absolute newest set of unofficial NVIDIA drivers available. The drivers are date stamped on the 22th of December. We have not checked WHQL certification just yet (Microsoft tested and approved).
We virus and ad-ware checked the drivers and they appear to be 100% okay. We recrunched the driver set towards 15 MB. It includes the easy to use setup.exe for easy installation and we left all language files in there.
Included in de modded.inf directory is a  modified .inf file that you can copy into the archive so your GeForce graphics card will be supported. One downside might be that the setup.exe does not work properly anymore. If so, please uninstall your old drivers properly and then install these drivers the old fashion way:
> System properties > Device Manager > Driver > Update
These drivers are to be considered beta, due to that NVIDIA does not support them. Use and abuse at your own risk. Please post and read user experiences in our NVIDIA drivers forum.
We recommend you to use the 71.40 drivers instead of these ones
apres jsais pas trop ce que ca vaut ce qu'il on dit mais pour les 71.40 il dise :
Windows 2000/XP - beta
ForceWare Logo (200 x 30)Two thumbs up to Station.Drivers for posting ForceWare 71.40 drivers. This is the absolute newest set of unofficial NVIDIA drivers available. The drivers are date stamped on the 16th of December. We have not checked WHQL certification just yet (Microsoft tested and approved).
After a good look at the drivers .inf file we noticed that all GeForce cards are supported making this a very interesting release !
moi personellement j'utilise les 71.40 et j'ai aucun probleme sous les jeux ( hl² , doom3 , css , cs .... )
j'ai une 6600 gt apres faut savoir qu'elle carte graphique tu as ?
les 71.40 dl ici: http://downloads.guru3d.com/download.php?det=954
n°3811516
FanGY
Posté le 23-01-2005 à 13:41:14  profilanswer
j'ai une 6600gt de leadtek :D c koi tes score en bench ?
n°3811535
strYd3r
Posté le 23-01-2005 à 13:46:15  profilanswer
slt,  vous pouvez me donner la temperature de vos 6600 gt en idle et en full plz
n°3813867
guigotech
Posté le 24-01-2005 à 07:06:26  profilanswer
ya deja plien de topic pour ca cherche un peut  :)
n°3813869
guigotech
Posté le 24-01-2005 à 07:07:56  profilanswer
mes bench son pas terrible a cause d'un athlon 2400+ :( et d'une carte mere sis stable mais ya mieu :)
admark 2003 : 7000 pts
le 2005 jlai fait mais jme souvien pu  :pt1cable:
Probleme forceware avec G4 TI 4200Probleme de ForceWare...
Quels forceware pour une 6800Gt ?bilan forceware
Quelle version des detonator/forceware pour ma Geforce 4 Ti4200 64Mo ?sortie tv et forceware 66.81
Forceware et correction gammanview et forceware 61.77
ecran et forceware 61.77problemes avec drivers forceware
Plus de sujets relatifs à : forceware 71.50 ou 71.24 ?
