4049 connectés
  ecran bleu
ecran bleu
n°9154199
vicou5
Posté le 20-05-2014 à 17:52:36  profilanswer
salut a tous j'ai quelques soucis je ne comprend pas pourquoi mon pc crash  voici ce que who crashed me dit en sachant que mon alimentation est morte mais je laisse mon pc brancher  :
On Tue 20/05/2014 08:25:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052014-23649-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005023028, 0xBA000000, 0x400405)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Sun 18/05/2014 16:35:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051814-22401-01.dmp
This was probably caused by the following module: hal.dll (hal+0x1218A)
Bugcheck code: 0x124 (0x0, 0xFFFFFA80051C7028, 0xBA000000, 0x400405)
On Sat 17/05/2014 23:25:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051814-22885-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x13FAA0)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80002F95AA0, 0xFFFFF88003FF8508, 0xFFFFF88003FF7D60)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 17/05/2014 23:08:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051814-18408-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75B80)
Bugcheck code: 0xA (0xFFFFF808030C6C38, 0xC, 0x0, 0xFFFFF80002EAD749)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Sat 17/05/2014 20:48:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051714-21652-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80051EA028, 0xBA000000, 0x400405)
On Fri 16/05/2014 08:24:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051614-25131-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800544D028, 0xFA000000, 0x20E0F)
On Wed 14/05/2014 13:34:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051414-20358-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005454028, 0xBA000000, 0x400405)
On Tue 13/05/2014 18:21:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051314-22245-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005453028, 0xBA000000, 0x400405)
On Mon 12/05/2014 19:20:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051214-18033-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80051E8028, 0xBA000000, 0x400405)
Conclusion
19 crash dumps have been found and analyzed. Only 10 are included in this report.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
n°9154280
rastaben
Posté le 20-05-2014 à 19:13:59  profilanswer
Bonjour,  " en sachant que mon alimentation est morte mais je laisse mon pc brancher" ??  le problème est là non ? :??:
mon feed : http://forum.hardware.fr/hfr/Achat [...] #t13351402
  ecran bleu
ecran noir ou bleu 0x19 sur MSI NVIDIA GTX770Problème démarrage PC crah écran Bleu
écran bleuecran bleu pertinant
ecran bleuPC plante avec écran bleu puis redémarre
Problème écran bleuPC ne redemarre pas : blocage / ecran bleu
Ecran bleu - hardware ou software ?ecran bleu
Plus de sujets relatifs à : ecran bleu
