4998 connectés
  Carte 3D professionnelle GLZ2 !!! Un monstre de puissance !!!
 Page :   1  2  3  4
Page Précédente
n°1969367
Lordben007
Membre Premium
Posté le 17-11-2002 à 00:24:34  profilanswer
J'ai besoin de vos connaissance pour trouver le nom d'une carte 3D :
Elle se compose en 2 parties ( un peu comme les voodoo 2 en sli ; elles prennent 2 PCI ) .La carte est assez longue ( 25 - 30 cm ) C'est marqué intergraph computer system smt219 dessus mais j'arrive pas à trouver quoique ce soit à son sujet !
Autre chose, elle dispose d'un connecteur VGA 15 broches + Svideo . Il y a aussi 1 gros CPU dessus et 2 plus petits à coté .
Edit : voici quelques specifications :
The GLZ series accelerates OpenGL[tm] graphics on Intergraph Computer Systems' TDZ workstations. GLZs let you manipulate Gouraud-shaded 3D models by adding realistic effects such as lighting, translucency, and textured surfaces; and performing spectacular flythroughs, walkthroughs, and animations -- all in real time, at high resolutions, and in true color.
By performing shading and geometry operations in dedicated hardware, GLZs ease the load on the TDZ's Pentium[tm] processor(s) and cut down traffic on the PCI bus, which results in dramatic improvements in graphics performance.
The GLZ family supports Intergraph's 17- and 21-inch multi-sync monitors and 21- and 27-inch InterVue monitors at resolutions up to 1,600 x 1,280 pixels. The GLZs support dual screens and are ready for stereoscopic display on any stereo-ready monitor. (LCD shutter glasses and emitter modules are required and are available from Intergraph Computer Systems.)
The GLZ family offers a selection of 34, 24, or 12 megabytes of VRAM. 24 megabytes of VRAM supports resolutions up to 1,600 x 1,280 with 16.8 million colors (true color). 12 megabytes of VRAM suppots true color at a maximum resolution of 1,152 x 854. 34 megabytes of VRAM supports a 32-bit Z buffer, double-buffered true color, and display capabilities such as translucency and overlay at resolutions up to 1,600 x 1,280.
Intergraph Computer Systems offers six different GLZ configurations
Celle que j'ai serait donc une GLZ 2
24 MB (GLZ2) of high-speed VRAM for 92 bit planes of video memory at all display resolutions, providing:
24-bit, double-buffered image planes
24-bit Z buffer
1-bit, double-buffered overlay
Other planes for additional features and further acceleration
Support for the OpenGL industry-standard graphics library
Full hardware support for Gouraud and flat shading of 3D triangle meshes
Anti-aliased vector support
Industry-standard PCI bus interface with high-speed DMA engine
Genlock support for dual screens
Support for the following Intergraph Computer Systems' monitors:
17- and 21-inch multi-sync monitors (GLZ1 and GLZ2)
21- and 27-inch InterVue monitors (GLZ2)
Stereo-ready display for 3D viewing
Multiple video resolution support for resolutions ranging from 640 x 480 to 1,600 x 1,280 pixels (GLZ2)
Multiple video resolution support for resolutions ranging from 640 x 480 to 1,152 x 864 pixels (GLZ1)
Eight hardware color tables, allowing multiple windows to simultaneously display using independent color palettes
10-bit gamma correction
En bref çà défonce tout  :pt1cable:  :pt1cable:  Même le R9700pro et même le NV 30 !!!!
Message édité par Lordben007 le 17-11-2002 à 05:25:24
Topic Ventes
n°1969376
e-TE
Posté le 17-11-2002 à 00:30:17  profilanswer
ya quoi d'ecrit sur le gpu ? sinon ta possibilite de faire une photo ?
n°1969393
Lordben007
Membre Premium
Posté le 17-11-2002 à 00:36:11  profilanswer
Y'a des Rad sur les 3 cpu / gpu ? ... Et pour l'instant je peux pas prendre de photo à part peut être avec ma webcam de  :kaola:
Je prends la peine de le faire ?
Topic Ventes
n°1969394
fute77
Life Is Short ! Have Fun !
Posté le 17-11-2002 à 00:36:23  profilanswer
Photo ca aiderai
sinon, intergraph sur google ca doit donner qq chose
nan ?
"Si il y avait un impot sur la connerie, l'Etat s'autofinancerai" J Yanne
n°1969400
e-TE
Posté le 17-11-2002 à 00:38:49  profilanswer
essaye toujours avec ta webcam... sinon tu peux les faire fonctionner ?
n°1969460
power600
Toujours grognon
Posté le 17-11-2002 à 00:59:30  profilanswer
http://www.sundance.com/edge/files [...] ctlist.asp
Tiens? Y a une signature, là.
n°1969472
alex1980
Posté le 17-11-2002 à 01:11:16  profilanswer
3000$ :ouch:
n°1969476
Lordben007
Membre Premium
Posté le 17-11-2002 à 01:16:00  profilanswer
La webcam ne marche pas trop bien  :(
Autrement j'ai été voir sur le site mais je retrouve pas le modèle ...
Sur W98 c'est marqué Cirrus Logic 5434 PCI ...
Topic Ventes
n°1969513
Lordben007
Membre Premium
Posté le 17-11-2002 à 01:54:33  profilanswer
C'est bon les photos arrivent  ;)
Topic Ventes
n°1969515
fgruat
1 c'est bien 2 c'est mieux
Posté le 17-11-2002 à 01:57:13  profilanswer
si c la carte que je pensse  :love:
[:fgruat]3dfx c de la balle c quand qu'il sort le rampage ??? jamais a cause de nvidia ??? et aussi webmaster du site www.cleder.com une jolie petite ville pour vos vacances
n°1969531
Lordben007
Membre Premium
Posté le 17-11-2002 à 02:25:36  profilanswer
Qq1 a une idée ?
Topic Ventes
n°1969537
mantronic
Take it to the red line
Posté le 17-11-2002 à 02:40:36  profilanswer
merde j,ai bien vu 36 module de apparemaent de la ddr???
en passant c qu ta trouver ca ou cette carte lol... ca doit bien valoir une fortune!
n°1969538
mantronic
Posté le 17-11-2002 à 02:41:17  profilanswer
en 2k si tu evut la vedre je toffre 100$  :D
n°1969540
Lordben007
Membre Premium
Posté le 17-11-2002 à 02:42:03  profilanswer
de la DDR ? je pense pas quand même !
Y'a vraiment rien de marquer dessus  :(
Topic Ventes
n°1969541
mantronic
Posté le 17-11-2002 à 02:42:48  profilanswer
http://www.geocities.com/SiliconVa [...] smt219.htm
ca te dit qqchose ca?
n°1969542
Lordben007
Membre Premium
Posté le 17-11-2002 à 02:42:55  profilanswer
J'aimerai vraiment savoir ce que c'est avant  :D
Topic Ventes
n°1969543
mantronic
Posté le 17-11-2002 à 02:44:07  profilanswer
scuse sdram c tres possible....
cette carte a 2-3 ans possible?
n°1969544
Lordben007
Membre Premium
Posté le 17-11-2002 à 02:46:43  profilanswer
Y'a marqué çà sur le bas de la carte :
Intergraph computer systems SMT219 Rev C
Et elle peut effectivement avoir 2 / 3 ans !
Cà avance çà avance !!!
Topic Ventes
n°1969546
Lordben007
Membre Premium
Posté le 17-11-2002 à 02:52:07  profilanswer
Sur les chips mémoire :
SEC  Korea
      512Y
KM428C257T-7
Topic Ventes
n°1969550
blazkowicz
Posté le 17-11-2002 à 03:01:37  profilanswer
Ce doit être des puces de 512Ko, de la DRAM FPM ou standard (même pas de l'EDO!) je pense que le -7 signifie temps d'accès de 70 nanosecondes.
et je pense plutôt que la carte est vieille de 7 ou 8 ans.
cf ceci:
http://www.fpga-faq.com/archives/02450.html
des posts parlant de cette carte datent de décembre 95
Message édité par blazkowicz le 17-11-2002 à 03:04:22
n°1969552
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:05:03  profilanswer
Blazkowicz a écrit a écrit :
Ce doit être des puces de 512Ko, de la FPM ou bien de la VRAM? je pense que le -7 signifie temps d'accès de 70 nanosecondes.
cf ceci:
Y'a pas d'images donc je peux pas dire quel modèle c'est . Par contre y'a autant de chips mémoire derrière la carte aussi ( à l'intérieur )
Topic Ventes
n°1969556
blazkowicz
Posté le 17-11-2002 à 03:11:00  profilanswer
cette carte regroupe plusieurs modules transputers !?!
un transputer est un module incluant un microprocesseur et un mémoire, dans le cas présent, 128K de SRAM (de la mémoire cache) et 4Mo de DRAM externe. Les transputers sont utilisés en grappe pour réaliser des calculs parallèles.
c'est joli cte carte. je suppose que les puces surmontées d'un radiateur (y en à quatre?)sont des transputers (la DRAM externe étant déportée ailleurs) et que ces transputers sont utilisés pour des calculs graphiques, qui sont par nature très parallélisables.
qqun peut confirmer?
n°1969559
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:18:51  profilanswer
J'avais oublier que j'avais un scanner moi  :pt1cable:
je fais 2 captures et je les poste !!!
Topic Ventes
n°1969566
mantronic
Posté le 17-11-2002 à 03:34:49  profilanswer
j'estpere tu ^passe pas la carte dans le scanner, ya pas de danger? lol
n°1969567
Marc
Chasseur de joce & sly
Posté le 17-11-2002 à 03:35:25  profilanswer
C'est une Intense 3D, maintenant pour savoir quelle modèle euh ... :D
(1000 ou 2200 je pense)
Message édité par Marc le 17-11-2002 à 03:38:41
Moi, j'aime pas les signatures
n°1969568
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:36:02  profilanswer
La carte est vachement grande quand même ! Elle dépasse un peu de la fenetre de numérisation !
Les images arrivent ...
Topic Ventes
n°1969570
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:37:02  profilanswer
Tu dors jamais toi  :jap:  :D
Le premier qui trouve c'est quoi je lui offre un disque dur IDE de 200Mo  :D
Topic Ventes
n°1969572
Marc
Posté le 17-11-2002 à 03:38:57  profilanswer
Ben fait de vraies fotos );
n°1969573
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:39:52  profilanswer
Cà arrive ...
si seulement j'avais un APN ! T'en a pas 1 qui te sers à rien ?  :D
Topic Ventes
n°1969574
Marc
Posté le 17-11-2002 à 03:42:25  profilanswer
Pas de scanner?
n°1969577
Lordben007
Membre Premium
Posté le 17-11-2002 à 03:53:02  profilanswer
Si j'ai un scanner mais j'avais oublier de le brancher ! Comme quoi çà peut servir  :pt1cable:
Voici les images ( attention c'est plus costaud ! )
http://membres.lycos.fr/teknoblaster007/3d/dos.jpg
http://membres.lycos.fr/teknoblaster007/3d/face.jpg
C'est déjà plus beau non ? Echelle 1:1 quasiment ...
Je peux démonter la carte pour scanner l'intérieur aussi ?
Message édité par Lordben007 le 17-11-2002 à 03:54:05
Topic Ventes
n°1969583
mantronic
Posté le 17-11-2002 à 04:00:57  profilanswer
c pas une intense 3d 2200!!!
n°1969584
Lordben007
Membre Premium
Posté le 17-11-2002 à 04:01:44  profilanswer
C'est quoi çà ?
Topic Ventes
n°1969591
Marc
Posté le 17-11-2002 à 04:10:40  profilanswer
Bon essaye de l'installer tu verra bien :D
n°1969592
Lordben007
Membre Premium
Posté le 17-11-2002 à 04:11:16  profilanswer
Tu renonces ?!  :D  he he  :whistle:
Topic Ventes
n°1969595
saker
Posté le 17-11-2002 à 04:17:51  profilanswer
en tout cas ca fais une belle bete  :o
no sign
n°1969598
Lordben007
Membre Premium
Posté le 17-11-2002 à 04:23:42  profilanswer
J'ai trouvé !
http://www.byte.com/art/9509/sec10/art13.htm
24Mo de ram  :sarcastic: Bon il faut que je l'installe pour voir si çà peut faire tourner Halflife  :D
Topic Ventes
n°1969601
Marc
Posté le 17-11-2002 à 04:32:25  profilanswer
Ben oui mais non, ta carte c'est celle de Integraph (c'est du référence design mais bon), donc c'est pas bon ;)
n°1969603
Lordben007
Membre Premium
Posté le 17-11-2002 à 04:34:03  profilanswer
C'est pas une GLZ2 ?  :(
Topic Ventes
n°1969606
Marc
Posté le 17-11-2002 à 04:38:52  profilanswer
Ba c'est comme si tu faisait un scan de Radeon 9700 et que tu disais c'est la connect3d alors qu'en fait c'est la ati
 Page :   1  2  3  4
Page Précédente
Probleme Carte mere ASUS A7V333 au demaragePb SON avec carte mère MSI
je cherche le pilote pour win98SE d'un carte memoire sur USBquelle carte graphique dans 2 mois??
Quel carte mère pour P4 3.06Ghz HT ?question de disposition de 4 carte PCI
Carte mère de m.... !remplacement de carte graphique
kelle carte mere pour un p4 ht3ghz?qq1 aurait la doc d'une vielle carte mère l'ASUS p2b :)
Plus de sujets relatifs à : Carte 3D professionnelle GLZ2 !!! Un monstre de puissance !!!
