5534 connectés
  Detonator 42.68 dispo ici !
n°2224510
chev_alier
Vive la clim !
Posté le 16-02-2003 à 23:00:26  profilanswer
Vous savez bien... les fameux qui peuvent donné entre 100 et 600pt de + à 3dmark2003 !
Les liens donné par les site d'informatique français ne marche plus, car le site hwextreme.com a retiré les liens.
- Gerard Posch from EntCity send us a note that the new drivers are making some visual artifacts when running 3DMark03.
- I received several emails informing me the scores increased by over 100-200 points in 3DMark03!
- I received a few more emails with scores increased over 300 points and some up to 600 points!
- It's confirmed that the new Detonator 42.68 drivers will increase 3DMark03 scores over 100-200 points but there will be visual artifacts in a few of the benchmarks.
- Users running older versions of 3DMark won't notice any improved performance.
- If you don't bother about 3DMark scores, I would highly recommend you to use Detonator 42.86 drivers.
- Tom's Hardware updated their benchmarks and the performance of their NVIDIA GeForce FX 5800U increased 1785 points, from 3468 to 5253.
We received these drivers directly from NVIDIA, and it's available at their Press FTP. The Press FTP is a private FTP site which requires a login and password and it's not open to the public. We were informed that the drivers were sent out to select members of the press and are not for wide distribution. Due to copyright violation, we have removed the links for the downloads above. You can download the drivers from the NVIDIA Press FTP provided you have the correct username and password. Please contact us if you need any help. :-)
voups.... dois-je retirer mon msg ?  [:whyme]
http://www.windows-news.net/downlo [...] p_4268.zip
Message édité par chev_alier le 16-02-2003 à 23:08:34
n°2224512
banditsuzu​kixp
Posté le 16-02-2003 à 23:02:56  profilanswer
n°2224515
chev_alier
Vive la clim !
Posté le 16-02-2003 à 23:04:05  profilanswer
Bah c'est qu'un driver... spa du warez ou une "certaine démo alpha" [:wanobi le vrai]
Mais bon, si un modo me le demande, j'efface ce topic (où il peut l'effacer lui-même :D)
Message édité par chev_alier le 16-02-2003 à 23:04:52
n°2224521
banditsuzu​kixp
Posté le 16-02-2003 à 23:06:42  profilanswer
j'ai pas suivi cette affaire, il ont quoi c'est drivers?
si y font gagner des points mais font merder le reste...
n°2224529
chev_alier
Vive la clim !
Posté le 16-02-2003 à 23:09:07  profilanswer
Ben y fais des bandes noirs dans 3dmark2003 (d'après des commentaires).
n°2224547
Prophet_ch
Posté le 16-02-2003 à 23:17:31  profilanswer
Je vais les tester sur C&C generals pour voir si le jeu sera plus fluide.
Je suis entre 25 et 32 fps dans le menu principal, je verrai tout de suite s'ils sont mieux que les autres ou pas.  :)
n°2224555
banditsuzu​kixp
Posté le 16-02-2003 à 23:20:09  profilanswer
[:eric_deluxe]  on sera fixé!
n°2224615
Prophet_ch
Posté le 16-02-2003 à 23:46:27  profilanswer
Alors, ça change kedal sous C&C.
Sous 3dmark03, j'avais 1862 avant, 1901 now.
Avec en prime un gros bug, bande noir au milieu de l'écran. Ca vient sur les 2 derniers jeux.
Bref, on y gagne rien.
Prenez pas, ca vaut pas le coup.  :(
n°2225711
le tertre
Posté le 17-02-2003 à 14:56:33  profilanswer
okay, merci :jap:
n°2225732
Jovial
It's clobberin' time
Posté le 17-02-2003 à 15:01:25  profilanswer
et cotes perfs, 1707 avec les 42.86 (sans bande noire par contre ) pour 1750 avec les 42.68  :sarcastic:
aucun interet donc
n°2227008
chev_alier
Vive la clim !
Posté le 17-02-2003 à 20:56:08  profilanswer
Ben ouais... c'est pas avec une GF4 que le score va doubler (mais il augmente quand même un peu ! nuance)... c'est surtout optimisé pour les FX.
Le bug est connu et je l'ai cité !
n°2227100
DI4B0LIK
Posté le 17-02-2003 à 21:27:51  profilanswer
2000 tout pile avant, 1400 avec ces drivers la ! lollll
moi j'dis: j'repasse sur les anciens drivers !
n°2227102
Phlos
Posté le 17-02-2003 à 21:28:01  profilanswer
[:totoz6]
[boitier] Antec : Sonata ou Lanboy -> DISPO !!!La abit nf7s est dispo en V1.1 ?
quel detonator pour dx9 ?Detonator 42.70... ils sortent d'ou??
Bon... QUELLE 9500 PRO vers 9700 (si possible dispo en france hein :)Bonne carte mère P4 dispo ?
Optimiser les réglages Detonator.Recensement des bons Detonator pour TVout
Il est dispo.................les detonator 27.00 WHQL sont dispo sur clubic ...
Plus de sujets relatifs à : Detonator 42.68 dispo ici !
