Bonsoir,
J'ai récupéré un PC NEC powermate vl350 slim il y a juste la CG qui déconne un peu. Qd le pc allumé l'écran vibre.
Je pensais changer la CG est en faire un htpc ou un nas.
A votre avis ça peu le faire
Voici la config
Microsoft® Windows® XP Professional
Socket 939
Support AMD Sempron, Athlon 64 and Athlon 64FX processors TM
Support 800 and 1000Mhz HyperTransport (HT) interface speeds TM
Core Logic (Chipset): The ATI RS480 + SB400 chipset consisting of:
PCI Express Interface
Compliant with the PCI Express 1.0a Specifications
1x1 PCI Express general purpose links
Graphics:
UMA mode operation requires no external memory
HYPER MEMORY? technology offers optional dedicated Local Frame Buffer configuration for a 32-bit or 64-bit interface and up to 128MB of memory
3D Graphics
2D Graphics
Multiple Display Feature:
TV out
Power Management Features
Universal Connectivity
System Memory: Four 184-pin DDR SDRAM DIMM sockets
Serial Presence Detect
Support for single-sided or double-sided DIMMs (DDR 333 / DDR400)
Support for up to 4 GB system memory
Asynchronous HyperTransport and memory controller interface speeds
Supports dynamic link width and frequency change
Non-ECC RAM (ECC memory will run in non-ECC mode)
Single and dual channel mode operation:
Single channel mode with single DIMM, non-symmetrical population or non-identical DIMMs
Dual channel mode with 2 or 4 identical DIMMs, populated symmetrically
AC'97 processing using the Realtek ALC655 codec
Realtek RTL8110(SB) 10/100/1000 Mbps controller
I/O controller : LPC Bus I/O controller (SMSC DME1737-NR) I/O controller with the following features:
PS/2 Keyboard and Mouse controller
AC Power Failure Recovery
Floppy disk controller supporting one FDD with 360K, 720K, 1.2M and 1.44M-bytes
Enhanced Digital Data Separator
2 serial ports, NS16C550A compatible UARTs with Send/Receive 16-Byte FIFOs.
1 Parallel Multi-Mode port supporting SPP (Standard parallel Port), EPP 1.7 and 1.9 (IEEE 1284 Compliant), and ECP (Extended Capabilities Port) modes
Motherboard GLUE Logic
LPC Interface · PC99, PC2001 Compliant
ACPI 2.0 Compliant
One CPU Smart Fan controller.
